Alpine Lizard Build Project - Page 146 - JeepForum.com
 104Likes
post #2176 of 5455 Old 02-26-2014, 11:23 AM
ScroungerLee
That looks nice. You should do something to waterproof that crimped butt splice. Some other type of connector would be better, like soldering the connection and having shrink tube covering it.
ScroungerLee is offline
post #2177 of 5455 Old 02-26-2014, 12:28 PM Thread Starter
Dadamsnv
1977 CJ5
That connector is inside the tub in an area where we see 6" of rain a year. Never the less, you are correct. I'll likely put a bit of electrical tape over it and call it good. Thanks for keeping me in line
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #2178 of 5455 Old 02-26-2014, 03:21 PM Thread Starter
Dadamsnv
1977 CJ5
Hey Gary,
Remember when I said my leaks are almost completely fixed? Well my t case doesn't leak anymore, but I just noticed some seeping out of my driver side front axle seal
You were right! I just had to go and open my big mouth.
On the plus side, this gives me the opportunity to replace my ball joints, change my fluid, and possibly add a spartan locker.
Dadamsnv is offline
post #2179 of 5455 Old 02-26-2014, 05:32 PM
Skerr
Round off the corners of the light bracket (if you haven't already). Give it the same contour as the light. Besides eliminating a snag point, it will look more finished. Nice work!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #2180 of 5455 Old 02-26-2014, 08:02 PM Thread Starter
Dadamsnv
1977 CJ5
Great advice! But a tad too late I'm afraid.
Dadamsnv is offline
post #2181 of 5455 Old 02-26-2014, 08:05 PM Thread Starter
Dadamsnv
1977 CJ5
For those who care to know, the green wire with the black tracer is NOT the driving light. It was right in my driver side light, but not in the harness. Or I could've screwed it up somehow. I dunno. All I know is the white wire without tracer is the driving light doh!
Dadamsnv is offline
post #2182 of 5455 Old 02-26-2014, 11:36 PM Thread Starter
Dadamsnv
1977 CJ5
Under hood rattling is back with a vengeance! However, it isn't the air cleaner this time. I just couldn't see any collision marks in the tranny tunnel, and was running out of ideas. So I started grabbing things under the hood and shaking them.
The last thing I went to Shake was the steering shaft. Wouldn't you know it, the dan thin rattles up and down and made the same noise I was hearing. Apparently the bearing in charge of supporting the splined portion or the steering column in the engine bay is very bad.
Dadamsnv is offline
post #2183 of 5455 Old 02-27-2014, 09:07 AM
WSS
WSS's Avatar
1972 CJ5
My PO rigged up (nicely) a heim and bracket to support the shaft. Works good. I can get you a pic if it will help.
WSS
WSS is offline
post #2184 of 5455 Old 02-27-2014, 10:20 AM Thread Starter
Dadamsnv
1977 CJ5
Originally Posted by WSS
My PO rigged up (nicely) a heim and bracket to support the shaft. Works good. I can get you a pic if it will help. WSS
Thanks, but the replacement bearing is $22. If that doesn't work, I'll have those pics.
This is also a good time to order the bell crank joint kit.
Dadamsnv is offline
post #2185 of 5455 Old 03-03-2014, 08:40 AM Thread Starter
Dadamsnv
1977 CJ5
Finally filed taxes last night. It's a modest return, but if we weren't saving for a house, my half would allow me to have some killer fun with the jeep. Oh well, maybe next year. Apparently there is another huge tax benefit for home buyers this year. So next tax season should be the boost the CJ needs.
This year was certainly better than last year. I ended up paying over $1500 to the IRS last year :S
Dadamsnv is offline
post #2186 of 5455 Old 03-03-2014, 08:47 AM Thread Starter
Dadamsnv
1977 CJ5
The wife and I have set a soft target date to hit the rubicon with jeep jamboree in late august. But first this checklist must be filled out:
Front spartan locker
Rear locker (optional)
4" RE lift and YJ conversion (possible shackle reversal at the same time)
33x12.5x15 toyo MTs on 10" wheels
Rocker armor
Tummy tuck skid plate
Beefy diff covers
Dadamsnv is offline
post #2187 of 5455 Old 03-03-2014, 10:30 AM
WSS
WSS's Avatar
1972 CJ5
With your welding skills, the diff covers will be an easy one to knock off the list. For rocker armor, 4x4x1/4 or 3/16 angle works good, the other stuff............$$
From experience, I can say "think it through" LOL. The cost savings is worth it. This weekend I built my shock hoops BEFORE I had the shocks. Now, the second time I get to build them will be much easier. I wanna kick myself. I was all set to use 11x2 shocks, then a set of 12x2 w/res become available, hoops are 2" too short.
WSS is offline
post #2188 of 5455 Old 03-04-2014, 10:24 AM Thread Starter
Dadamsnv
1977 CJ5
I will most definitely be welding the rocker armor, tummy tuck, and diff covers. I can save loads of money this way
That's a bummer about the shock hoops, but they are looking good!
Dadamsnv is offline
post #2189 of 5455 Old 03-04-2014, 06:08 PM
Skerr
I am so there with you!!!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #2190 of 5455 Old 03-06-2014, 09:59 AM Thread Starter
Dadamsnv
1977 CJ5
Time to consult the experts. In looking for new axle seals for the D30, I noticed they offer inners and outers. So the question is: does the CJ D30 actually use an outer axle seal? If so, when I replaced my ring and pinion, I only had inners and only replaced inners.
I aim to replace ball joints, axle seals, and diff cover with a beefier one as well as install a spartan locker all in one shot. So I'll start hoarding parts for that this week.
Dadamsnv is offline
