AMC 1973 Rambler 304 in CJ7? - JeepForum.com
post #1 of 5 Old 08-13-2002, 03:37 PM Thread Starter
kev1
Question AMC 1973 Rambler 304 in CJ7?
Does anyone know if a 304 out of a 1973 AMC Rambler drop into a 1980 CJ7? What would I have to do to make it work? Change of motormounts? Oil Pan? etc...
Thanks
kev1 is offline
post #2 of 5 Old 08-13-2002, 07:42 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
If your're replacing a 258 then you'll need the pass. side engine mount to install the AMC V-8.
Steve
OldJeepguy is offline
post #3 of 5 Old 08-13-2002, 07:56 PM Thread Starter
kev1
It will be replacing a GM-151 4 banger, the standard engine that came with the jeep. I think a valve is sticking and the SR-4 Transmission doesn't like 2nd.
I just got it and it needs some body work, so I am trying to get it reliable before winter.
kev1 is offline
post #4 of 5 Old 08-14-2002, 09:44 AM
mxg342
mxg342's Avatar
Are you planning on keeping the SR-4 or not?
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline
post #5 of 5 Old 08-14-2002, 09:51 AM Thread Starter
kev1
At this point, I am trying to get a T-176 so I won't be keeping the SR-4 nor will I be keeping the GM-151 if I find a 258.
kev1 is offline
1973 Cj5 Marinehorne Jeep CJ Forum 24 02-10-2011 09:10 PM
1973 Cj5 Marinehorne Jeep CJ Forum 1 08-16-2009 07:02 PM
CJ5 1973 would you buy it???? jeeperscrepers Jeep CJ Forum 7 03-09-2009 08:51 PM
1973 Cj5? seagrave Jeep CJ Forum 9 02-11-2009 06:48 PM
1973 Cj5 Skeg Jeep CJ Forum 22 04-16-2007 08:29 AM
