AMC 20 end play - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > AMC 20 end play
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 11-02-2014, 01:56 PM   #1
teedubbaya
Junior Member
teedubbaya's Avatar
1983 CJ7
AMC 20 end play
ok, lets see if the youtube link works now...
I'm guessing the end play on this 2-piece is a little out of spec along with shot seals.
Now searching the forum for repair steps.
http://www.youtube.com/watch?v=2UAonEXgQpo
Tony
teedubbaya is offline   Reply With Quote Quick reply to this message
Unread 11-02-2014, 02:39 PM   #2
skizriz
1978 CJ7
Looks like its time for new bearings. Those are shot.
And thats a 1 piece axle.
Sent from my HTC One SV using JeepForum
78 CJ7.. 258.. TH400/Dana18.. SOA/stock YJ springs.. 35" General Grabbers.. Waggy 44s.. 4.88 gears...Spartan/Lockright...Fiberglass front to rear
skizriz is offline   Reply With Quote Quick reply to this message
Unread 11-02-2014, 02:57 PM   #3
teedubbaya
Junior Member
teedubbaya's Avatar
1983 CJ7
One piece? Thanks for the correct information!
How do you tell? I saw an old thread that said if one side has a big nut on it, then it's a two-piece.
Are bearings and seals specific to the manufacturer, or are the all the same fit? How do I ident who made it?
Thanks!!
Tony
Unread 11-02-2014, 05:14 PM   #4
jeepwhore
Hair puller xtraordinaire
jeepwhore's Avatar
The "big nut" would be right in the center of the lug nuts....in the pic below the nut is removed but it threads onto the end of the axle shaft.
2 pc on the left, 1 pc on the right.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline   Reply With Quote Quick reply to this message
Unread 11-02-2014, 05:42 PM   #5
skizriz
1978 CJ7
And yes, the bearings and seals can be specific, even for the same manufactures, depending on how old the axles are.
Best to find out who made them, and give them a call to be certain.
There shouldn't be any slop in them. If you pull them apart, the bearings will probably come tumbling out. Hopefully there isn't any damage done already.
Unread 11-02-2014, 06:52 PM   #6
LumpyGrits
STOP drive'n it, till those 1 piece axles are fixed!
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline   Reply With Quote Quick reply to this message
Unread 11-02-2014, 08:02 PM   #7
teedubbaya
Junior Member
teedubbaya's Avatar
1983 CJ7
Yep LG, it's in the garage until it gets fixed.
Any tips on how to determine where it came from?
Jeepwhore, the axle on the passenger side looks like the one on the left in your picture. The drivers side looks like the one on the right.
Tony
Unread 11-02-2014, 08:06 PM   #8
teedubbaya
Junior Member
teedubbaya's Avatar
1983 CJ7
Ok, looking at new ones online looks like I got a single on one side and a two-piece on the other...ha ha!
Tony
Unread 11-02-2014, 08:08 PM   #9
LumpyGrits
Might be some maker/sellers ID somewhere on the axle.
Worst case, you junk'em both and buy some Mosers.
What's under that center black disc on the hub?
LG
Unread 11-03-2014, 02:06 PM   #10
born2fish
axle in your video looks a lot like my alloy usa axle shaft
born2fish is offline   Reply With Quote Quick reply to this message
Unread 11-03-2014, 02:58 PM   #11
teedubbaya
Junior Member
teedubbaya's Avatar
1983 CJ7
I'll get that sucker pulled this weekend and see what I can find out.
Tony
Unread 11-03-2014, 03:31 PM   #12
LumpyGrits
Again-What's under the disc/sticker in the center of your hub?
LG
Unread 11-03-2014, 11:03 PM   #13
teedubbaya
Junior Member
teedubbaya's Avatar
1983 CJ7
LG, I don't know. I'll have to look this weekend. I'm crazy busy till then, so it sits in the garage. If I end up needing to replace, those Moser sets aren't too terribly expensive.
Tony
Unread 11-08-2014, 09:51 PM   #14
teedubbaya
Junior Member
teedubbaya's Avatar
1983 CJ7
LG, I pulled the one-piece axle and the only thing I could find to ID it is the little disc on the outside, and there isn't much left on it...
Tony
Unread 11-08-2014, 11:38 PM   #15
jeepwhore
jeepwhore's Avatar
The disc with the purple looks like Yukon Gear emblem.
:-D
