AMC 20 Gear Swap - JeepForum.com
post #1 of 9 Old 01-30-2014, 10:24 AM Thread Starter
556hjytt78
1980 CJ7
AMC 20 Gear Swap
Ok, I've got an AMC 20 with one piece moser axles, locker, and new brakes. It is a 2.73 ratio so I know the carrier wont work with my new 4.56 r&p's. On the jeep now is a tired AMC 20 with the proper carrier for the new r&p's. Here is my question.
Would it be easier to set up my r&p's on the axle with the proper carrier and swap everything over? Or, pull the proper carrier out and put it in the better axle? This is my first r&p set up. Im looking for the easiest way to get my shims correct
Any thoughts or suggestions?
556hjytt78 is offline
post #2 of 9 Old 01-30-2014, 11:16 AM
Knucklehead
1973 CJ5
Either option will require you to do a R&P setup for the new gears so I'd suggest putting the correct carrier from you current axle into the built axlehousing with 1 piece axle shafts and new brakes (assuming the new axle is the correct width for your application).
WJ Build: http://www.pirate4x4.com/forum/jeep-cherokee/2171458-wj-build-sd-axles.html
Knucklehead is offline
post #3 of 9 Old 01-30-2014, 11:23 AM Thread Starter
556hjytt78
1980 CJ7
I have to measure the existing shims to get me in the ballpark when I start the set up. Which shims do I measure? or do I start from scratch with the shims?
post #4 of 9 Old 01-30-2014, 12:53 PM
Knucklehead
1973 CJ5
Unfortunately, you are pretty much starting from scratch - two different range carriers, different housings, new gears. I'd use the shims on the "new" carrier as a ballpark but expect some work from there to get the backlash and contact pattern correct.
post #5 of 9 Old 01-30-2014, 02:48 PM
LumpyGrits
You must do the set up in the axle housing you will be using.
Don't forget that the pinion will be marked +/- for starting reference. Mod 20 shims are on the outside of the bearings. Use the OEM set up to start with. Do a pattern check on at least 3 places on the ring gear.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #6 of 9 Old 01-30-2014, 03:50 PM
Speedy94c
1977 CJ5
My advise would be to find someone that has some knowledge of setting up and r&P. This is a very hard thing to do and requires close tolerances. I wouldnt want you to do it and it not get correct and mess up some $ worth of parts. Good luck with it which ever way you go.
Steve
Speedy94c is offline
post #7 of 9 Old 01-30-2014, 03:59 PM
LumpyGrits
Steve
Good advice.
Special tools needed for R&P work. Inch-pound and foot-pound torque wrench, and a dial indicator that will measure down to .001".
Along with a bearing puller and press.
LG
post #8 of 9 Old 01-30-2014, 06:02 PM Thread Starter
556hjytt78
1980 CJ7
I've got a dial indicator and inch/lb torque wrench. My buddy has set them up before. He will be on standby. Thanks for the input guys.
post #9 of 9 Old 01-30-2014, 07:42 PM
LumpyGrits
You will need a foot/lb. torque wrench for the bolts. Red Loc-tite for the ring gear bolts.
The inch pound is for check'n pinion bearing preload.
Also, get a 0-1" micrometer for measuring the shim's thickness.
Good luck,
LG
