Alpine Lizard Build Project - Page 2 - JeepForum.com
 107Likes
post #16 of 5500 Old 06-17-2012, 08:19 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
Dadamsnv (FNG)...I couldn't let ya get that plate...w/o the meaning of the term in "some" circles. I didn't want ya getting exposed by truckers every time ya fillled up. Not that you're not a handsome man NTTIAWWT! Of course the Mrs could make some money paying for parts!
This is the best tech/parts and fellowship forum on the webs. I've given, and recieved parts for FREE from total strangers (well not anymore) who didn't need them anymore. We're just like that. It was just your turn in the barrell. I'm a newbie too, been there. Hang around, you'll love it!
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #17 of 5500 Old 06-18-2012, 12:04 AM
85LaredoCJ7
Wtf ?^^^^^
The Dude abides....
85LaredoCJ7 is offline
post #18 of 5500 Old 06-18-2012, 12:58 AM Thread Starter
Dadamsnv
1977 CJ5
Lizard=truck stop hooker. Not exactly what I was going for. Thanks for the heads up!! And for the comments (I think, haha). Have you a build thread??
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is online now
post #19 of 5500 Old 06-18-2012, 12:59 AM Thread Starter
Dadamsnv
1977 CJ5
And what's FNG?
post #20 of 5500 Old 06-18-2012, 01:02 AM
85LaredoCJ7
F'n new guy.....
The Dude abides....
post #21 of 5500 Old 06-18-2012, 01:31 AM
62wagonkid
Its too bad that hoa isnt as big as it used to be... even 5 years ago I was there last year and it was fun but not nearly enough rides.
62wagonkid is offline
post #22 of 5500 Old 06-18-2012, 01:36 AM Thread Starter
Dadamsnv
1977 CJ5
And now onto todays post.
Like I mentioned previously, I was performing some routine drum brake adjustments and inspections when I stumbled upon a happy little f-up. The PO had apparently blown up an axle and had it replaced (at least I hope it wasn't his handy work). All good right? Wrong. Whoever did the work did several things that warrant a kick square in the nuts.
1. Used a pry bar to remove the inner seal, and left two sharp little snake bites on the seal surface of the housing which tore the outer edge of the seal and caused a nasty leak. Some quick dremel work fixed it. Pic 1
2. Reassembled the axle with an outer seal meant for a larger one piece axle I assume because it didn't touch the new axle at all, just hovered neatly around it. Pic 2
3. Didn't torque the axel nut at all, it wasn't even finger tight when I pulled it apart, it was loose an floppy on its threads, thank god for cotter pins and castle nuts. This of course ruined the splines being all jiggly.
4. Used a ton of grease to assemble the hub, which melted onto the drums and caused the strange drifting phenomena that caused the inspection. The leaking gear oil didn't help either. Pic 3
So I pulled both sides apart and ordered Ten Factory one piece axles. All was well and good until I got rubicon front axels in the mail instead of AMC 20. It took 4wheelparts two weeks to figure that one out. A one week down time turned into almost a month. Thanks PO, and thanks 4wheelparts.
post #23 of 5500 Old 06-18-2012, 01:40 AM Thread Starter
Dadamsnv
1977 CJ5
Originally Posted by 85LaredoCJ7
F'n new guy.....
Balls
post #24 of 5500 Old 06-19-2012, 01:20 AM Thread Starter
Dadamsnv
1977 CJ5
Well since I had so much down time because of the shipping fiasco with the axels, I decided I'd put a horn on the jeep, lord only knows why there isn't one, or a windshield wiper motor, or windshield fluid pump, or...
First thing I did was polish up the horn connections underneath the steering lock ring. I knew this connection was bad because my multimeter was giving me an intermittent tone when I shorted the two wires under the horn button. Pic 1
I then used the existing relay and wiring, and simply mounted a new set of hella horns to a modified Home Depot shelf bracket which I painted black. Pic 2 & 3
I topped it off with a new 13" grant GT polished steering wheel. Pic 4.
Now I have horns and an unbent steering wheel!
image-1195704864.jpg   image-2474445286.jpg   image-1997821543.jpg   image-1736371070.jpg
post #25 of 5500 Old 06-19-2012, 01:33 AM
hutch1200
hutch1200's Avatar
1979 CJ7
Looking good. Glad you're handling safety things 1st. Nice work, and you make it look easy!
post #26 of 5500 Old 06-19-2012, 11:09 AM Thread Starter
Dadamsnv
1977 CJ5
Thanks hutch
It may look easy, but thats cause I'm a month or so behind on posts and the frustration has had time to pass. When I get all caught up, I'm sure there will be a little more frustration pouring though my posts
I will include a few frustrating things for all to know about.
1. The steering lock ring is a B*tch to get back on! the spring behind it is really stout. I had to use a screw driver stuffed into the blinker lever hole in the steering column to hold down the ring while I put the c-clip back on, holy crap.
2. I had to drill and tap the aluminum pressed on steering wheel mount because it was all kinds of messed up, worst part is I had to do this while it was on the steering shaft because the threads were that bad, so keeping the aluminum out of the steering column was fun.
3. I had to pay a shop $50 to pull the AMC 20 hub because I couldn't find a puller anywhere, and I couldn't figure out how to use my press on it.
I wish I had taken more pics of this stuff, but I get caught up working and don't want to stop
post #27 of 5500 Old 06-19-2012, 12:05 PM Thread Starter
Dadamsnv
1977 CJ5
So, keeping up with the safety theme, I did a absolute ton of research on DOT approved four point harnesses. Turns out there is only one company I can find that makes them: Scroth. They make several nice race belts, are supported by all those (insert acronym) race organizations, and, best of all are DOT approved. I was concerned about the lap belt being safe for the lady friend and me, so I knew the four point would be a full time thing, but being glued to the seat sounded lame. It turns out, however, that Schroth makes a retractable four point that has an automatically locking spool just like a modern seat belt. I read a ton of reviews and It looks like with these harnesses I can maintain three point mobility with the added safety of a four point all in a DOT approved package. And talk about safe! Go to the website and watch some of their crash tests with these harnesses. They have an antisubmarine tech that works very well. Only bummer is the mounting point for the shoulders has to be the rear bench seat belt mounts, which will be annoying for backseat passengers. But I suppose I can keep the regular lap belts as well and simply use the quick disconnect to set the harness webbing aside while I have back seat passengers. Also they are a little pricey (Cheapest I found is $209 from Tunershop). With this great find I began looking at new seats meant for the four points. I quickly decided on the Corbeau Baja RS. Corbeau is an awesome company for jeeps seats. You can buy a whole lot of cheap crap these days, and it seems Corbeau is the real deal. Plus everyone online loves these seats, so I ordered some ($600 from Morris). I didn't buy brackets yet because I want to see how the seats fit without them. I will buy the harnesses when I have the dough.
In the meantime, I had some time to putter around and fix little things here and there while I waited an eternia for my axle kit. I started with the ugly t-18 shift lever. I pulled the shift lever out and pulled the dumb looking sedan shift knob off to find an mangled stump instead of thread underneath. I wish I had a pic of the poor thing. It looked like someone tried to grind the threads off and JB weld the universal ugly a$$ knob on. Thank god it didn't hold (I would still be trying to get it off). The shift lever was also covered in electrical tape, so i pulled it off to find a rust mess. I attacked it with loads of 180 grit and brought it to a shine pretty quick. I was going to paint it black, but the shiny steel with the sand paper marks in it was so cool, I decided to clear coat the shaft, and leave it looking bare. This of course all took place after the machine shop put 1/2" - 13 threads back on it a little further down the shaft ($50). I topped it all off with 8 ball I bought from a local pool hall. Drilling straight into a spherical object with a hand drill is NOT easy, AND the material the balls are made from does not obey the "when step drilling, the next larger bit will align to the smaller, previously made hole" rule. I got it threaded though, and it looks awesome on the shaft. I also ordered a new boot to put on it. I liked it so much I bought a 2 ball and a 6 ball for my future twin stick. I only threaded the 2 ball for now since I have a single stick t-case.
Last for this post, I relocated the rocker trim off of the fender hump to where it belongs which took some grinding. I attached a fixed side and an "original" side pic. This exposed some bare fiberglass, but whatever. Thanks PO.
8ballhole.jpeg   8_ball.jpeg   2_ball.jpeg   Bad_rocker_panel.jpeg   good_rocker_panel.jpeg
post #28 of 5500 Old 06-20-2012, 12:18 AM Thread Starter
Dadamsnv
1977 CJ5
Still waiting for axles, so I figured I'd tighten up my steering a bit and throw on my ARB onboard air. I air down if I wheel hard, and I figure the ability to air down and up at a whim is one of the best wheeling mods you can make.
Anyway. I got to the steering shaft and gave it a wiggle to find that it was the CV style joint at the base of the steering shaft that was so terribly loose. The CJ wandered like it had ADD real bad on the freeway, and I wanted to completely stop this, so I bought a Borgeson steering shaft and tightened up the steering box. Now this thing steers like a new Honda.
I put the ARB unit on the sloped part of the driver side front wheel well. In previous pics you can barely see a black and decker power inverter bolted there (what the hell PO!). I Ripped that POS out an now the air lives there. Leek proofing it took a few tries, but I eventually got that little tank to lose only 2 psi a day. The wire harness is crazy looking at first, but it all goes together very easy, ARB did a great job on this product! It filled my 31" tire from 8 psi to 30 in one minute!
I also found a way to mount my steering stabilizer above my tie rod without it running into anything including the bump stop. It looks like a generic kit, and the tie rod mount had no way of mounting that wouldn't hit my diff. So I tool the grinder to it and made it fit
image-1957258762.jpg   image-3278850125.jpg   image-2525129234.jpg   image-447969311.jpg   image-2640625008.jpg
post #29 of 5500 Old 06-21-2012, 01:07 AM Thread Starter
Dadamsnv
1977 CJ5
Still waiting on axles, still... Waiting...
But I did get my seats in!! I pulled the old passenger seat with its bracket and put the new seat on the bracket. I heard there were fitment issues with the CJ5s, but I wanted to see if it was going to work. Unfortunately, the seats didn't fit. So I ordered the entire seat bracket since it kept the stock height. Now, I wait again.
The old passenger seat l pulled had three seat covers on it. All obviously well loved. I imagine it was stock in the 70's, black and white woven yarn in the 80's, purple felt in the 90's, and cheap crap ricer purple in the 2000's
post #30 of 5500 Old 06-21-2012, 01:10 AM
hutch1200
hutch1200's Avatar
1979 CJ7
FYI. The seats you ordered are the same price @ quadratec, but they have a shipping deal. Check through the thread for the ordering process. Keep up the good work!.
