alternator bracket - JeepForum.com
post #1 of 10 Old 01-15-2007, 11:32 AM Thread Starter
LSUtiger
1980 CJ5
alternator bracket
what does the original bracket look like for a 1980 cj5 304. The one I have now is some welded stuff that works but it is not right and it is in the way of the p/s upgrade. Also where can I find the correct bracket. I see them on ebay but they all look different. Is there a difference in year models? There is a 1983 waggy 360 bracket for sale. Shouldn't this work? If anyone can post a pic that would be great.
LSUtiger is offline
post #2 of 10 Old 01-15-2007, 03:06 PM Thread Starter
LSUtiger
1980 CJ5
I guess what I need to know is if the bracket is 1 piece or if it has a couple of brackets. Shouldn't a 360 waggy bracket fit?
LSUtiger is offline
post #3 of 10 Old 01-15-2007, 04:45 PM
1979CJ7
1979CJ7's Avatar
1979 CJ7
the bracket outta my 7 had a few pieces to it. i think it was like a totaly of 3 or 4. im not certain. i dont know about the waggy one either. i would think it would fit. just make sure its in the same spot and i would htink it might work.
1979CJ7 is offline
post #4 of 10 Old 01-20-2007, 05:47 PM
GAchoptop
GAchoptop's Avatar
1977 CJ7
My trail jeep is a chopped Wag w/ a 360 and I'm currently rebuilding a 77 CJ7 w/304 and needed the alt brackets and the one from the Wag 360 worked fine picked it up at pullapart. Compared to the Chop first and all pieces looked the same.
GAchoptop is offline
post #5 of 10 Old 01-21-2007, 09:52 AM
hfjeff
hfjeff's Avatar
It depends whether you have A/C or no A/C. The brackets are different. If you have no A/C, then those brackets are getting difficult to find. Most Waggies had A/C. I do not have any good pictures of them.
MINE: 1995 YJ/2.5L/115K/Completely Stock
MY DAD's: 1978 CJ7/ AMC 360 .030" over/ Motorcraft 2100/ Edelbrock Performer/ Proform HEI Ignition/ Hedman Headers with dual Flowmaster 40's/ Taurus Fan/ FK-35 Control/ Painless Harness/ Rebuilt T150 & Dana 20/ 4" Lift/ 31" Procomp Mud Terrains/ All Fiberglass. (SOLD)
MY BROTHER's: 1996 ZJ Limited/5.2L/117K & Completely Stock.(SOLD)
hfjeff is offline
post #6 of 10 Old 01-21-2007, 10:19 AM
John N
1981 CJ8
The ones off of a Waggy V-8 will work, but you should get all of the accessory brackets (p/s too) and pullys. Use them as a set so that everything alines and the belts will be a stock application. Get the attaching bolts, too, some are long or odd stuff. A/C won't matter on most I've seen, a separate belt went from the alt to the a/c compressor.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #7 of 10 Old 01-21-2007, 02:06 PM
kappa505
1980 CJ5
On my 80' CJ5 304 the alternator bracket is simply a flat c shaped piece of metal with a slit through the middle long ways that would allow for adjusting the belt tension. This bracket was for the bottom mounting bolt on the alternator and would bolt to the engine block. The top bolt of the alternator used a spacer sleeve to make it square with the bottom and screwed into the block. It is mounted on the passenger side of the engine.
kappa505 is offline
post #8 of 10 Old 01-21-2007, 05:14 PM
fuzz401
1978 CJ7
there are 2 style of brackets a c shaped on and the multi pc one this is the multi on
the only diff between the AC one and the non AC one is the spacer is longer and the plate to w/p is bigger
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #9 of 10 Old 01-22-2007, 02:44 PM Thread Starter
LSUtiger
1980 CJ5
thanks for the help. I think that I found one that is off a 304 w/o ac. It is the c bracket style. Hopefully, this will solve my problem. Once again thanks for all the great info. and pics.
LSUtiger is offline
post #10 of 10 Old 05-13-2010, 08:23 PM
kidashley25
do you have any picture of your bracket. if you want some OEM parts try to look at the parts bin. or try some proform alternator bracket
kidashley25 is offline
Where to buy Alternator Bracket for 304? Rupie25 Jeep CJ Forum 6 11-30-2009 12:07 PM
AMC 360 Alternator Bracket blackbirdxx Jeep CJ Forum 8 02-23-2009 06:36 AM
alternator bracket help... ndigilio3 Jeep CJ Forum 8 05-23-2008 03:15 PM
Need help with 258 Alternator Bracket Seether Jeep CJ Forum 4 08-22-2007 08:36 AM
Alternator Bracket mt_2000_1 Jeep CJ Forum 4 02-07-2007 09:21 PM
