Aluminum Valve Cover Install - Page 2 - JeepForum.com
post #16 of 24 Old 04-28-2011, 06:15 PM
podboy333
1983 CJ7
Originally Posted by Oily View Post
I bought a Clifford aluminum valve cover and they suggested and supplied yellow weatherstrip adhesive. The instructions stated to *glue* it to the valve cover.
I say this because, I would never glue a gasket to the head. It will have to be scraped at sometime later. Gluing to the valve cover keeps the scrapings from falling into the head.
Can you find a picture or link to the type of weatherstrip adhesive you are talking about? Never heard of using that before.
abernut, great post....I love seeing a tidy engine bay and this makes me want to go out and start getting mine cleaned up.
For best results, try not to do anything stupid.
Fight Crime...Shoot Back.
podboy333 is offline
post #17 of 24 Old 04-28-2011, 11:20 PM
sdrewel
1976 CJ7
http://3mcollision.com/3m-black-supe...3602-4250.html
Thats from 3M's website. you can pick it up at any auto parts store. Personally I like the black, but the yellow works just as good.
sdrewel is offline
post #18 of 24 Old 04-29-2011, 04:51 AM
243
1978 FSJ Cherokee
Just ask for Gorilla Snot
Dave's 78 Build
243 is offline
post #19 of 24 Old 04-29-2011, 06:18 AM
spittoon
quick question, do you HAVE to tap out larger holes in the head or can I use the current, smaller-sized bolts?
spittoon is offline
post #20 of 24 Old 04-29-2011, 08:22 AM
mcmud
1983 CJ8
If you are referencing a smaller hole that is already threaded use it instead.
Some heads will have holes threaded and smaller helicoils inserted into them, while others will only have indexing holes, those are rather shallow but I've read that tapping them without drilling deeper has been successful.
Point is there are several different head treatments, your application may vary.
While the "gorilla snot" sounds very effective I've always used Indian Head gasket shellac, gluing the gasket to the valve cover. IMHO using a silicone sealer is a
mcmud is offline
post #21 of 24 Old 04-29-2011, 06:09 PM
hutchmanhd
I asked for some "Gorilla Snot" at NAPA the other day and the girl behind the counter said, "I don't think we sell that!" LOL!
1986 CJ7 Stock
hutchmanhd is offline
post #22 of 24 Old 05-10-2013, 01:47 AM
geraldfrasl
hey what5 was the wireing that you removed from the left side of the firewall
geraldfrasl is offline
post #23 of 24 Old 05-10-2013, 06:53 AM
GP_Pete
GP_Pete's Avatar
Originally Posted by abernut View Post
Here's a closer look.
Still a long way to go, but slowly getting there.
This weekend I am going to tackle the Charcoal Canister and Fluid tanks...After seeing Kens http://www.jeepforum.com/forum/f8/ke...hread-1040550/ I am feeling inspired.
Looks great dude. Good work.
GP_Pete is offline
post #24 of 24 Old 05-10-2013, 11:07 AM
sparkey
1983 CJ5
valve cover
I used the existing indexing holes and tapped those, believe they are 5/16", used S/S allen heads. Just check the depth, used Permatex High Tack gasket sealer on the cover, set it on my steel work table for a awhile, gasket down, and it has worked just fine for those that might want to try this.
Say what you think because those that matter don't mind and thoes that mind don't matter.
sparkey is offline
Install of Aluminum Valve Cover Vonster Jeep CJ Forum 16 05-12-2015 11:05 AM
Aluminum Valve Cover install somdfisher Jeep CJ Forum 0 05-12-2010 09:30 AM
258 Aluminum Valve Cover MrWills Jeep CJ Forum 5 05-06-2010 09:08 AM
Aluminum Valve Cover oil cap twmattox Jeep CJ Forum 7 10-16-2007 09:32 PM
Which Is The Best Aluminum Valve Cover dhood Jeep CJ Forum 4 09-12-2007 12:36 PM
