AMC 20 / Nissan Drum2Disc Brake Conv - JeepForum.com
post #1 of 13 Old 02-19-2012, 02:08 AM Thread Starter
leeherron
1981 CJ8
I've read a few of these threads and plan on doing this addition, but wondered:
Have we compiled a list of confirmed donor models for the calipers? I've seen zx300 and Maxima, but no clear model years. Any other models? How bout the same for rotor donor?
Is this complete?
Calipers and brackets
Nissan Maxima-1995~01?
Nissan 300 ZX-1987~89?
Rotors
89-98 Geo Tracker
86-95 Suzuki Samurai
This seems like a no brainer conversion with cost being closer to $200 from salvage, than $1200 new.
How to convert rear drum to disc breaks using salvage parts on AMC 20
Reference:
2003 - zuki rotor/nissan caliper - pirate4x4.com
2006 - Disc Brakes w/Suzuki & Nissan - forums.off-road.com
2009 - Rear 20 Disc Upgrade - jeepforum.com
2010 - AMC 20 disc brakes - theamcforum.com
leeherron is offline
post #2 of 13 Old 11-29-2012, 05:28 AM
Tyger78
any new info on this?
I've done lost my mind...... mind.... mind.... mind..... mind..... what a silly word.
Tyger78 is offline
post #3 of 13 Old 11-29-2012, 06:50 AM
waterdowg
That infromation looks right. Not sure if it make a difference, but I rememeber seeing something about wanting the rotors from 4 door Geo or Samurai. I also read something a few weeks ago about using Ford F150 rotors. But there was not year stated on that.
waterdowg is offline
post #4 of 13 Old 11-29-2012, 10:50 AM
jpd1899
1978 CJ7
Try this. It's not complete and I can't guarentee 100% accuracy, but it worked on mine.
http://www.jeepforum.com/forum/f8/am...s-list-957447/
jpd1899 is offline
post #5 of 13 Old 11-30-2012, 08:16 AM
waterdowg
If you want the brackets here you go. http://www.jeepforum.com/forum/f8/maxima-amc-20-disc-brake-conversion-brackets-blue-print-needed-1208307/index2.html Post 22 he just posted this yesteray. He has a few sets.
post #6 of 13 Old 12-01-2012, 09:39 AM
Tyger78
Thank you Waterdowg... I'll be contacting and getting some.
Tyger78 is offline
post #7 of 13 Old 12-01-2012, 04:40 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Don't feel like you guys need to rush and get the last brackets that I have on the shelf.. I cut them regularly.
Also, if any of you are doing "one-off" brake conversions and need caliper brackets, feel free to either shoot me a DXF File (if you have access to CAD), or even send me a good template via mail... trace them out on stiff cardboard or 1/4" plywood/MDF.. I don't mind doing one-offs and shipping them in Flat Rate boxes.
Just keep in mind, the dimensions you send, are the dimensions I cut... With CAD/CAM.. "garbage in= garbage out. "
BESRK is offline
post #8 of 13 Old 12-02-2012, 09:37 PM
mooncruiser
Is this complete?
Rotors
89-98 Geo Tracker
Reference:
Are these front or rear calipers from a Maxima?
mooncruiser is offline
post #9 of 13 Old 12-02-2012, 11:50 PM
lcampbell89
Are yall still using same master Cylinder as stock? Also same brake lines? What other components are needed to do this?
lcampbell89 is offline
post #10 of 13 Old 12-03-2012, 04:38 AM
waterdowg
Get the rear calipers from the maxima. They have the e brake. Also get the short brake hose for those, it will attache directly to youe CJ steel brake hose. As for the MC, that varies. Some claim that it works as is, some claim they make the rear brakes only have 2# of pressure. Other have switch to an early Vette MC. So that is something you will have to work out.
post #11 of 13 Old 12-03-2012, 08:10 AM
mooncruiser
Thanks Waterdowg
post #12 of 13 Old 12-03-2012, 09:16 AM
lcampbell89
Also are these calipers from the nissan maxima the front calipers that we are just putting on our rear?
post #13 of 13 Old 12-03-2012, 09:19 AM
waterdowg
Oh before I forget and no one has said anything about is the e-brake cable. The e-brake cable will attach to the maxima Caliper you may need to get a creative but it should be fine. The other ends were the 2 rears attach to front at the equalizer bar, you may find that are short a inch or so. That can be resolved with a bolt and coupling nut. This will extened the threaded shaft from the front cable and allow out to reach the equalizer bar. You will need to cut the threaded part of the front cable a little, put on the coupling nut, and use the bolt thru the equailzer bar. Depending on the bolt lenght you can either cut the head off and use nuts or use 2 nuts to create a jam on the equaliser bar. It sound like a lot but read it a few time and and look what you have and it will click. This is really easy.
cj , disc brakes , drum brake
4.0 head conv question..... h2oman Jeep CJ Forum 33 09-02-2010 10:11 PM
Power brake conversion out of '84 nissan?? tcarlton Jeep CJ Forum 0 10-24-2009 06:55 PM
Who makes model 20 Nissan conversion brake rotor brackets? CJman77 Jeep CJ Forum 9 09-07-2009 07:35 PM
YJ spring conv. VaCJ79 Jeep CJ Forum 7 06-08-2008 09:05 AM
tj- cj disc brake conv. help rcgkaw Jeep CJ Forum 5 01-18-2007 10:07 AM
