Aluminum valve cover install - JeepForum.com
post #1 of 5 Old 09-25-2011, 10:03 AM Thread Starter
Ollie09
1983 CJ7
I bought an aluminum valve cover to replace the plastic one and 2 mounting holes on the intake side need to be drilled & tapped. I read through many of the threads reguarding this install, and all say to not go to deep or you'll hit water. None said exactly how deep the drill should be. Anyone know?
Thanks,
Gary
Ollie09 is offline
post #2 of 5 Old 09-25-2011, 10:14 AM
somdfisher
1981 CJ7
When I did mine, I didnt go more than maybe a 1/4 inch. It was last year so I can't remember off hand. If you do a search there are many threads discussing this. That is where I got all my info. Actually, just about everything I've thought about has been discussed on here.
O|||||O 1981 CJ7, 258, 4 speed..If it ain't cut, it ain't custom.
somdfisher is offline
post #3 of 5 Old 09-25-2011, 11:34 AM
VACJ7
VACJ7's Avatar
Mine had the holes so I did not have to drill. I just used a blind tap as far as I could go. My holes were only deep enough to cut maybe 3 threads, which is fine because it is not like there is a lot of torque on those bolts.
'84 CJ-7 |
VACJ7 is offline
post #4 of 5 Old 09-25-2011, 07:43 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
how long are the bolts that go into the cover? put them in the aluminum cover and see how much deeper they would go..
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #5 of 5 Old 09-25-2011, 08:31 PM
MrWonderful73
I've done it twice now (2 different engines) first time I drilled about a 1/4 inch and hit the water jacket, second time I drilled about 1/8 inch and used a bottem tap. Like the poster before it wont cut many threads but it holds fine, you may have to put a couple washers on the bolt it it bottoms out before it tightens. Or you could put studs in, thread locker and put nuts on it. Good Luck
MrWonderful73 is offline
Install of Aluminum Valve Cover Vonster Jeep CJ Forum 16 05-12-2015 12:05 PM
Aluminum Valve Cover Install abernut Jeep CJ Forum 23 05-10-2013 12:07 PM
Aluminum Valve Cover install somdfisher Jeep CJ Forum 0 05-12-2010 10:30 AM
aluminum valve cover oil cap TexasCJ7 Jeep CJ Forum 3 04-15-2007 03:22 PM
Aluminum valve cover DustinsCJ7 Jeep CJ Forum 12 10-19-2003 11:46 PM
