AMC 20 gears - JeepForum.com
post #1 of 4 Old 10-10-2007, 08:56 PM Thread Starter
jennandal
1983 CJ5
AMC 20 gears
For some reason i cannot access the search feature right now, but earlier today I was reading a post about gears in the AMC 20. Someone wrote about the markings on the differential housing giving you info about what gears are inside. If anyone can post that again it would be awesome. The list stated that there is a letter(s) on top of the housing that designated the gearing and the double letters indicate a limited slip? Thanks for the help.
83 CJ5 w/258 I6, 4.0 HO head swap, Weber 34 w/ nutter bypass, 2.5" shackle lift w/8* castor shims, superlift shocks, 32" Hankook Dynapro MT's, TFI ignition upgrade and coil, dual electric fan off full size Dodge pickup, and tons of wires and vacuum hosing laying around.
jennandal is offline
post #2 of 4 Old 10-10-2007, 09:32 PM
79cj7reny
1979 CJ7
79cj7reny is offline
post #3 of 4 Old 10-10-2007, 10:16 PM
Dreygo
This should help you out more.
http://jeep.off-road.com/jeep/articl....jsp?id=261402
USAF Pavement and Equipment Operator AKA: Dirtboyz Air Force Jeep Club Member 51
1995 YJ 4.0 I-6, AX-15, NP231 w/JB Super Short, Dana 30/35, 4.10 gears. 4" lift, 33X12.5XR15 Goodyear Duratracs/Cragar V Series, Homemade front bumper w/Hella 700FF
Dreygo is offline
post #4 of 4 Old 10-11-2007, 06:26 AM Thread Starter
jennandal
1983 CJ5
Thanks guys, found it!
can i run 35s on my cj5 and what gears should i run eckley25 Jeep CJ Forum 7 09-15-2008 09:09 AM
What gears should I buy? nichols077 Jeep CJ Forum 12 05-20-2008 04:31 PM
Gears spk454 Jeep CJ Forum 5 04-12-2008 08:20 PM
Help with gears hardee81cj7 Jeep CJ Forum 6 10-25-2005 01:52 PM
If gears are shot, can you use 4wd gears? cinnamonbelle Jeep CJ Forum 2 03-24-2003 10:44 PM
