Aluminum Scrambler build - JeepForum.com
post #1 of 35 Old 03-27-2013, 04:36 PM Thread Starter
GPERSCREEPERS99
GPERSCREEPERS99's Avatar
After years of wanting a CJ8 and trying to buy one locally also on ebay that was already done and have seen driving around town for a few years I placed several bids and I was the top bidder but I didn't hit the reserve. Turned out when I contacted the guy he wanted 25k and I was at 16k and we couldn't make a deal we were too far apart so a couple weeks later I gave in on a whim and well I bought this one that needed lots of work on ebay in Oct. 2011 and had it shipped from Virginia
Pictures from ebay listing
It looked pretty solid just surface rust for the most part...so I thought. Pictures can be deceiving. I saw some holes but nothing I thought couldn't be patched.
It arrived at 9pm so here is some pictures of it the next day.
99 Jeep Wrangler built on 35's
82 Aqualu Aluminum Scrambler Chevy 350 on 33's
14 JKU Rubicon My Daily Driver
12 Grand Cherokee Wife's Daily Driver
GPERSCREEPERS99 is offline
post #2 of 35 Old 03-27-2013, 04:39 PM Thread Starter
GPERSCREEPERS99
Disassembly started
Last time it moved under its own power
No more body
post #3 of 35 Old 03-27-2013, 04:43 PM Thread Starter
GPERSCREEPERS99
Rusty cross members and old gas tank
New crossmebers on and After sandblasting and first coat of KBS Coatings
Ford 9 inch before sandblasting
after blasting
After painting
post #4 of 35 Old 03-27-2013, 04:44 PM Thread Starter
GPERSCREEPERS99
After install with RE 4.5 lift
Chevy 350 ready to go
Old tub and all the parts I bought to fix it being hauled back to Buffalo area of NY from my house in Chicago
New tub arrived from Aqualu Industries in BC Canada the same day the old tub got picked up
post #5 of 35 Old 03-27-2013, 04:51 PM Thread Starter
GPERSCREEPERS99
Tub put on for the first time
Starting to come back together
This is where I am now. I obviously left out a million pictures or forgot to take them like the fixing the body mounts stripping the frame a second time to redo it again since I wasn't happy with it but I wanted this thread to be more about the build since putting the Aluminum tub on since all of the work I did previously has been over the last year and a half. I have had some big breaks working and had to make tough decisions on replacing the original tub and spending what seems to be a never ending amount of money the last 2 months. At this point I'm about 3k over my original budget and probably have 5k or more to go. Definitely won't recoup the money but I don't ever plan on selling so it doesn't matter.
post #6 of 35 Old 03-27-2013, 04:59 PM Thread Starter
GPERSCREEPERS99
Some basic Jeep specs
Chevy 350, Dana 300 Twinstick, 350 trans
Ford 9 inch w/limited slip
Dana 30 it will have a Eaton Elocker and 4.10s once I install them soon.
Aqualu Industries CJ8 Tub
Re 4.5
JKS 1.25 Body Lift
Will most likely roll on 35s maybe bigger but currently on 33's
Once I get all the body parts on and mock it up I will take all the steel off and blast paint and prime it. My plan for now is to Polish the tub and paint the hood fenders windshield frame doors silver but I am considering painting the entire thing too. Not really a "chrome" guy but I've seen some really cool polished aluminum Jeeps. It would definitely be cheaper to polish it then paint it. Will see when I get closer to that stage in the next few months.
I will have both the half cab hardtop and a full soft top and seating for 6.
post #7 of 35 Old 03-27-2013, 06:05 PM
RoostrRiz
Nice job so far!!
RoostrRiz is offline
post #8 of 35 Old 03-27-2013, 06:37 PM
mirage100
1976 CJ7
How do you like the body? Was it a good fit?
mirage100 is offline
post #9 of 35 Old 03-27-2013, 08:33 PM
IowaJoe
1979 CJ7
sooo jealous. looks great so far
IowaJoe is offline
post #10 of 35 Old 03-27-2013, 08:37 PM
Galt
Galt's Avatar
1983 CJ7
Looking nice.
A=A
1983 CJ7 304 V8
1985 CJ7 258 I6
1993 RX7 1.3L Rotary/ GT40R turbo/484 rwhp
2002 F-150 Lariat 5.4L V8
2007 GMC Yukon Denali 6.2L V8
Galt is offline
post #11 of 35 Old 03-27-2013, 08:49 PM Thread Starter
GPERSCREEPERS99
Thanks!
So far the body seems perfect. I had and still have a ton of holes to drill but if anyone is looking to buy a new tub and don't care if its 100 percent original these aluminum tubs are a far superior product quality wise. The aluminum is much thicker than the steel and seems much more substantial.
post #12 of 35 Old 03-27-2013, 08:53 PM
OleBlue73
1973 CJ5
I'm looking to go this route one day with my 73 '5 to get rid of those wood-filled hat channel floor supports that hold moisture and rot from the inside out. I'm following along.
Personally, I'd prep and paint the aluminum instead of polishing it and trying to match the fenders and hood with silver paint.
1973 CJ5, 304, T15, D20
2009 JKU, Rubicon
2005 TJ, X, 4.0, 6 speed
OleBlue73 is offline
post #13 of 35 Old 03-29-2013, 08:47 AM Thread Starter
GPERSCREEPERS99
Well not a ton of progress yesterday but I did get all the holes drilled and bolted the fenders on and drilled and installed the hood. Its so scary drilling into my brand new aluminum tub. Got check and recheck a hundred times before you can do it.
The aftermarket Hood and fender fits but its just a tad off and that drives me nuts. I just couldn't wait any longer to find a good hood and fender here in the rust belt.
Couple pics
I did find a few problems yesterday. I need to remove the lip on the edges of the dashboard as the don't quite fit the new tub and I discovered this Jeep sits really high and due to the height and the garage door I'm not sure if I can fit anything larger than 33's so I'm probably going to pull the JKS body lift. I'll see what happens when I get the windshield frame on which is next.
post #14 of 35 Old 03-29-2013, 10:37 AM
Trapshooter
Great stuff!! Keep up the good work.
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #15 of 35 Old 04-01-2013, 09:40 AM Thread Starter
GPERSCREEPERS99
This weekends progress...Got the windshield on. I know its not much progress but laying it out and drilling the holes in the tub to bolt it down is one of those thing you need to check a 1000 times before you drill.
