Alpine Lizard Build Project - Page 8 - JeepForum.com
 122Likes
post #106 of 5595 Old 07-25-2012, 10:26 AM
8pitcher
8pitcher's Avatar
Originally Posted by Dadamsnv
I got the oil pan put back in last night, I'ts been off for about 2 weeks now
I don't think it will be on there long though. I'm pretty sure I botched the pan gasket install. I got a little heavy handed with the wrench and a corner of the gasket blew out and cracked. I'd just pull it back out tonight and redo it, but I used a ton of silicon sealer on the pan gasket, and I'm hoping the insides and the four corners held up and sealed. Time will tell, and its only a minor hassle to redo it, so whatever happens happens.
On the plus side. The black painted pan bots and the AMC metallic blue pan look fabulous under the rig! Maybe even too nice
Its strange looking at the pan color under sunlight versus under LED camera flash, Its a totally different color.
It looks so much bluer under the hood. And I like the black bolts too.
8pitcher is offline
post #107 of 5595 Old 07-25-2012, 10:31 AM Thread Starter
Dadamsnv
1977 CJ5
Thanks I thought painting the bolts black would be a cool idea, plus the cardboard box helps organize them. I like under the hood blue better I think
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #108 of 5595 Old 07-25-2012, 10:36 AM
8pitcher
8pitcher's Avatar
Ya I do too. When it was just hanging I thought it looked more turquoiseish
8pitcher is offline
post #109 of 5595 Old 07-27-2012, 10:19 AM Thread Starter
Dadamsnv
1977 CJ5
Looks really good. I wish I could do that. I bought my engine stand for $20. Do you have a spare harmonic balancer? Just asking because you said that you got one with the long block.
Nice find on the engine stand
As far as the harmonic balancer goes, I'm not sure what ill do with the one he gave me. It's still attached to the long block at the moment. I'll probably keep it with the long block, and my extra would be the one I'm currently using, so in a few months I'll have a spare
Dadamsnv is offline
post #110 of 5595 Old 07-27-2012, 10:24 AM Thread Starter
Dadamsnv
1977 CJ5
I sold my old YZ 125 yesterday, and I got $850 out of the deal. Not bad for booking for $1000 but having blown fork seals and a super dented expansion chamber. I'll miss it, but I have more garage space now, and a little jingle. I still have two other dirt bikes to keep me company anyway.
Dadamsnv is offline
post #111 of 5595 Old 07-27-2012, 10:32 AM
8pitcher
8pitcher's Avatar
YZs are so much fun. I had an 83 YZ 80 but I blew a ring. Then I sold the bad engine for 200. Which is how much I bought it for. What kind of other dirt bikes do you have.
8pitcher is offline
post #112 of 5595 Old 07-27-2012, 10:33 AM
8pitcher
8pitcher's Avatar
I might take that off your hands when your ready to sell it.
8pitcher is offline
post #113 of 5595 Old 07-27-2012, 10:39 AM Thread Starter
Dadamsnv
1977 CJ5
The last few nights I've been trying to kick some serious *** on the jeep. On Wednesday, I put the flywheel, clutch, bellhousing, clutch linkage, transmission, and tcase on. I was super exhausted. But the clean, painted drivetrain and the black bolts look awesome! I'll post pics when its all done.
One bad thing, a flywheel to crank bolt was stripped It only held 60 ft lb or so before it went, and the worst part it its the treads on the crank that are bad. Oh well, I have five other bolts. Its pretty frustrating to have that happen, PO must have impacted them on at some point. I left the bolt in as tight as I could for balance, but its for show now.
Last night didn't go any better, the PO used a home made aluminum block adapter to lift the torque arm off the advance adapters t18 to d20 adapter so the torque arm wouldn't hit the tranny. This added another inch to the tcase drop kit though, and it looked stupid. So I grinded the heck out of the torque arm and tranny mount to make it fit without the homemade adapter. It was a little upsetting grinding on my beautiful new prothane tranny mount, but whatever. When I went to bolt everything up, I found another stripped set of threads in the t18 to d20 adapter. ARRRGH!! So I drilled it out and tapped it to 1/2" x 13, and I'll buy a bolt for it tonight on my way home.
I was still able to do a test fit on the skid plate, and, of course, the holes didn't line up at all without that dumb homemade adapter (I'm beginning to see why it was there), but I really want that extra inch of ground clearance. After that bit of new I quit for the evening, I will drill a couple new holes in the skid tonight, and hopefully be off the the races.
Once the tranny mount and skid are in place, I can heat up and bend my JB fab twin sticks into the right place. Right now they run right into the t18 shift pattern
Pic one is the tranny all set up to be pulled up into place through the tranny cover in the body
Pic two and three detail all the grinding and fitment the torque arm and tranny mount needed
Dadamsnv is offline
post #114 of 5595 Old 07-27-2012, 10:51 AM Thread Starter
Dadamsnv
1977 CJ5
Its true, YZs are the best two stroke race bikes. I really loved the 125, but I've moved on the something much more beastly.
Here is my RMZ 450. It was my resto project before the jeep. I blew the motor on it. Somebody before me lost some plastic in the case, and it eventually melted on the clutch on a snowy trailride (lots of clutch action) and clogged up the strainer which cut all the oil off going to the heads, and BOOM.
So I frame offed it and this is what she looks like today. Don't let the appearance fool you, I ride the living hell out of this bike!
I also have an RMZ 250 that I primarily keep around so my brother can use it, but every now and then, its nice to get on a bike that doesn't weigh 330 lbs.
The first three are pics of the RMZ 450, I don't have any of the 250, and the last two are of the YZ.
Dadamsnv is offline
post #115 of 5595 Old 07-27-2012, 10:54 AM Thread Starter
Dadamsnv
1977 CJ5
I forgot to mention. I have stage 1 hot cams, hot rods crank, Athena 490 big bore kit, Boyesen super cooler, and two brothers full Ti pipe on the RMZ 450. Needless to say, I'ts a freaking beast!
And it looks like the 250 made it into the last shot.
Dadamsnv is offline
post #116 of 5595 Old 07-27-2012, 10:55 AM Thread Starter
Dadamsnv
1977 CJ5
If/when I get to that point, Its yours man!
Dadamsnv is offline
post #117 of 5595 Old 07-27-2012, 10:58 AM
8pitcher
8pitcher's Avatar
Those are nice bikes. Now I just mainly ride on atvs. Then I have upgraded also to jeeps. I mainly enjoy anything with an engine.
8pitcher is offline
post #118 of 5595 Old 07-27-2012, 11:00 AM
8pitcher
8pitcher's Avatar
How fast is it? It's gotta be at least 130mph
8pitcher is offline
post #119 of 5595 Old 07-27-2012, 11:01 AM Thread Starter
Dadamsnv
1977 CJ5
One more for the road (if you cant tell, dirt bikes fire me up big time!)
This is a decent sized kicker by my house. After this shot, I measured 48 steps boot to boot from lip to rear tire mark. Its at least a 48' jump. Not a ton of air, but its a high third jump and it floats like butter.
Dadamsnv is offline
post #120 of 5595 Old 07-27-2012, 11:03 AM Thread Starter
Dadamsnv
1977 CJ5
Its all low end and torque. I've got it geared to run about 65 tops, which is about normal for a short track race bike. I run sand a lot, and even with all this power, I'm glad its geared so low.
Dadamsnv is offline
