AMC 20 disc brake conversion - Page 2 - JeepForum.com
post #16 of 21 Old 04-22-2011, 01:48 PM
jwhite_00
deleted.
jwhite_00 is offline
post #17 of 21 Old 04-22-2011, 02:40 PM Thread Starter
johnnypac
1980 CJ7
Originally Posted by frodin1 View Post
NASTRA Part # 121219 front left NASTRA Part # 122467 rear left. 2 different part numbers. Lol. Wow, I'm pretty sure the fronts wouldn't have the e-brake mechanism on them.
Yea, that's what I just said in my previous statement, the numbers would be different "for obvious reasons" meaning the rear has ebrake. so now I go out and find out if the fronts will work by trial and error.
The reason I started this thread is because I have seen thread after thread on the conversion. None of them mention being able to use FRONT maxima calipers (which the only ones I have access to) but the threads date bake for YEARS. So I was wondering if over those years someone had used the front. Well, I'm gona find out this weekend if they work or not.
johnnypac is offline
post #18 of 21 Old 04-22-2011, 06:23 PM
jeepwhore
Back when I was considering doing the disc swap I was having trouble finding info too. Looking back through my notes I didn't find much except a list of calipers, without ebrakes, used in other kits available on the market:
78-83 Chevelle, Monte Carlo, El Camino, Malibu, Tempest, Cutlass, F-85, Pontiac Grand prix, Le Mans, GTO, Grand Am, and Bonneville.
However, I couldn't find what rotors were used with these calipers. I'm thinking maybe stock D30 rotors would work but I can't remember if they were too deep and interfered with getting the caliper mounting brackets in place. If they do fit without issue I suppose you could use stock D30 calipers as well but this is all just assumption on my part at this point as it's been over a year since I last considered doing this.
I'll keep looking and see if I can find anything on my mac when I get home next week.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #19 of 21 Old 04-22-2011, 06:32 PM
SeaWulf
1983 CJ7
Most swaps using car calipers use Geo Tracker or Suzuki Samurai front rotors since they are the same lug pattern and are thin enough to fit the car calipers.
You could also use F150 front calipers and rotors with some work.
It all comes down to your fabrication ability, budget, etc
SeaWulf is offline
post #20 of 21 Old 04-22-2011, 07:30 PM Thread Starter
johnnypac
1980 CJ7
Thanks for the help. Let me know if you come up with anymore info.
post #21 of 21 Old 04-22-2011, 07:38 PM
frodin1
1980 CJ7
I know people have done swaps on full size Chevy's/broncos/and blazers using Cadillac calipers. But those all use the rears, because they use the E-brake. However the fronts may work if you don't want the e-brake? They make ready made brackets that they just bolt up to. Don't know if it could be adapted to a Jeep, but it would make finding parts easy. I was looking into it for my 3/4 ton.
frodin1 is offline
drum to disc brake conversion 284916 Jeep CJ Forum 4 11-04-2010 04:46 AM
CJ disc brake conversion ? NCHornet Jeep CJ Forum 11 12-06-2007 07:47 PM
CJ7 Disc Brake Conversion for REAR Jonnyhaku Jeep CJ Forum 3 04-16-2007 07:42 PM
Disc brake conversion question Tractor Boy Jeep CJ Forum 1 03-28-2007 02:47 PM
Disc Brake conversion CJmadison Jeep CJ Forum 4 02-24-2006 03:14 PM
