| Support JF - Equipment Drive and Future Downtime |
| Register | FAQ | Mark Forums Read | Search Members |
LinkBack | Thread Tools |
| #16 | ||||||||
Web Wheeler Join Date: Aug 2007 Location: South West Indiana Posts: 5,341 |
__________________ REMEMBER, Information gathered for free on the internet is worth EXACTLY what you paid for it! ----------------- I used to be 'TeamRush', but I'm much better with medication.... | |||||||
| #17 | |
Registered User Join Date: Nov 2007 Location: lake havasu city, az Posts: 11 | thanks for helping out so much.. i do not have the alt. in the 1st picture i have the Prestolite alt. from the 2nd picture... i will go take it back and get the 10si and get out the hacksaw.. so the only mod i will have to do to get it to fit in the Prestolite/Motorola bracket is just trim the big foot down? sorry for asking so much just dont want to hack that one up and not be able to take it back if it wont work... as for upgrading the wire ill get some of that welding cable, do you think running that big of wire to the alt is just overkill? and again which of these wires need to be fused? i have no idea how to solder, would crimping it work or should the really be soldered. the headlights are really dim barely working i have seen some threads on building a new wiring harness for the headlights with relays built in, do you know a good thread how to on this? the brake lights are also not working the running lights are on correctly and the blinkers work just when you brake the lights dont change any the running lights just stay on... any idea on where to start there?? sorry for all the questions just trying to get this thing reliable and legal |
| #18 | |||||||
Web Wheeler Join Date: Aug 2007 Location: South West Indiana Posts: 5,341 | Quote:
Delco 10 SI alternators grow on trees, and they are EASY to find. Practice on a 'Junk' or 'Core' alternator from a junk yard first. If you don't have junk yards locally, find someone with old GM vehicles sitting around a buy a core from them to practice on. Remember, the front frame (the front housing) of those 10 SI alts are interchangeable. If you get one JUST the way you like it, you can always swap it onto the discount store alternator... Quote:
Alternator gets 10 gauge wire, not welding cable. Anything over about 75 amps needs 8 gauge wire. Quote:
Fusible links (fuse wire, available from NAPA) are clearly marked in the diagrams and list sizes for what run of wire. Solder is easy, and this is a good time to learn. Much better to solder the connections than to have moisture creep into the joints and rot them out where you can't see the corrosion. Radio Shack has a excellent solder for beginners (and for anyone working with anything less than about 8 gauge wire) Very good flow into the joints, excellent conductor, and works well to seal connections. It's very fine and very easy to control. http://www.radioshack.com/product/index.jsp?productId=2062717&cp=&sr=1&origkw=solder &kw=solder&parentPage=search Radio Shack p/n 64-013 Quote:
You get the alternator working and I'll draw you up a head light relay harness, but you WILL have to solder for that one! Quote:
I don't wire for kids or guys that want to keep things stock... I wire to get things working and keep things working! __________________ REMEMBER, Information gathered for free on the internet is worth EXACTLY what you paid for it! ----------------- I used to be 'TeamRush', but I'm much better with medication.... | ||||||
| #19 | |
Registered User Join Date: Nov 2007 Location: lake havasu city, az Posts: 11 | alright thanks alot ill get that alt. working and get a picture of it my g/f has been on vacation *with her camera* so ill get it before i start cutting one up also do i want to crimp and solder or just solder? |
| #20 | ||
Under the dash, you can get away with just crimping those terminals, they don't see moisture a lot. In the engine bay, you should take the appropriate measures to keep mud, water, salt, sand and what ever else you drive on out of your connections. On battery cables, I crimp, solder with silver bearing solder, and use heat shrink. Remember, the guys at NAPA will show you how to use all this stuff if you get it there. (Battery cable size terminals take a special crimper, and when you get your cables cut to size, NAPA will crimp them for free if you buy your stuff there) Heat gun from Harbor Freight or Sears is about $20 and works great for heat shrink tubing. Once you learn to use heat shrink, and what kind of heat shrink to use (Rubberized with glue) you won't use electrical tape again. I bet I don't use a roll of electrical tape a year anymore... There are good quality smaller terminals that have the solder already in them. You crimp, then use a heat gun. Again, NAPA can direct you to the correct terminals. I would also use heat shrink with these. REMEMBER, just because the terminal came with a plastic insulator, doesn't mean you have to leave it on there to crack and fall off later! I give the plastic a little heat, then pull it off with pliers so my Heat Shrink makes a good looking, as well as solidly insulated connection. __________________ REMEMBER, Information gathered for free on the internet is worth EXACTLY what you paid for it! ----------------- I used to be 'TeamRush', but I'm much better with medication.... | |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Battery or Alternator - Who's gone bad? | Alpha Pup | CJ Technical Forum | 20 | 10-05-2008 03:00 PM |
| New alternator or battery? | SuB8HaVeN | CJ Technical Forum | 5 | 06-04-2008 10:35 AM |
| Electrical/Battery/Alternator Issue | hoezaycuervo | CJ Technical Forum | 9 | 02-11-2008 09:33 AM |
| Alternator keeps frying / Battery Draw Problem | Jeepnstein | CJ Technical Forum | 11 | 07-07-2006 04:15 PM |
| Alternator upgrade/dual battery | CJmadison | CJ Technical Forum | 1 | 02-10-2006 08:03 AM |
Previous Thread
Next Thread
