AMC 20 Disk Brake conversion - JeepForum.com
post #1 of 21 Old 07-26-2013, 04:18 PM Thread Starter
Truck633
GO ONE MORE!!
Truck633's Avatar
I am creating this thread to steer folks in the right direction, If you have a stock CJ and just want to do a semi cheap conversion, the maxima or nissan 300x swap may be just what you are looking for.
I did the swap with the nissan calipers with (e-brake) and the 2 door rotors from a Geo tracker. To say I was HUGELY let down, would be the understatement of the year!! Simply put, it didn't work. It did squeak loudly, turn the solid caliper a beautiful shade of blue and warped the heck out of one!
Follow the thread here if you are interested.
http://www.jeepforum.com/forum/f8/ma...+20+conversion
Now, for those of you running a larger tire and/ or lower tcase gears, here is the SOLUTION..
I just finished up and not only will it hold the rears in 4low (I have a 4:1 kit in my Dana 300) but you can get it to lock up under a load!!
The calipers are GM, I bought mine from Autozone for a 73 Monte Carlo
there are multiple rotors that fit 5 on 5 1/2, you can get some from an 80's bronco that are close, or possibly use the 4 door tracker rotors, but I didn't measure them out, so I am not endorsing that. I started to build the brackets myself, the ones I got from BESERK are awesome, but like I said before, the pads and calipers are just not powerful enough to stop the 35's.
I will post all the photos below, and you can see the size difference in everything.
On my search, I ran across TSM disk brakes, they sell the brackets that bolt directly to the axle flange and accept the GM rotors, They also sell the 11 9/16 rotor that fits our CJ's. I don't want to advertise against policy here, however for those of you looking to do this swap, it is WELL worth your time to google them up!!!
OK, since I have to resize every photo, I will just put them below, if you have any questions, feel free to hit me, I will answer what I can!!
..ninja edit..
As you can see, I had to get a couple of 45 degree brake fittings to accept the banjo style bolt. Also the caliper brackets come with a welded on tube where they mate up with the flange, I was instructed to either shim these or grind if they were off, just as an added bonus, they fit perfectly with no modification.
They also enclosed shims to take the place of your backing plate, since I had already cut mine, I just used them, however if you want to save a huge headache of cutting your backing plates, these shims fit great and you can ebay your old backing plates for a small fortune!!
Enjoy
Tom
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #2 of 21 Old 07-26-2013, 04:23 PM Thread Starter
Truck633
GO ONE MORE!!
Truck633's Avatar
Forgot to talk about the e-brake.. I got the valve from ricks performance, it simply ties in between the master cylinder outlet and the rear disks.. Press the brake and turn the valve!! We just finished a YJ and it works flawlessly, so when I get mine plumbed in, I will add photos as well!!
Truck633 is offline
post #3 of 21 Old 07-26-2013, 04:35 PM
7CJ5White6
1976 CJ5
Since you can advertise can you send me a list of all the parts you used? Thanks paul_m_white at msn dot com
http://www.jeepforum.com/forum/f8/1976-cj5-complete-tear-down-rebuild-1476311/
7CJ5White6 is offline
post #4 of 21 Old 07-26-2013, 04:39 PM Thread Starter
Truck633
GO ONE MORE!!
Truck633's Avatar
I will try to put them in a list and post it up in a bit, however it is raining straight down and since the CJ is in perfect shape, the boy and I are headed out to play in the mud and prolly break something else!!!!!
Tom
Truck633 is offline
post #5 of 21 Old 07-26-2013, 11:34 PM
billybooster2
1983 CJ8
subscribed.
billybooster2 is offline
post #6 of 21 Old 07-27-2013, 12:28 PM
boojeep
1979 CJ5
In on this upgrade as well. Could be a winter project if the garage becomes mine again.
boojeep is offline
post #7 of 21 Old 07-27-2013, 12:37 PM
Dngrs1
1979 CJ7
Should I assume that the axles be upgraded to 1 piece before this conversion?
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #8 of 21 Old 07-27-2013, 12:58 PM
titomars
1981 CJ7
In many states a line lock or micro lock is not street legal for an emergency/parking brake system. So check your states laws. Here in California and Neveda it must be a mechanical system completely independent of the hydraulic system.
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #9 of 21 Old 07-27-2013, 06:55 PM
BlueRubiconrich
8.8 disc brakes
I used Ford 8.8 rear Disc brakes on a 86 CJ7 with a factory Dana 44
1 I had to enlongagate the side to side holes.
2 I had a company redrill the holes to 5 on 5 1/2
3 I ran a 1/4" spacer on the inside of the rotor.
4 a TJ Rubicon combo valve
5 saddle clamps on the Ebrake cables.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #10 of 21 Old 07-27-2013, 07:32 PM
Fourtrail
1974 CJ6
Did this setup on Dad's CJ-7 and yes it is easy and works great. We used the weld on brackets and the GM 'metric' calipers.
If you use the later 'metric' gm car calipers, Speedway motors sells the e-brake calipers.
http://www.speedwaymotors.com/Emerge...pers,1968.html
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #11 of 21 Old 08-05-2013, 10:50 AM Thread Starter
Truck633
GO ONE MORE!!
Truck633's Avatar
Bumpo to reference a picture....
Truck633 is offline
post #12 of 21 Old 01-14-2014, 10:14 PM
Thbugman
1978 CJ7
Subscribe
Thbugman is offline
post #13 of 21 Old 03-16-2014, 01:22 AM
Spieg8
1984 CJ8
Tom
What happened to this thread? Was there a list of parts somewhere and I just missed it? Was the build a success or fail?
Last word for OP was that they were going to go drive in the rain/mud... hope the brakes didn't cause an accident.
Spieg8 is offline
post #14 of 21 Old 03-16-2014, 08:11 AM
Mike Romain
Same for up here in Canada.
The OP also states he can lock up the rear brakes under load also! Yikes, can we say how to do 360's in one easy lesson!!!
There is supposed to be a combination valve in Jeeps and most other vehicles that prevents this from happening.. It is extremely dangerous to have the rear wheels lock up on you at speed.
If in part time 4x4 with the front and rears locked together, you just go out sideways into the ditch which is why the CJ owners manual says to stay off the brakes when in 4x4, to use the gears to slow down and just brake at the end.
If in 2 wheel drive and you lock the rears up, you do 360 spinouts faster than you can blink.
Normal panic braking locks the fronts and loads the rears. The rears keep turning until you are almost all the way stopped.
Mike
Mike Romain is offline
post #15 of 21 Old 03-16-2014, 08:16 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I'm curious if this mod worked, as well. I don't think I've read a disc brake conversion thread that was a complete success, yet.
Matt
Matt1981CJ7 is offline
