#1 | |
AMC 20 drum brake ?'s
My camera is broke or I would of taken pics of the drum set-up before dissasemble. I have two jeep CJ manuels that are as usual little to no help. Searched the internet last night for an hour or so and no real help so I need yours.
Where does the e-brake attach too inside the drum on my amc 20? I think I can get the rest of the set-up but have no idea what it attaches to on the brake assembly. Any write-ups on assembly of the drum brakes for this axle?
1985 cj 7. 360 V8, 35X12.50 BFG's sitting on Crager 15X8 rims, summer brothers axle rear, Yukon axles up front, lock rite lockers front and rear, 5" of lift, body armor, six point roll cage, 8000lb warn winch, 4.56 yukon gears front and rear, t-18, dana 300. And much more on the way. www.therockgods.com www.reno4x4.com |
#2 |
http://www.geocities.com/cantwait_forviolence/images/drum_brakes_setup.jpg
http://www.geocities.com/jeep_resources/images/dbrakes01.jpg Hopefully one of these will help you out. There may be more info on this page too: It attaches to the parking brake lever. You can kind of see it in the picture. http://www.geocities.com/cantwait_forviolence/nav.html
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes. Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA, |
#3 |
There should be a metal plate that swivels front to back is attached to the back shoe. towards the bottom of the plate are two pieces which stick out to make a "c". pull the springy sheath around the cable back, and slid the cable between these 2 prongs.
This probably isn't the world's greatest description, but i hope it helps
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, T150/D20, NT D30/D44, 3.73, 4" Superlift, 33x12.50 BFG KMs, Shackle Reversal, Home built 4x4 tube bumpers, KC Daylighters Future Plans: Waggy 44 front, Scout II 44 rear, Lockers, 35s or so, winch, T18, twin stick. 73 CJ6-Future project when I get out of school |
#4 | |
If it doesnt work I will read the links above. Thanks fellas
#5 |
Alrighty then, got the drum brakes all assembled but now the drums wont fit over the brake shoes. I know that the adjuster on the bottom needs to be adjusted, just not sure of how to do it.
Also, how snug should the brake shoes be against the drum for proper brake wear? Thanks
#6 |
Alpha dog
Turn the star adjuster until it is about as small as it will go, this will pull the shoes in. The drum should then go on. Bolt the wheel back on, and adjust the star adjuster (from the slot in the backing plate) until the wheel can't spin freely. Then back off of the adjuster until the brakes drag a little and the wheel makes about 1 turn with an easyish push.
Then you have to drive it a back and forwards a bunch of times, and each time you use brakes to stop, they will self adjust to the correct preset - as long as you are in the ballpark with the star adjusters. BTW: This may all be moot, unless you are using new drums, as often old ones build up a ridge on the lip of the drum, where the shoes do not wear the drum. Often new pads will be too thick to clear this ridge, and they will not go on easily or at all.
'82 Scrambler - NV4500/4.5" lift/33" BFG/Holley 390 - twin stick, and my windshield washers work! Full 1/2 cab Cage 2004 Grand Limited 4.7 HO - OH Boy! 2010 Grand Laredo 5.7 Hemi - SICK - work vehicle -gone - replaced by an 08 Tahoe - nice ride. "Both my Doberman and my Jeep can accurately be described as 'black and rust.'" "I got a fever . . . and the only prescription is more cowbell" |
#7 |
SERVANT TO THE JEEP GODS
And be sure you have the adjusters on the proper sides (one is reverse thread). If not, the brakes will actually loosen off every time you back up.
'84 CJ-7: 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, Yukon 1 pc axles, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rear aussie locker, twin sticks/clocking ring waiting to go in. The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied. <------------and yes, that is her. :-D |
#8 | |
#9 | |
#10 |
Well its all back together minus a driver rear brake line that I broke while bending. Will get one at the parts store tomorrow. And then maybe I can go for a ride tomorrow.
#11 |
Alpha dog
Glad to see its working out. I'm sure you saw that getting the drums turned will make a level surface with no ridge.
#12 |
Ya its all back together, but the locker is acting up. Gonna go work on some here shortly.
Best deal is that Pep boys did the drums for free
#13 |
Got a friend to come over from one of my 4wheel clubs here in Reno and he's a mechanic and brought over all his fancy brake tools and checked my assembly, explained the mechanics of the brake system to me, and taught me how to bleed my brakes. Luckily I had my brother here to run the brake pedals so I could actually see how its done for once.
Best part is, he's a Toyota guy
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
