AMC 20 Pinion Yoke, Crush Sleve Replacement - JeepForum.com
post #1 of 14 Old 07-28-2011, 03:33 PM Thread Starter
Erik719
1983 CJ7
All,
I'm getting ready to replace the pinion yoke on my AMC 20. I've been reading the posts here and studying the FSM. I think I have it under control, but wanted to run it by a few of the "experts" here to make sure.
As I understand it I have two options. 1) Replace the crush sleve (as outlined in the FSM) or 2) Do not replace the crush sleve (as discussed on several posts here).
OPTION 1.
If I replace the crush sleve, there is no need to take a torque reading prior to removing the pinion yoke (correct?). Since I am going to replace the crush sleve, I would just torque the pinion nut to the specifications given in the FSM. One question on this method. According to the diagram, the crush sleve is located behind the bearing and bearing cup. How do I remove this set of bearings? Are the pressed on the pinion shaft? The FSM says to use a rawhide mallett to drive the pinion gear out of the bearings when disassembling the differential. I don't think I want to do that.
OPTIOPN 2.
If I DO NOT replace the crush sleve, I need to take the torque reading prior to removing the pinion nut. This should tell me how much "pressure" is currently on the crush sleve. When I reassemble, I torque to the same spec so everything is (theoretically) back the way it was.
Do I have it right?
Thanks in advance.
BTW: Went to four aouto parts stores last night looking for a beam type, inch pound, torque wrench. No one knew what the hell I was talking about. Two stores had foot pound, beam type wrenchs, one had an inch pound 'clicker' wrench and one only had foot pound 'clicker' wrenchs. One of the clerks I asked for help, didn't even know what a torque wrench was.
'80 CJ7 - Gone but not forgotten
'83 CJ7 - Donkey
Erik719 is offline
post #2 of 14 Old 07-28-2011, 03:41 PM
VACJ7
VACJ7's Avatar
If all I was doing was replacing the yoke, I would not mess with the crush sleeve. Get a new seal too. Take your rotational reading and put it back plus 5 in-lbs for the new seal. I could not find a beam wrench locally either. I had to order one online.
VACJ7 is offline
post #3 of 14 Old 07-28-2011, 06:08 PM
deadeye
1983 CJ7
when I replaced my seal a few years back I used option 2. I retorqued it to the same spec. as it was.
did you try sears for the wrench? IIRC thats where I got mine.
83 CJ7, 350 TBI, TH350, Dana 300 twin stick, Dana 44 E-locker, Ford 8.8, Detroit, 4:10 gears, 35x13.5x15s
"Just Exchange Every Part"
deadeye is offline
post #4 of 14 Old 07-28-2011, 07:22 PM
80cj
80cj's Avatar
1980 CJ5
Use option 2. You don't want to get into replacing pinion bearings if you don't need to.
80cj is offline
post #5 of 14 Old 07-28-2011, 07:35 PM
CSP
'nuther vote for option #2. Take the torque reading to 5 in/lbs more than it was just to take up any slack that may have developed in the bearings since the original install.
CSP is offline
post #6 of 14 Old 07-29-2011, 06:50 AM
bandhmo2
If you were setting up the gears new, you would set the pinion preload to factory spec. with out the carrier or ring gear in. This preload keeps the pinion bearings tight. Since you are not doing a full gear replacement you will most likely not want to pull the carrier, so the ring gear will remain meshed with the pinion. So any torque (preload) readings taken on the pinion will include torque or preload required to turn the carrier bearings and axles if you do not pull them as the FSM specifies. Therefore, whether you reuse the crush sleave or not is not an issue. You should take a before and after torque so as to eliminate the effects of the carrier bearings (and axles if do not pull them as the FSM specifies).
When I had to replace a seal on my AMC 20 I did not have an inch pound torque wrench, so I hung an old onion sack off of one of the bolts on the yoke and added cans of beans to it till it just kept rotating once started by hand. I then removed the yoke and replaced the seal, which was the objective, if you are doing the yoke then do the seal as well they are cheap. I retorqued the pinion nut to the preload weight in cans plus about 2.5 lbs more. This works out to about 5 inch pounds since the bolt the bag hung off was about 2 inches from the center of the pinion.
bandhmo2 is offline
post #7 of 14 Old 07-29-2011, 08:36 AM Thread Starter
Erik719
1983 CJ7
Thanks. I'm sitting outside Sears right now waiting for them to open so I can buy a torque wrench. If they don't have one, I'll try the "onion sack" method.
'83 CJ7 - Donkey
Erik719 is offline
post #8 of 14 Old 07-29-2011, 09:11 AM
CSP
Just be aware that you don't want a click type torque wrench. It need to be a beam or dial type and inch pounds versus the more common foot pounds.
CSP is offline
post #9 of 14 Old 07-29-2011, 10:03 AM
stgil
1982 CJ7
...Like this >>> ONE <<< not very expensive ($35 on >>>amazon <<<) and accurate (I've checked)!!!
Keep the TW1 which has 0-60 inch pound range , TW2 has a biggest range but not accurate enough for reading a preload
Lucky you are... I've bought it in France at $90 ... thank you import taxes
Regards,
Gilles
FULL DANA 30 REBUILD->
CJ7 LAREDO REBUILD->http://www.jeepforum.com/forum/f8/82-cj7-laredo-diesel-restoration-1179198/
stgil is offline
post #10 of 14 Old 07-29-2011, 10:51 AM
atomicflatulenc
Option 3: crush sleeve eliminator.
'85 CJ7, 258 4.2 Howell TBI, NP435, twin sticked Dana300, 4.56 Yukon chromoly: Rear20-extra thick tubes, shaved,trussed,discbrakes,ARB: Front30- flipped tierod,Detroit EZ locker, warn hubs: 3.5" BDS YJ springs and booster, 35" Trxus M/T's, rhino'd, full roll cage, borgenson steering shaft, big daddy steering box bracket...Unknown OIL Leak(working on it...)
FOR SALE $6000
atomicflatulenc is offline
post #11 of 14 Old 07-29-2011, 01:05 PM
VACJ7
VACJ7's Avatar
Erik, If they do not have one you can borrow mine. You are just down the road from me.
Paul
VACJ7 is offline
post #12 of 14 Old 07-29-2011, 04:03 PM Thread Starter
Erik719
1983 CJ7
Paul, thanks. I may take you up on that when the weather breaks!
'83 CJ7 - Donkey
Erik719 is offline
post #13 of 14 Old 07-29-2011, 04:04 PM Thread Starter
Erik719
1983 CJ7
How do you do that?
'83 CJ7 - Donkey
Erik719 is offline
post #14 of 14 Old 07-29-2011, 04:20 PM
80cj
80cj's Avatar
1980 CJ5
Instead of being a collapsible spacer, its a solid tube. You use shims to make fine adjustments. Some people custom turn them in a lathe. But again, it invovles pulling the pinion out.
80cj is offline
Does a Dana 30 or a 44 use a pinion crush sleeve? imtheant Jeep CJ Forum 13 05-31-2011 07:40 AM
Regearing..pinion yoke has a lot of play SwampRabbit Jeep CJ Forum 15 01-29-2010 08:29 AM
AMC 20 Pinion Seal reassembly: What crush washer?? hfjeff Jeep CJ Forum 22 03-26-2007 05:58 AM
pinion yoke shocka59 Jeep CJ Forum 2 10-02-2006 05:46 AM
Dana 30 Ring and Pinion Crush Sleeve Wiggy Jeep CJ Forum 2 01-30-2005 02:30 PM
