Alternatives to carrying a spare tire? - JeepForum.com
post #1 of 28 Old 04-23-2013, 02:29 PM Thread Starter
Manhattan
1981 CJ8
I've always been a fan of carrying a spare - the same size as the other 4 tires. But I'm beginning to question that. My CJ currently spends all of its time on the street, and when I finally do get it ready for the trail (couple small issues), it'll still spend most of its life on the street.
Tires don't seem to flat like they used to - credit the advancements in tire technology I guess. And, with 35" MTs, the cut side wall is even less of an issue. I just keep thinking about that 100lb 3' obstruction back there... rattling, blocking my vision, making it a (small) hassle to get things in/out of the bed... and thinking of options like a plug kit and compressor (used that a few times - on other people's cars).
Anyone done that - ditched the spare for a plug kit and compressor?
It'd also make it easier to carry bikes and gear - the receiver hitch, access, etc. I'd definitely use the spare for anything off-road.
Thoughts?
Thanks.
1981 CJ8, Chevy 5.7, SM465, D300, RE 4.5, 35" BFG MTs, 20/30 4.56, Detroits, Warn 9500ti
Manhattan is offline
post #2 of 28 Old 04-23-2013, 02:36 PM
Jeffro06
Jeffro06's Avatar
Personally I like having a spare. It's probably more of a personal choice. There are pro's and con's to each. I'd rather not get stuck on the side of the road, at night or in bad weather fighting with a plug and compressor. While on the trail I like the peace of mind of having a spare, as you never know what could happen there.
Jeffro06 is offline
post #3 of 28 Old 04-23-2013, 02:39 PM
JeePete
1983 CJ7
"Anyone done that - ditched the spare for a plug kit and compressor?"
And a can of fix a flat, in case you can't find the "object" that poked the tire.
The bigger wheels tend to have leverage and bounce (twist) the carrier.
So, yeah, I'd do it.
JeePete is offline
post #4 of 28 Old 04-23-2013, 02:43 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I detach my tire carrier from the bumper and run it for a total of five months throughout the year. If its an upcoming wheeling trip, I like to have a spare in case I lose a bead with the km2's but other than that, its coming off. I have AAA and cell service everywhere else not to mention a plug and seal kit and OBA if need be.
Luck Favours The Prepared
Anticanman is offline
post #5 of 28 Old 04-23-2013, 03:11 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Manhattan,
If I had your roll bar, and I didn't run a top, I'd look into mounting the spare on the angled portion at the rear of the cage.
I think you could get it high enough to not block your rear view.
Just a thought,
Matt
Matt1981CJ7 is offline
post #6 of 28 Old 04-23-2013, 04:10 PM
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by Matt1981CJ7
Manhattan,
Just a thought,
Matt
I wouldn't want to do this, it raises the COG.
To answer the original question . I carry a spare on my DD CJ.
On the trails I don't, of the group I wheel with, 1 out of 10 carries a spare. This is usually the Jeeper who drives his/her Jeep on the trip.
10 out of 10 of the non spare carriers have a spare, but it stays on the trailer. These same people also have OBA, a plug kit, and I also have a can of fix-a-flat, and spare valve stems.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #7 of 28 Old 04-23-2013, 04:27 PM
243
1978 FSJ Cherokee
I have not bought my spare but I too am questioning the need for a matching BFG KM2, a tall skinny radial would serve the purpose, be lighter, cheaper and I can put a spare tire cover on it. I have carried a Safety Seal plug kit since 2000 but I would not want to rely on it; on the other hand, I don't remember changing a flat since 2000 either.
I used to keep the offending artifacts but the box was getting hard to close so I chunked them and started over, right now I have 1/3 of a utility knife blade and a drywall screw from tires repaired in the last six months.
I was on a state draw hunt in San Angelo and returned to my Dodge to find a 3/8" lag bolt in the sidewall of my MT and losing air, I put two or three plugs in it and drove it almost a year before I replaced the tire.
Worth every penny and more.
Dave's 78 Build
243 is offline
post #8 of 28 Old 04-23-2013, 04:53 PM
skizriz
1978 CJ7
Here's a picture of a guys tire from Sunday. No spare, a few miles back in the woods, nobody to bail him out with a spare, all because he wasn't prepared. Luckily we had plugs and on board air.
Don't know how he drove it home, or even if he did.
I personally wouldn't want to be "that guy" that is that unprepared that I don't even have the most basic of needs when I go into the woods.
Throw a receiver on the front to carry the bikes.
skizriz is offline
post #9 of 28 Old 04-23-2013, 05:00 PM
Matt1981CJ7
1981 CJ7
I'm with skizriz on this one. i wouldn't run without a spare. Sidewall tears don't plug easily.
Matt
post #10 of 28 Old 04-23-2013, 05:12 PM
Matt1981CJ7
1981 CJ7
Bill
Well, yes, I suppose it would raise the COG...about as much as an average-sized passenger standing up in the back.
It rarely happens, Bill, but I have to disagree with you on this one. Having the spare on the cage wouldn't increase the COG any more than, say, a hardtop.
If Manhattan plans on putting this rig in situations where that little bit of COG will make a difference, then my hat's off to him.
Matt
post #11 of 28 Old 04-23-2013, 05:16 PM
243
1978 FSJ Cherokee
Matt,
In this case, I believe the spare would completely block out the view if mounted on that angled part of the roll bar.
Mounted on the top above the passengers are would look better and be completely out of the way.
OTOH, Manhattan is not asking about re-mounting a spare.
Dave's 78 Build
243 is offline
post #12 of 28 Old 04-23-2013, 05:41 PM
Matt1981CJ7
1981 CJ7
Originally Posted by 243 View Post
Matt,
Fair enough. I offered an opinion. Manhattan is free to ignore it, or not.
I will say, of the 3 tires i've blown in off-road situations, no amount of plugging would have repaired them. Fortunately, I had a spare in each case.
Of course, it depends on where you wheel. I'm not wheeling on 80-grit Moab rock, or muddy mid-western timbered trails. Some of the crap I roll over is rocky, sharp shale, or granite, that will slice a side-wall in a hurry.
Matt
post #13 of 28 Old 04-23-2013, 06:01 PM
243
1978 FSJ Cherokee
I am not griping at ya Matt
Dave's 78 Build
243 is offline
post #14 of 28 Old 04-23-2013, 07:12 PM
HALOjmpr
You want what, when?
HALOjmpr's Avatar
1982 CJ7
My doctor told me I have no alternative and I need to eat less and exercise to quit carrying my spare ...... man he's a downer.
In DD and wheeling I've needed spares so it would be hard to get me to go without one. I have AAA too but even on remote highways those guys can be 3+ hours out when I could be rolling again in 20 minutes or less.
The AAA is really more for my wife when I'm not around
"It's not about how hard you can hit, it's about how hard you can get hit and keep moving forward!"
HALOjmpr is offline
post #15 of 28 Old 04-23-2013, 07:34 PM
skizriz
1978 CJ7
It almost three years and 20,000 miles I haven't needed my spare yet. But I will always have it WHEN needed.
I could probably run on flat tires. I drove home about two miles Sunday with 8 psi in all four tires. Other than it riding better, I couldn't even tell a difference.
I know about two hours were wasted Sunday dealing with what should have been a 15 minute tire change. Kind of a bummer for others involved.
skizriz is offline
