Aluminum or steel for my tie rod? - JeepForum.com
post #1 of 2 Old 02-06-2002, 12:22 PM Thread Starter
junger
Post Aluminum or steel for my tie rod?
I'm replacing my tie rod with beefier tie rod ends on my CJ7. I got to thinking about the new tie rod by Challenger Performance called the Alumi-Flex. Aluminum, although not as strong as steel, has a greater tensile strength (meaning a greater ability to return it it's original shape). They don't make a Alumni-Flex for a CJ7, but I can just fabricate one. But, should I go with it, or stick with a steel tie rod? Can any one see any advantages or disadvantages?
Thanks!
-Josh
junger is offline
post #2 of 2 Old 02-07-2002, 09:08 AM
T Hoff
1975 CJ5
Post
I'd stick with steel.
Aluminum Alloy is 'brittle' almost like an exhaust manifold is (Cast metal). It is strong but if it's bent, it tears. And bending it back is a real hazzard.
With metal, if you smack a rock and want to bend it back, get a big hammer, with Aluminum...you will ruin the strength of the part.
'75 CJ5 ---Chevy HP 350 motor-- All Fiberglas---one piece tilt forward nose
1985 chevy stepside pickup, 300K on the clock: Original Owner
1989 Volvo 240 300K on the clock: Original Owner
the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K
T Hoff is offline
STEEL OR ALUMINUM ALLOY RIMS 2cjs Jeep CJ Forum 5 03-14-2011 10:57 PM
Best Tubs - Steel, Fiberglass or Aluminum RetiredSERE Jeep CJ Forum 9 01-19-2009 11:41 AM
Helicoil in Aluminum 5555555 Jeep CJ Forum 10 01-18-2009 10:46 PM
Valve Cover. Plastic, Aluminum or Steel? White92 Jeep CJ Forum 10 06-23-2007 04:48 AM
Aluminum Radiators Lightningdon Jeep CJ Forum 6 10-15-2003 09:36 PM
