AMC 20 problems - JeepForum.com
post #1 of 4 Old 04-05-2013, 03:15 PM Thread Starter
jpsmets
1982 CJ7
AMC 20 problems
Hi guys. Haven't been on here in quite awhile, but I just got my 82 CJ7 back and I'm ready to tear into it. I sold the jeep to my brother in law a few years ago. It was in phenominal shape but of course he beat the crap out of so here I am picking up the pieces. I bought it back from him because I felt it suffered enough and now I'm ready to bring it back to life.
So he has it towed to my house after he kills the rear axle. I take a look at it and the part that retains the bearings is shredded on the axle tube. So I start trying to identify exactly which rear I have. I think it was completely modified because nothing matches up. First its a narrow track based on the 50.5" distance between the tires. It has 4.10 gears in it, but it has the letter code B on the diff housing which tells me its wide track with 3.31 gears. The axle tube on the drivers side measures approx. 16" and the passanger side measures approx. 18" Anyone have any clue about this? I want to get a new rear put in, but I'm not even sure what to get at this point.
Thanks guys, and I'm glad to be back in CJ land
jpsmets is offline
post #2 of 4 Old 04-05-2013, 07:33 PM
S76
Are you sure it is a narrow track? Code B if for wide tracks.
Narrow Track AMC 20
Code Gear Ratio Diff Type
AA 2.73 Open
DD 2.73 Trac-Lok
BB 3.31 Open
CC 3.31 Trac-Lok
A 3.54 Open
N 3.54 Trac-Lok
GG 3.73 Open
Q 3.73 Trac-Lok
L 4.10 Open
M 4.10 Trac-Lok
Wide Track AMC 20
D 2.73 Open
DD 2.73 Trac-Lok
B 3.31 Open
BB 3.31 Trac-Lok
A 3.54 Open
AA 3.54 Trac-Lok
H 3.73 Open
HH 3.73 Trac-Lok
C 4.10 Open
CC 4.10 Trac-Lok
The wide trac 20's have 2 different length axles also.
If you always do what you've always done. You will always get what you've always got.
S76 is offline
post #3 of 4 Old 04-06-2013, 06:14 AM Thread Starter
jpsmets
1982 CJ7
Thats kind of what confuses me. If I measure from the inside of each tire I come up with 50.5" for a narrow track. And I thought there was a much bigger difference in the offset on a widetrack. I didn't even notice the 2" difference until I got under there and measured. I know this jeep had quite a bit done to it before I got it like the engine/tranny swap it also used to be stick now its automatic. The gears were changed in the rear at the very least so I figured maybe they did some crazy axle swap where they shortened a wide track for some reason.
jpsmets is offline
post #4 of 4 Old 04-06-2013, 06:33 AM
nshefbuch
1982 CJ7
You can't measure from the inside of the tires. Different size tires would give you different length. 82 was first year for wide track anyways. When I snapped a shaft on mine I actually measured the shaft to order correct replacement. Like mentioned driver and pass side shafts measure differently.
CJ7/SOA /5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt detroit/d44 ARB 4.10 High Steer
nshefbuch is offline
