Alternatives to carrying a spare tire? - Page 2 - JeepForum.com
post #16 of 28 Old 04-23-2013, 08:03 PM
lucdog
lucdog's Avatar
1980 CJ5
I maybe should have added that both my trail Jeeps have bias ply tires. When I've compared my IROC's to my buddy's radial IROC's there is a difference in sidewall thickness. I run 4 psi in mine with beadlocks, he doesn't go below 8 psi. :-), with 0 psi in the front tire on my 5, the rim is still 4" from the road/trail surface.
Front and rear lockers also play a roll in this. Where someone with open diffs will try to avoid a large sharp rock, and slid into the side of it, I would drive over it.
No spare in my opinion is partially driven by who you wheel with, any of the club members in my group wouldn't hesitate to drive 20 miles on or off road to get the spare for another member if needed. I sat on a trail for 2 hours 2 years ago after removing the ignition module from the HEI, so another member could drive his J truck off a extreme trail, (Wa&hita) without needing to tow and winch.
Matt, I've Jeeped in the Black Hills in S.D. I've never seen rocks as sharp as these. Google or search youtube for "Fruity pebbles" For one of the trails. It's close to same in Southern Missouri.
OP, sorry about the kind of off topic, sometimes I get carried away. I get excited about taking my Jeeps on the trails.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #17 of 28 Old 04-23-2013, 08:35 PM Thread Starter
Manhattan
1981 CJ8
No sweat on the "thread creep".
And to be clear - I would not hit the trail without a spare - I'd only consider running without a spare on the street - and local at that.
1981 CJ8, Chevy 5.7, SM465, D300, RE 4.5, 35" BFG MTs, 20/30 4.56, Detroits, Warn 9500ti
Manhattan is offline
post #18 of 28 Old 04-23-2013, 08:55 PM
S76
Thanks for the topic. Good to hear others opinions.
As of now I am planning not to carry a spare when driving local on the tar. Plugs, fix a flat, and a little compressor should get me home. Any trail riding in this area keeps you within walking distance to get out of the woods.
Plus I can always call my son to fetch me.
If you always do what you've always done. You will always get what you've always got.
S76 is offline
post #19 of 28 Old 04-23-2013, 09:07 PM
yahwhy
1982 CJ7
You should just hire a tow truck to follow you around, maybe the same one you had to haul your jeep in to get the brakes bled.
yahwhy is offline
post #20 of 28 Old 04-23-2013, 09:12 PM
lucdog
lucdog's Avatar
1980 CJ5
Funny how things are different, my DD CJ gets me to work, I wouldn't think about not having a spare tire on it.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #21 of 28 Old 04-24-2013, 12:03 AM
Dngrs1
1979 CJ7
If you have a spare (5th tire), you can rotate them around periodically and actually increase the time before you have to buy new tires. (What a concept).
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #22 of 28 Old 04-24-2013, 07:05 AM
CJ7ROB
Try to avoid using Fix-a-Flat if possible. Both tire places I go to say it can rust the insides of steel rims if you leave it in there long enough and throws the tire off balance, especially if its up front. I had a steel rim rusted bad on the inside from the PO using Fix-a-Flat. Its ok for an emergency situation to get you home, but better if you just have a spare to swap out.
CJ7ROB is offline
post #23 of 28 Old 04-24-2013, 10:06 AM Thread Starter
Manhattan
1981 CJ8
Still bent out of shape about my comment about you putting Warn stickers on your Chinese winch huh
post #24 of 28 Old 04-24-2013, 07:10 PM
yahwhy
1982 CJ7
Not at all, you ask for an alternative to carrying a spare tire, and I gave you one. It may not be cheap, but with the looks of your rig, money is not one of your short comings, unlike me, with limited funds you get what you can afford at the time.
yahwhy is offline
post #25 of 28 Old 04-24-2013, 09:18 PM
fourbtgait
1930 MK Patriot
Ive always carried a full size spare no matter the vehicle. I was up cutting firewood in the mountains of Montana, 10 ply Toyo Open Country, sliced the sidewall of the tire on a rock just twice the size as my fist on a well maintained forest service road. No cell service, no CB, nobody around for 20 miles. Cost of a cord of wood just jumped up.
The CJ7 only has 2 ply sidewalls, wanted 3 ply but also didnt want the extra weight of each tire.
fourbtgait is offline
post #26 of 28 Old 04-25-2013, 11:17 AM
Mlaughlin8
1980 CJ5
I have to say that I would rather have it and not need it, than need the spare and not have it! That just seems to be my luck usually!!!
Mlaughlin8 is offline
post #27 of 28 Old 04-25-2013, 11:45 AM
Rattyflatty
1948 CJ2A
I'm with the "have a spare tire along crowd". Being that I don't get to go wheeling that often, a gashed tire really puts a damper on quality wheeling time with no spare on board. I do also carry a plug kit and have a York compressor on my ride.
I don't know what you load into the rear of the CJ8 but have you though about rearranging your stuff to bring the spare inside the body? I done this years ago on my flatty vs swing out on the bumper and loved it. Mind you I had 35" on steel,10 gal fuel,high lift,4 way wrench and an ax on it.
Tonight we drink for tomorrow we shoot bang bang
Rattyflatty is offline
post #28 of 28 Old 04-27-2013, 01:32 PM
Iceman_RNR
usually I carry a spare on the trails as well as the street. On the trails I might not in case we need the back seat and/or the spare is close by in camp and easy to get in case the plugs and OBA won't get the job done. But we've even plugged tires with 2" gashes on the trail (no sewing with bailing wire or anything) and were able to drive them out ...
Never used the Slime stuff and never will ...
Just get good plugs and practice
'84 CJ7, '96 CTD, '00 TJ
Iceman_RNR is offline
