Alpine Lizard Build Project - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Alpine Lizard Build Project
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHutMemorial Day Weekend Sale Starts Friday-Tuesday 10% off +
Unread 07-15-2012, 12:36 PM   #61
Dadamsnv
D-adams-nv(nevada)
Dadamsnv's Avatar
1977 CJ5
Wuf
"JB weld is like government: in the right hands, it's powerful, but in the wrong hands, it's devastating"
Searching for the Golden Tuning
How I made my Jeep more awesome (roll bar mounted speakers)
Dadamsnv is offline   Reply With Quote
Unread 07-16-2012, 08:04 AM   #62
8pitcher
TgillyCustomFabworks
8pitcher's Avatar
1976 CJ5
I'm getting a sand blaster a big compressor so I can do my frame and body. And all the painting.
1976ish cj5 rebuild 304 t18 dana20 and 7"total lift.
1982 cj7 currently in pieces using parts for cj5
1989 yj i4 5 speed. my grandpas but practically mine. seeing that im the only one who drives it really.
2009 JKU custom bumpers
my workshop build threadhttp://www.jeepforum.com/forum/f37/b...kshop-1430213/
my JK build http://www.jeepforum.com/forum/f96/8...lower-1460650/
8pitcher is offline   Reply With Quote
Unread 07-16-2012, 09:50 AM   #63
Dadamsnv
D-adams-nv(nevada)
Dadamsnv's Avatar
1977 CJ5
You should for sure get a compressor that can run %100 duty cycle and run 12 or better CFM. Expensive, but you can blast all day and paint all day without giving the compressor a break. I have a craftsman 30 gal. and I have to stop and let it rest all the time, and the CFM is too low to paint a whole lot.
Unread 07-16-2012, 09:59 AM   #64
8pitcher
8pitcher's Avatar
1976 CJ5
I found an 80gal on CL And got a sandblasted for 30 bucks.
Unread 07-16-2012, 10:09 AM   #65
Dadamsnv
D-adams-nv(nevada)
Dadamsnv's Avatar
1977 CJ5
NICE
Unread 07-16-2012, 10:30 AM   #66
8pitcher
8pitcher's Avatar
1976 CJ5
NICE
It will be. I hope it's cheap enough.
Unread 07-16-2012, 12:54 PM   #67
8pitcher
8pitcher's Avatar
1976 CJ5
Got a 30 gal for 100$ and sandblasted for 30$
Unread 07-16-2012, 02:06 PM   #68
Dadamsnv
D-adams-nv(nevada)
Dadamsnv's Avatar
1977 CJ5
Pretty good deal man! Just watch the duty cycle on that compressor. Don't want to blow her up
Unread 07-16-2012, 02:54 PM   #69
8pitcher
8pitcher's Avatar
1976 CJ5
Ya your right. I'm going to do all the sandblasting myself which will be awesome.
Unread 07-19-2012, 12:18 PM   #70
Dadamsnv
D-adams-nv(nevada)
Dadamsnv's Avatar
1977 CJ5
I am waiting for AMC blue metallic engine paint from seymore so I can finish the oil pan, but in the meantime, I figured I'd fix the expansion plug leak above the crank on the back of the motor, and replace my pilot bushing. I'm actually lucky that I pulled all the drivetrain apart to seal and paint everything. without doing that, I would have never found that expansion plug leak and would have taken it as a bad new rear main over and over again.
I washed the block with that gunk gel engine cleaner and when it was dry, I could see brown sealer around the plug, and a moist trail of oil heading for the rear main. I had to tap the sealer with a hammer to break it off of the block. Upon inserting the new plug I pushed one side of the new plug in too far for my liking (thought it may contact the cam (not good), so I pulled the new plug back out and trashed it. Off to Summit for another plug set (only way I can get the one plug I need). The second one went in perfect, I used a thin film of RTV in the plug's hole to help seal against remaining brown sealer bits and scratches I may have missed.
I used the grease pack technique I've seen used on this forum to remove the pilot bushing, and it worked great! The new bushing went in really tight! That'll be fun to remove if I have to later.
Unread 07-20-2012, 12:36 AM   #71
8pitcher
8pitcher's Avatar
1976 CJ5
Is seymore the company you bought the paint from?
Unread 07-20-2012, 09:40 AM   #72
Dadamsnv
D-adams-nv(nevada)
Dadamsnv's Avatar
1977 CJ5
No, I used Levineautoparts.com, they were almost half the price of most stores, and I couldn't find it locally.
Here's a link to the paint, just click AMC metallic blue. The part # is EN-66
Unread 07-20-2012, 09:44 AM   #73
8pitcher
8pitcher's Avatar
1976 CJ5
Thanks a lot. Post pics when painted and how you did it so I can myself when it comes time.
Unread 07-20-2012, 10:12 AM   #74
Dadamsnv
D-adams-nv(nevada)
Dadamsnv's Avatar
1977 CJ5
I just got the pan painted, I really like the hue, but it is a little lighter than I thought it was going to be. I had primed the pan about a week ago, so all I had to do was spray. I used four light coats. The can said light coats tend to look better, so I sprayed them all pretty light, but I also sprayed my new water neck, and I used one light coat and two heavy coats, and it came out way less rough and looks better in my opinion. So my advice is use one or two light coats followed by a final heavy coat. I also cleaned and painted my front driveline.
Unread 07-20-2012, 11:36 AM   #75
8pitcher
8pitcher's Avatar
1976 CJ5
Are you not worrying about getting paint inside the pan?
