Alpine Lizard Build Project - Page 171 - JeepForum.com
 50Likes
post #2551 of 4970 Old 08-22-2014, 12:41 PM Thread Starter
Dadamsnv
1977 CJ5
My boss inherited a gen 2 ram 2500 with a cummins 5.9L and an auto tranny. He is parting it out and offered me the rear axle (him and I chat about crawlers sometimes). According to the web, it's a dana 70 with either 3.54 or 4.10 gears. WMS-69.5". 35 spline axles. Basically, it's the ideal rear axle for a gnar crawler, so I'll probably buy it off him and store it in the garage. It'll be there a while until I an touch it, but that's what 3 car garages are for.
The plan:
-Ballistic fab disk brake conversion $40
-70's Blazer calipers and rotors. Kit is designed to accept these parts.
-Detroit locker $500
-4.88 gears $300
-blue torch fab diff cover $70
Powder coated black and set up for links and coils. A man can dream right? Someday, I want this...
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #2552 of 4970 Old 08-23-2014, 12:40 AM Thread Starter
Dadamsnv
1977 CJ5
Now that I've seen what a brand new clutch looks like, I'm confused as to why mine was failing. My old one looks hardly wore out
I wonder if the flywheel was warped or if there was some other problem. I suppose if the clutch was truly wore out I would've felt it slipping instead of shuddering. Given the care the PO took of this jeep, I wouldn't be surprised if the flywheel was never turned when the last clutch was put in. Jeeze
Dadamsnv is offline
post #2553 of 4970 Old 08-23-2014, 12:56 AM
gazzo
Originally Posted by Dadamsnv
Now that I've seen what a brand new clutch looks like, I'm confused as to why mine was failing. My old one looks hardly wore out I wonder if the flywheel was warped or if there was some other problem. I suppose if the clutch was truly wore out I would've felt it slipping instead of shuddering. Given the care the PO took of this jeep, I wouldn't be surprised if the flywheel was never turned when the last clutch was put in. Jeeze
Umm, I just did that this morning. Ask me why I didn't get the flywheel skimmed whilst they were balancing it to suit the 360. Dumb and lazy that's why
Daniel my brand new clutch assembly into my 7 2 years ago was shuddering for a while so that's hard to explain right? Hopefully the new Sachs plate and B&B pressure plate I fitted to the CJ10 360 today doesn't give me the yips. It's one of those 3 finger jobbies which I haven't used before.
Gary (gazzo)
http://www.jeepforum.com/forum/f8/gazzos-cj10-truck-2185617/
gazzo is offline
post #2554 of 4970 Old 08-23-2014, 04:01 PM Thread Starter
Dadamsnv
1977 CJ5
Gary,
That is hard to explain. I just want it to never happen again. This shuddering was very violent
In other news, I've blasted one whole header, a long process with a %50 duty cycle 33gal compressor. I've also created a cool blasting cabinet and welded up a motor mount backing plate. My second header is 1/2 way done.
Dadamsnv is offline
post #2555 of 4970 Old 08-24-2014, 01:49 AM Thread Starter
Dadamsnv
1977 CJ5
After a while, I couldn't take the sand blasting any more. Too darn hot in all that safety garb, so i set about cleaning my block. I had some simple green lying around, so I used that up first. I used a screwdriver to scrape the thick stuff off, a wire brush to loosen the medium stuff, and a water spray bottle to rinse the light stuff. I have much more work to do, but here is a before and after of the worst side. I'd say the simple green did quite well.
Dadamsnv is offline
post #2556 of 4970 Old 08-26-2014, 10:31 PM Thread Starter
Dadamsnv
1977 CJ5
This.
Dadamsnv is offline
post #2557 of 4970 Old 08-26-2014, 10:44 PM
lucdog
1980 CJ5
The clutch problem could be the springs in the friction disc. One or more could be broke, or just weak.
The springs are there to absorb shock load when the clutch is released,
George, what the proper term for this? Harley's have the same thing , I believe it's on the crankshaft primary chain sprocket.
Looking good Daniel!!!
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #2558 of 4970 Old 08-27-2014, 04:54 AM
gmakra
Bill my Harleys were before the newer gentler Yuppie Harleys with electric start, heated seats and all that so mine didnt have any damping springs.
gmakra is offline
post #2559 of 4970 Old 08-27-2014, 05:45 AM
lucdog
1980 CJ5
It's the compensating sprocket. Not part of the clutch assembly. Name:  image-3359802010.jpg
Research shows the "C" sprocket has been used in ione form or another since 1955.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #2560 of 4970 Old 08-27-2014, 09:47 AM Thread Starter
Dadamsnv
1977 CJ5
Thanks Bill. And I hope you're right. I'd much rather have a defective or worn/broken clutch or clutch component than a mystery problem.
Dadamsnv is offline
post #2561 of 4970 Old 08-27-2014, 11:22 AM
gmakra
Yeah but you will still have a pink engine compartment!
gmakra is offline
post #2562 of 4970 Old 08-27-2014, 02:49 PM Thread Starter
Dadamsnv
1977 CJ5
You don't know that!
Dadamsnv is offline
post #2563 of 4970 Old 08-28-2014, 10:50 PM Thread Starter
Dadamsnv
1977 CJ5
Baked my engine mount brackets, and painted my other header. I've also been cleaning my block a lot. I'm close to painting the block at this point, but I still haven't received my AMC blue paint from bulltear!
Dadamsnv is offline
post #2564 of 4970 Old 08-29-2014, 01:13 AM
8pitcher
8pitcher's Avatar
Thank god the house came with a custom part baker in the sammich room!!
8pitcher is offline
post #2565 of 4970 Old 08-29-2014, 05:36 AM
Guy Smilie
Guy Smilie's Avatar
1978 CJ5
Got my AMC blue paint from Levineautoparts.com, $7.99 a can in 2 days
Guy Smilie is offline
