AMC 20 gear and pinion - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > AMC 20 gear and pinion
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe ULTIMATE "Selectable" Locker System! BroughFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 11-27-2013, 03:50 PM   #1
couyon
1983 CJ7
What is the best brand gear and pinion for a AMC 20?
couyon is offline   Reply With Quote
Unread 11-27-2013, 05:30 PM   #2
Skysoldier
1979 CJ7
I have a complete AMC 20 axle with new brakes and 3:54 gears for $100 excellent condition.
Skysoldier is offline   Reply With Quote
Unread 11-27-2013, 05:44 PM   #3
couyon
1983 CJ7
Where are you located?
Unread 11-28-2013, 06:22 AM   #4
atlshaun
Junior Member
1983 CJ8
I am having Yukon YG prefixes installed currently
atlshaun is offline   Reply With Quote
Unread 11-28-2013, 06:24 AM   #5
atlshaun
Junior Member
1983 CJ8
Just a wild guess....but....Beaumont, CA is coming to me...
Unread 11-28-2013, 10:53 AM   #6
ScroungerLee
Funny, I had the same vision
ScroungerLee is offline   Reply With Quote
Unread 11-29-2013, 08:39 AM   #7
Skysoldier
1979 CJ7
No it just means you don't want it bad enough. I was just putting it out there. It originated in CA and is not rusted out. AATW
Unread 11-29-2013, 02:35 PM   #8
agear
yukon or dana
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is online now   Reply With Quote
Unread 11-30-2013, 12:24 PM   #9
80cj
80cj's Avatar
1980 CJ5
Dana does not make AMC 20 gears but Yukon is good. I run Precision 4.10's in mine and they patterned nicely and run very quiet.
80cj is offline   Reply With Quote
Unread 11-30-2013, 05:46 PM   #10
couyon
1983 CJ7
How about G2?
Unread 11-30-2013, 07:05 PM   #11
JeepHammer
Running On Empty...
1973 CJ5
'Best' brand is Dana/Spicer gears.
Works the first time, EVERYTIME with no screw ups. (When properly installed).
There are several places that buy Dana gears and private label them, but you can see the 'Dana' logo stamped into the gears when you get them.
JeepHammer is offline   Reply With Quote
Unread 11-30-2013, 10:09 PM   #12
couyon
1983 CJ7
Where can I find Dana gears for a AMC 20?
Unread 11-30-2013, 10:22 PM   #13
JeepHammer
Running On Empty...
1973 CJ5
Dana/Spicer made the AMC 20 housing and gear sets for AMC.
If you want new gears, they are all over the web, or you can contact users here to see if they will sell what they have.
Unread 12-08-2013, 01:50 PM   #14
agear
I tried a g2 ring and pinion set for my amc 20. They were defective some of the teeth were too thick
Unread 12-12-2013, 04:06 PM   #15
agear
80CJ(BOB) "dana doesn't make gears for the amc 20 anymore"
