Alyssa's '65 CJ5 Navy Jeep - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Alyssa's '65 CJ5 Navy Jeep
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 07-12-2013, 01:17 AM   #1
Rollbar
1984 CJ8
Well we/Alyssa just bought a 1965 CJ5 Navy Jeep. PO put new springs on and shackles but it is a clean Jeep and we are going to fix her up as a DDriver.
4 Cyl, 4:27 Gears, new head job/valve job done and the window opens out. I think it was used on the flight line side of the Navy.
Now we just have to tow it home and go through it.
Project CJ8 Build Gallery <----Click
CJ8 Build Thread<---- Click
Rollbar is offline   Reply With Quote Quick reply to this message
Unread 07-12-2013, 02:23 AM   #2
MoC
Congrats to y'all!
MoC is offline   Reply With Quote Quick reply to this message
Unread 07-12-2013, 06:40 AM   #3
Jeeper44mag
1978 CJ7
Very nice!!!
'78 CJ7, 304, ps, pb, A/C, ~3" Lift, 12.5"x33" MTZ's., T150/D20, D30/AMC20, 4.56.
Jeeper44mag is online now   Reply With Quote Quick reply to this message
Unread 07-12-2013, 06:43 AM   #4
Skerr
Dang nice shape! This will be fun. Congrats.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 07-12-2013, 10:40 AM   #5
LumpyGrits
Love the cobwebs.
How's it run?
Looks to be solid and in dang fine shape.
LG
LumpyGrits is offline   Reply With Quote Quick reply to this message
Unread 07-12-2013, 11:30 AM   #6
Rollbar
1984 CJ8
I haven't started it yet but I did pull on the V belt and rotated the motor 2" so it is not frozen
Might just let my daughter drive the CJ8 and I drive this
Unread 07-12-2013, 08:37 PM   #7
WNC-84CJ7
Cool jeep.
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
-- Thomas Jefferson, 1 Thomas Jefferson Papers, 334
WNC-84CJ7 is offline   Reply With Quote Quick reply to this message
Unread 08-13-2013, 09:49 PM   #8
Rollbar
1984 CJ8
Also got my daughters '65 Navy Jeep running after 7 yrs.
Sorry, I said the rad cap was a gas cap etc-been a long day and that is 3 gallons of fuel.
Unread 08-13-2013, 10:00 PM   #9
Rollbar
1984 CJ8
Throttle linkage problem.
Unread 08-13-2013, 10:17 PM   #10
Rollbar
1984 CJ8
Ok, looking at the brake lights-well, they don't work.
Headlights work, rear running lights work when headlights are on, BUT, the front parking lights do not come on when the headlights are on. They do come on when the light switch is at the parking light position.
Also, this Jeep does not have a turn signal lever to on the column.
Does anyone have any idea on the brake lights/is there a switch that is supposed to be engaged when the pedal is depressed?
Thanks,
Jim
Unread 08-13-2013, 10:37 PM   #11
lucdog
lucdog's Avatar
1980 CJ5
Jim, I'm not certain on this year Jeep, but if the brake pedal goes into the floor, and it's not hung from the dash, I believe the switch is on the master cylinder.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 08-13-2013, 10:43 PM   #12
Rollbar
1984 CJ8
Oh Ok, thanks Bill, I'll have to look for it.
Ya the pedals are not swing pedals, but push to floor.
Thanks,
Jim
Will update:
Unread 08-14-2013, 08:51 AM   #13
WindKnot
1977 CJ7
Good for you! Stay the course (Navy pun) and you're going to have a GREAT Jeep!
I'd rather be lost on the trails than found at home!
[b]Phoenix Rising- A Flame Off Restoration?[/b] [url]http://www.jeepforum.com/forum/f8/phoenix-rising-flame-off-restoration-1807257/[/url]
WindKnot is online now   Reply With Quote Quick reply to this message
Unread 08-14-2013, 10:28 AM   #14
Balvar24
1979 CJ7
Brake switch is on the master cylinder.
You can buy aftermarket turn signal kits that include a rocker switch that will mount you your column.
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline   Reply With Quote Quick reply to this message
Unread 08-14-2013, 10:55 PM   #15
jeepdaddy2000
1971 CJ5
That is because they are parking lights. They aren't supposed to be on with the headlights.
Up until 76, turn signals were an add on item, which were attached to the steering column. The "stock" units aren't available anymore,
But you can get a regulator from any truck stop.
This is a common replacement unit. You will have to wire in the complete system, to include the brakes.
It should be a pressure switch either on the front or bottom of the MC.
jeepdaddy2000 is offline   Reply With Quote Quick reply to this message
