AMC 20 HUB Removal :brickwall - JeepForum.com
post #1 of 44 Old 09-09-2013, 03:07 PM Thread Starter
bobert0670
1980 CJ7
OK So I have gone through the rebuild stickies, and have not seen a good way to do this. How in the friggin world do you get the Hub off the axle shaft? I have tried pullers, and had them where I could not turn the screw any farther without a 4' section of pipe! I started to wonder if they are two piece, but judging from the axle sticking through with a castle nut I would have to say yes. Now I am not shy of using BFH's but I also don't want to break something due to my lack of knowledge on these. Any insight or shoudl I keep beating on it?
Robert
My first ever Resto project.
bobert0670 is offline
post #2 of 44 Old 09-09-2013, 03:12 PM
jeepwhore
Did you smack the end of the puller after it was tight, then re-tighten and repeat?
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #3 of 44 Old 09-09-2013, 03:12 PM Thread Starter
bobert0670
1980 CJ7
OK I found out that I need to get the 3 jaw puller. And as soon as I typed the post of course the next search revealed what I was looking for. I wish I could delete this! Yes Jeepwhore I did with the biggest BFH I have, didnt move a centimeter.
Robert
post #4 of 44 Old 09-09-2013, 03:12 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
Heat...
I have fought with plenty of these and heating the hub to get it to expand, while using the puller and a BFH, is usually the way they come off...
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #5 of 44 Old 09-09-2013, 04:40 PM
skizriz
1978 CJ7
I took mine to a place that works on big trucks. They put them in a 50 ton press and cranked on them until they went boom, literally sounded like a rifle shot.
Handed them a $20 and walked back out the door.
It's the only way to go IMHO.
skizriz is offline
post #6 of 44 Old 09-10-2013, 12:33 AM
80cj
80cj's Avatar
1980 CJ5
You need one of these to get that hub off.
80cj is offline
post #7 of 44 Old 09-10-2013, 08:55 AM
MojoMark
^make sure you get one of those that fits the lug pattern on the jeep. I borrowed one from Napa that was too small and that was the only one they had. I ended up using the neanderthal method to get my backing plate off (BFH, cutters, prybar). But I was putting in new axles
MojoMark
1986 CJ7, 4.2 I6, T5
D300, 2" Lift, 33" Tires
D30 Front (Aussie Locker), AMC 20
MojoMark is offline
post #8 of 44 Old 09-10-2013, 10:12 AM
CJ51973
CJ51973's Avatar
Originally Posted by Truck633 View Post
Heat...
X2. cherry red, really big three jaw, air impact on the puller, 3 pound hammer, get the kid's back.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #9 of 44 Old 09-10-2013, 10:28 AM
keith460
Jeep. There's Only One
keith460's Avatar
Yeah, you need to get the correct hub puller like the one 80cj has posted. Using a standard puller with the jaws behind the hub will likely bend the flanges of the hub and render it useless. A puller designed to be attached to the lug nut studs is what is needed.
If the hub has spun on the axle, as sometimes they do, be prepared to remove the axle from the four backing plate bolts and take it to a shop that has a 50 ton shop press. You will have to snip off the bearing gage that holds the bearing rollers in place in order to separate the backing plate from the axle.
1984 CJ-7 Renegade
keith460 is offline
post #10 of 44 Old 09-10-2013, 10:34 AM
Blakescj7
That sounds like a nightmare. I'm glad mine has one piece axles.
Blakescj7 is offline
post #11 of 44 Old 09-10-2013, 11:37 AM
LumpyGrits
IF you heat to "cherry-red", you have just ruined the axle/hub heat treat and annealed(softened up)them both.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #12 of 44 Old 09-10-2013, 02:55 PM
redsduty
1978 CJ7
I have removed several hubs with a piece of 1/2" plate steel. I drilled 1/2" holes in the same pattern as the wheel studs. Then punched out the wheel studs and lossened the axle nut until it is flush with the end of the axle shaft.
Bolt the plate against the axle nut through the stud holes with the largest bolts that fit and tighten evenly. Keep tightening the bolts and smack the center of the plate with a hammer until it pops loose. A little work to make the plate but it has worked good for me.
redsduty is offline
post #13 of 44 Old 09-10-2013, 03:14 PM
CJ51973
CJ51973's Avatar
Yeah, I was converting to one piece shafts. The whole time I was thinking "you need one piece shafts because those two piece will spin on you". I think the axle would have fallen out of the Jeep first LOL
CJ51973 is offline
post #14 of 44 Old 09-10-2013, 03:45 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Yeah, I'm starting to wonder if the bad rap that the 2-piece axles have is due more to guys running tires that are way too large, and gearing that is way to low, than it is due to a bad axle design.
This mod seems like more trouble than it's worth for my purposes.
Matt
Matt1981CJ7 is online now
post #15 of 44 Old 09-10-2013, 03:51 PM
LumpyGrits
It's NOT!!........
The POS, 2-piece was dreamed up by AMC's 'bean-counters" and they had the last word.
The best 1 piece axle set up is Moser!
LG
amc 20 , hub bolt , hubs
