Alpine Lizard Build Project - Page 7 - JeepForum.com
 122Likes
post #91 of 5607 Old 07-22-2012, 10:20 PM
8pitcher
8pitcher's Avatar
Originally Posted by Dadamsnv
It basically the whole motor besides the valve covers, intake and exhaust manifolds, timing cover, flywheel, and oil pan.
Or basically the fully assembled block along with fully assemble heads.
Oh ok I was thinking that it was a longer engine then normal.
What are you doing with your old engine?
8pitcher is offline
post #92 of 5607 Old 07-22-2012, 10:50 PM Thread Starter
Dadamsnv
1977 CJ5
The bottom end is pretty wore out, but the top end and pistons are in pretty good shape, I'll probably sell it on Craigslist. This one I'm buying is $100 and I'll sell mine for probably $300
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #93 of 5607 Old 07-22-2012, 10:52 PM
8pitcher
8pitcher's Avatar
That's not bad at all. You going to bore out the one your buying when you rebuild it?
8pitcher is offline
post #94 of 5607 Old 07-23-2012, 09:00 AM Thread Starter
Dadamsnv
1977 CJ5
Only if it needs it, and then the max I'd go is .030" over, but it's getting the works! I'm sending the block, heads, and the crank to a local motor shop to get completely refinished. Then I'll rebuild everything myself, and hopefully put an extra few ponies in it with a nice cam and some other mods
Dadamsnv is offline
post #95 of 5607 Old 07-23-2012, 09:10 AM
8pitcher
8pitcher's Avatar
Nice that what I'm doing with mine. I'm boring it though because I think it needs it and plus that only costs 100 for the whole block. Then 84 for a professional clean.
8pitcher is offline
post #96 of 5607 Old 07-23-2012, 10:47 AM Thread Starter
Dadamsnv
1977 CJ5
nice
Dadamsnv is offline
post #97 of 5607 Old 07-23-2012, 11:00 AM
8pitcher
8pitcher's Avatar
It will be but i am out of money right now
8pitcher is offline
post #98 of 5607 Old 07-24-2012, 05:27 PM
8pitcher
8pitcher's Avatar
Are you putting in a new cam shaft in the new engine?
8pitcher is offline
post #99 of 5607 Old 07-24-2012, 10:18 PM Thread Starter
Dadamsnv
1977 CJ5
Yup, a torquey low to mid range cam
Dadamsnv is offline
post #100 of 5607 Old 07-24-2012, 10:23 PM
8pitcher
8pitcher's Avatar
That's what I'm looking for. How much do they run?
8pitcher is offline
post #101 of 5607 Old 07-25-2012, 09:45 AM Thread Starter
Dadamsnv
1977 CJ5
This is the cam I'm looking at. Its like $200 with no lifters or timing set
http://www.compperformancegroupstore...de=A8CAMSHFTXE
Dadamsnv is offline
post #102 of 5607 Old 07-25-2012, 10:05 AM Thread Starter
Dadamsnv
1977 CJ5
Here's that long block I've been squawking about. Like I said, got it for $100. The guy also gave me a flexplate, timing cover, harmonic balancer, oil pan, 2bbl motorcraft carb, and all the engine bolts. So basically I bought an 80% complete motor with a blown camshaft and distributor gears. I also bought this stand and lift for $150 from a totally different person on the same day. Not a bad day at all.
Dadamsnv is offline
post #103 of 5607 Old 07-25-2012, 10:09 AM Thread Starter
Dadamsnv
1977 CJ5
My plan with this motor now is to pull the pan, and pull the main bearing caps to see what kind of shape the bottom end is in. If its cherry, I'll simply replace the cam bearings, cam, lifters, and distributor gearset. I'll probably do the rear main oiling mod and a couple more minor oiling mods to the front of the block while I'm in it. If its in bad shape, I'll slowly rebuild it as I have the money.
Dadamsnv is offline
post #104 of 5607 Old 07-25-2012, 10:20 AM Thread Starter
Dadamsnv
1977 CJ5
I got the oil pan put back in last night, I'ts been off for about 2 weeks now
I don't think it will be on there long though. I'm pretty sure I botched the pan gasket install. I got a little heavy handed with the wrench and a corner of the gasket blew out and cracked. I'd just pull it back out tonight and redo it, but I used a ton of silicon sealer on the pan gasket, and I'm hoping the insides and the four corners held up and sealed. Time will tell, and its only a minor hassle to redo it, so whatever happens happens.
On the plus side. The black painted pan bots and the AMC metallic blue pan look fabulous under the rig! Maybe even too nice
Its strange looking at the pan color under sunlight versus under LED camera flash, Its a totally different color.
Dadamsnv is offline
post #105 of 5607 Old 07-25-2012, 10:24 AM
8pitcher
8pitcher's Avatar
Looks really good. I wish I could do that. I bought my engine stand for $20. Do you have a spare harmonic balancer? Just asking because you said that you got one with the long block.
8pitcher is offline
