Altitude Wire - JeepForum.com
post #1 of 2 Old 04-17-2002, 03:20 PM Thread Starter
CJ8DV8
Post Altitude Wire
Hi Gang-
What exactly does the Altitude wire on my CJ do? I've read that you ground the wire to the engine block when you ride in elevations of 4,000 ft above sea level, but what gets adjusted or changed as a result? Timing? BBD Carb?
Funny thing is that when I put the wiring harness in my Jeep I originally grounded this wire by mistake. I thought it was just another ground. My house is only 50' above sea level, but the engine ran great anyway. Anyone know?
Black '83 CJ8
258 I-6
Auto
Half hardtop
Rustproof plywood floorboards and bed upgrade.
Lots of work, but working on it.
CJ8DV8 is offline
post #2 of 2 Old 04-17-2002, 07:56 PM
SamFromCO
SamFromCO's Avatar
Post
Info here.
<a href="http://www.off-road.com/jeep/tech/258bbd/altitude.htm" target="_blank">http://www.off-road.com/jeep/tech/258bbd/altitude.htm</a>
'86 CJ7, 258 w/Mopar MPI, 4.56 gears, rear Detroit/front Truetrac, full cage, OBA, 8274, 4" lift via Alcans/Rancho, 35's on beadlocks, other stuff. Built for rocks, mud is a four letter word.
SamFromCO is offline
Altitude Rejetting cs1094 Jeep CJ Forum 3 01-13-2009 12:54 PM
Density Altitude jayhawkclint Jeep CJ Forum 8 02-10-2008 08:28 PM
Howell kit & high altitude John N Jeep CJ Forum 2 07-17-2006 03:33 PM
high altitude tgbrannon Jeep CJ Forum 1 01-27-2006 05:35 PM
altitude adjustment rightsidedown Jeep CJ Forum 1 01-23-2004 08:04 AM
