Alternator acting up - JeepForum.com
post #1 of 7 Old 01-02-2014, 07:01 AM Thread Starter
highred
1979 CJ7
I put a new alternator in last summer. I couldn't tell you what size. It's what the kid at the parts store said the computer told him for a '79 CJ7. I'm not running any additional electric except for an alpine stereo with a 40 w amp. All of the lighting is LED.
I drive the Jeep daily and The problem I'm having is that the volt meter is around 10 when I start it up in the morning. It slowly builds up to 13 or 14 after 15 minutes or so, then starts spiking with the needle going completely off chart. Over 16. The lights get bright (head lights are not LED, everything else is), then go dim with the needle dropping to 12 or so.
So I'm not sure if this is the alternator or the battery, or something in between.
Any thoughts?
highred is offline
post #2 of 7 Old 01-02-2014, 07:36 AM
JeepHammer
Running On Empty...
1973 CJ5
Sounds like a bad voltage regulator.
This *CAN* Happen if the regulator isn't getting a good 'Ground' back to the battery, but that's unusual.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #3 of 7 Old 01-02-2014, 08:07 AM
EgulAye
1980 CJ5
It sounds to me like the voltage regulator is not working properly, or something in that circuit (sense wire). I've seen quite a few discussions here on the forum about properly connecting the alternator and also on testing the circuits to determine where a problem lies. Good luck.
2012 JK
Do you wave at night when they can't see you?
EgulAye is offline
post #4 of 7 Old 01-02-2014, 08:29 AM Thread Starter
highred
1979 CJ7
Where's the voltage regulator? Is it in the Alternator? I have an HEI ignition which allowed me to remove the ignition box. So right now, my alternator is wired to the solenoid and battery. Pretty straight forward.
highred is offline
post #5 of 7 Old 01-02-2014, 08:34 AM
JeepHammer
Running On Empty...
1973 CJ5
'79, you have the standard Delco SI series alternator. It's built into the alternator.
Two wire plug in the side of the alternator, a bigger wire on the back of the alternator.
Pretty common stuff.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #6 of 7 Old 01-02-2014, 12:39 PM
86cj74.2L
86cj74.2L's Avatar
Do you have a wire going from your negative post of your battery to both the engine block and a smaller wire going to the body beside the battery? Or just 1 wire to the block?
86cj74.2L is offline
post #7 of 7 Old 01-02-2014, 04:22 PM Thread Starter
highred
1979 CJ7
Both block and body are grounded.
highred is offline
