Alternator Wires? - JeepForum.com
post #1 of 4 Old 08-27-2013, 09:34 AM Thread Starter
70worm
1977 CJ5
Alternator Wires?
Can someone post a pic of the back of their stock external voltage regulator alternator so I can hook up the 2 small wires to the right posts. I've seen this asked a lot on the net but no pics.
Thank You.
77 304
Here's what I got.
70worm is offline
post #2 of 4 Old 08-27-2013, 10:08 AM
WindKnot
1977 CJ7
How about the Electrical Section of the FSM instead? 77 was the same as 76.
http://oljeep.com/gw/76_tsm/Section3.pdf
I think what you want is in Figure 3-6
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #3 of 4 Old 08-27-2013, 10:12 AM
superj
the red wire will only slip over the small post. its push on. the orange one should use a nut to hold the wire on
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #4 of 4 Old 08-27-2013, 10:56 AM Thread Starter
70worm
1977 CJ5
It helps some. So I guess this other wire with the 90* elbow must go someplace else.
So the alt only has 2 wires instead of 3? This is why a pic would help, so I can see exactly what should be hooked up working alt, on a running engine.
70worm is offline
