AMC 20 77 CJ7 to 78 CJ5?? - JeepForum.com
post #1 of 9 Old 09-13-2009, 03:40 PM Thread Starter
texasimport
1978 CJ5
My 78 CJ5 is stamped "A" 3.54 open and I found a 77 CJ7 stamped "N" 3.54 trac lock can I do a direct swap. . .any supporting hardware need for trac lock??? sorry to sound like a nube but that's the case.
78 304-CJ5
texasimport is offline
post #2 of 9 Old 09-13-2009, 03:59 PM
trailridin4x4x4
1981 CJ7
should be a direct swap, no hardware needed other than new fluids be sure u buy "limited slip" attitive with your gear oil.
trailridin4x4x4 is offline
post #3 of 9 Old 09-14-2009, 02:24 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Do you want to swap the entire axle in, or just the LSD carrier and ring gear?
You can swap the entire LSD axle in place of the open axle, but if you want to swap the LSD and ring only, you need to do a gear setup.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #4 of 9 Old 09-14-2009, 03:26 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
No offense, but if your doing the swap for the Trac Lok, don't waste your time. I have a very low opinion of these after seeing countless numbers of them grenade and would rather run an open diff if given the choice.
jeepdaddy2000 is offline
post #5 of 9 Old 09-14-2009, 07:33 PM Thread Starter
texasimport
1978 CJ5
Thanks guys. . . .found a nice amc 20 "A" 3.54 open. . . . .from a friend no less. . . . recent brakes bearings and in good working order. He 's doing a full build and wants stronger. And I get the dana 30 to also in good shape, so might swap that one too. I might as well do new springs and shocks while I'm in there. Told my son we have this thing in shape with in a year, might be ahead of schedule.
78 304-CJ5
post #6 of 9 Old 09-14-2009, 07:46 PM
gojeepin
1983 CJ7
What year are the axles you just found?
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #7 of 9 Old 09-14-2009, 07:56 PM Thread Starter
texasimport
1978 CJ5
Not actually sure late 70's early 80's will know tomorrow. AMC 20 narrow and it should fit. The guys a mechanical engineer so I know he did it right. Is there a year or years to stay away from?
78 304-CJ5
post #8 of 9 Old 09-14-2009, 08:33 PM
gojeepin
1983 CJ7
The only CJ AMC 20 rear you couldn't use is the one for the Quadratrac.
I thought maybe you found some wide-track axles... they'd bolt right in.
gojeepin is offline
post #9 of 9 Old 09-14-2009, 10:30 PM
80cj
80cj's Avatar
1980 CJ5
Exactly. They don't perform very well as a limted slip and the case is useless for installing a lunchbox locker. Even when new, it is barely better than an open diff. I ran GL-5 in mine and never had any problems with chattering. No need to add friction modifier. I pulled it out after running it for only 30K miles and replaced it with an Auburn. Better but not as good as a Truetrac.
80cj is offline
