Alpine Lizard Build Project - Page 13 - JeepForum.com
 57Likes
post #181 of 5059 Old 08-08-2012, 04:23 PM Thread Starter
Dadamsnv
1977 CJ5
Originally Posted by 8pitcher View Post
I'm gonna take over then in a few months then.
What happened to your radiator? Just a big hole or?
It had a JB welded fill neck, and was very slowly leaking form 3 spots. I knew this a while ago, but I figured I'd drive it a bit before I dug into it. Also, its super duper old, and it only has 1 core.
I bought a cheapy 3 core at summit. its painted black, which I think is stupid, but whatever. It'll get me by.
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #182 of 5059 Old 08-08-2012, 05:14 PM
8pitcher
8pitcher's Avatar
How much for that new radiator.
8pitcher is offline
post #183 of 5059 Old 08-08-2012, 08:49 PM Thread Starter
Dadamsnv
1977 CJ5
http://m.summitracing.com/parts/sgt-cu583
They say it has an auto tranny cooler, but it doesn't, and that's just fine with me.
Dadamsnv is offline
post #184 of 5059 Old 08-08-2012, 08:54 PM
8pitcher
8pitcher's Avatar
Auto tranny cooler doesn't really matter though you got a manny tranny right? I may look into a new radiator if mine doesn't work but the. One I have looks brand new so I won't know till its mounted.
8pitcher is offline
post #185 of 5059 Old 08-08-2012, 11:42 PM Thread Starter
Dadamsnv
1977 CJ5
Yeah, manny tranny, so it's actually better than I'd hoped.
Dadamsnv is offline
post #186 of 5059 Old 08-09-2012, 12:12 AM
8pitcher
8pitcher's Avatar
Hey better is good.
8pitcher is offline
post #187 of 5059 Old 08-10-2012, 11:47 AM Thread Starter
Dadamsnv
1977 CJ5
Over the last few days, I've been tearing apart the front of my 304 to fix a leak in the timing cover, and to take stock of what shape the timing set and cam gears are in. Lucky for me, both the timing set and the cam gears look very new. I did replace the oil pump though, and I lapped the oil pump cover to make some better pump clearance, and to give the new pump a place to make its own wear pattern instead of eating up the old pattern.
I painted the timing cover and the water pump with AMC metallic blue. I was going to sand blast the parts first (and buy a new water pump), but I decided I didn't want to spray sand into the oil passages that bad, and summit was out of every water pump they carry for AMC V8s. I could have and cleaned the cover out real well, but I just sprayed over the old paint after a really good solvent spray and clean session. Pics to come shortly. If I get her all back together on Saturday, I can cruise Hot August Nights this weekend in style!
Dadamsnv is offline
post #188 of 5059 Old 08-10-2012, 11:54 AM Thread Starter
Dadamsnv
1977 CJ5
Here are some more pics. The upload feature kind of screwed me out of some pics and then rearranged them, whatever.
Dadamsnv is offline
post #189 of 5059 Old 08-10-2012, 11:56 AM Thread Starter
Dadamsnv
1977 CJ5
I will have to check to make sure the oil passages in the cam, fuel eccentric, and cam gear line up. I dont see any goof wear, but it also looks pretty new, so... who knows. better check while I'm this deep.
Dadamsnv is offline
post #190 of 5059 Old 08-10-2012, 09:27 PM Thread Starter
Dadamsnv
1977 CJ5
Oil passage to the dizzy is free and open. I pulled the bolt and washer, and fed some little wire thought the notch. It went in about 5 inches which is perfect. Also here is the painted timing cover and water pump.
Dadamsnv is offline
post #191 of 5059 Old 08-10-2012, 09:31 PM
8pitcher
8pitcher's Avatar
Love the color. Looks really good. Next will be valve covers I guess right? Oh and how much play is in your timing chain I'm debating whether or not I need to get a new one.
8pitcher is offline
post #192 of 5059 Old 08-10-2012, 10:02 PM
Skerr
That AMC blue really makes an engine POP! Good job Dad.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #193 of 5059 Old 08-11-2012, 01:43 AM Thread Starter
Dadamsnv
1977 CJ5
Thanks guys
I painted over the old paint in favor of not spraying sand into the oil pump, so it's a little lumpy in spots, but looks WAY better, I'm glad you like it!
It turns out fel pro's complete timing cover gasket set doesn't come with a water pump gasket or a harmonic balancer seal despite being shown In the picture. Good grief. I was hoping to have the cover and pump on tonight, but that's life. I guess I'll be driving it Sunday instead of all weekend.
I was able to get a water pump gasket, but the seal was at napa, too far away. Here is the water pump sealed up with black bolts. I also filed the paint off of the timing marks to make the aluminum stand out.
Dadamsnv is offline
post #194 of 5059 Old 08-11-2012, 08:03 AM
Skerr
I hit my timing marks with a tiny bit of the rattle can metallic silver. I have no idea about long term durability, but it is SUPER EASY to see at thie time.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #195 of 5059 Old 08-11-2012, 10:49 AM Thread Starter
Dadamsnv
1977 CJ5
That's a good ide., I thought about the bare metal being a problem. It's Aluminum, but who knows. I'll probably put some clear over that spot
Dadamsnv is offline
axxxgijoexxxa , Brianscj5
