Alternator and Power Steering Brackets Chevy 350 Conversion - JeepForum.com
post #1 of 9 Old 11-19-2013, 09:09 AM Thread Starter
qualitycoast
1979 CJ5
Does anyone know of the best fit for alternator and power steering pump bracket and belts configurations for a 92 chevy 350 in a 79 CJ5? The engine came with the air conditioning pump and a serpentine belt. I don't want to use the air conditioning and want to configure the alternator and power steering. Any info would be greatly appreciated.
qualitycoast is offline
post #2 of 9 Old 11-19-2013, 09:30 AM
LumpyGrits
Turn that AC compressor into a air-compressor.
Sorry, can't help with the other issue.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #3 of 9 Old 11-19-2013, 09:35 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
Run a piece of small diameter rope around your pulleys to determine the length of belt you need.
Any parts store should be able to dig one out of there stock to match.
2Xtreme is offline
post #4 of 9 Old 11-19-2013, 10:38 AM
lucdog
lucdog's Avatar
1980 CJ5
With the serp belt on the 350 a pulley can be bought to replace the AC compressor. Sorry, i dont remember where i got mine. Everything else on the 350 will work, the hi pressure power steering line needs to match your pump, either a flare fitting or the "O" ring style.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #5 of 9 Old 11-19-2013, 10:41 AM
CSP
Why aren't you using the stock Chevy pieces? That seems to be the obvious answer, but maybe there's something I'm missing.
CSP is offline
post #6 of 9 Old 11-19-2013, 10:56 AM
lucdog
lucdog's Avatar
1980 CJ5
If I'm not mistaken it came from a local parts store.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #7 of 9 Old 11-19-2013, 12:23 PM
Speedy94c
1977 CJ5
You need a idler pulley off of a 88-94 chevy truck w/o a/c. I have used this on other things before. V-6 or V-8 will work. It goes where the a/c compressor was originally.
Speedy94c is offline
post #8 of 9 Old 11-19-2013, 12:24 PM
dg6772
Parts Plus carries the pulley you seek.
I have the same setup and am looking into making mine into a compressor. At this point I'm not sure if it's worth the effort or not. I'm going to compare the output rate vs. an electric compressor plus the conversion cost......
Dave in Muskegon
dg6772 is offline
post #9 of 9 Old 11-19-2013, 05:42 PM Thread Starter
qualitycoast
1979 CJ5
Thanks for the quick replies you guys. Great community.
350 conversion , alternator , power steering conversion
