AMC 20 axle shaft removal, confusion - JeepForum.com
post #1 of 6 Old 11-04-2013, 01:55 PM Thread Starter
stvincnt
1979 CJ5
I'm hearing a grinding noise in my passenger side rear axle. I'm assuming the bearing is shot. I want to pull the axle and I've researched the steps on the forum but I'm still confused . Some posts say that I have to loosen the backing plate and some say its not necessary. I believe it that it is the two piece type axle setup. Thanks in advance
stvincnt is offline
post #2 of 6 Old 11-04-2013, 02:00 PM
jeepwhore
The backing plate has to come off. If it's a stock 2 pc axle the bearing goes on from the outboard end of the shaft and the shaft assembly is held into the axle tube by the backing plate. No way to replace the bearing or pull the axle shaft without removing the backing plate.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline
post #3 of 6 Old 11-04-2013, 02:05 PM
LKCJ
1983 CJ7
If it is a model 20 axle, removing the brake backing plate will be necessary.
LKCJ is offline
post #4 of 6 Old 11-04-2013, 02:05 PM Thread Starter
stvincnt
1979 CJ5
Thanks for reply, Does that mean I have to take apart the breaks, I hit one bolt and it just spun, I'm assuming those are nuts and bolts
stvincnt is offline
post #5 of 6 Old 11-04-2013, 02:20 PM
LKCJ
1983 CJ7
There are 4 bolts that go through the backing plate the otter seal and seal cover. If it is a two piece axle you will want to remove the otter hub first.
Then the brakes. Then the 4 bolts. Good Luck!
LKCJ is offline
post #6 of 6 Old 11-04-2013, 02:30 PM
ASteve
1972 CJ5
Here's a good picture thread on the AMC model 20:
http://www.jeepforum.com/forum/f8/fu...l#post11481098
SC
ASteve is offline
