Alpine Lizard Build Project - Page 102 - JeepForum.com
 83Likes
post #1516 of 5190 Old 08-19-2013, 08:49 PM Thread Starter
Dadamsnv
1977 CJ5
I checked my timing curve in preparation of purchasing a decent HEI unit. A while back, I tuned my distributor and it looked like this.
When I checked today, it was...
12* @ 700 RPM
28* @ 1400 RPM
28* @ 2000 RPM
YIKES!!!!
My only guess was the springs fatigued, so I tore it apart and replaced my light and medium spring with two new medium springs. Then I tried again...
12* @ 700 RPM
15* @ 1200 RPM
23* @ 1400 RPM
28* @ 2000 RPM
28* @ 2500 RPM
Not a whole lot better, and what's with the jump between 12 & 14*??? Turns out the counterweights had worn on each other at 1400 RPM (where I typically wheel at and spend a lot of time at). It wore such that the advance falls into the 29* range into the pocket it wore and stays there. If it were loose springs, it wouldn't have stayed the same between 1400 and 2000 RPM since the max is mid 30's. that's my hypothesis anyway.
I hope it didn't harm my jeep too much. U haven't seen a drop in oil pressure or heard any audible pinging, so here's to hope. I will purchase a new dizzy before I run her again.
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is online now
post #1517 of 5190 Old 08-19-2013, 09:02 PM
lucdog
lucdog's Avatar
1980 CJ5
Good info Daniel, I imagine anyone who takes there Jeep off road could have the same problem. I spend most time on trails between 700 and 1600 rpm.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #1518 of 5190 Old 08-19-2013, 10:51 PM Thread Starter
Dadamsnv
1977 CJ5
B
Ought to check your timing then!!!
Honestly I'm pretty sure a legit distributor wouldn't have an issue. Mine is some cheap knock off brand. Time for a real one. Probably go with a nice MSD one to match my wires
post #1519 of 5190 Old 08-21-2013, 05:29 PM Thread Starter
Dadamsnv
1977 CJ5
Here's pictures of my distributor weights.
Notice the dark spots. Those are heavily wore surfaces
post #1520 of 5190 Old 08-21-2013, 05:33 PM Thread Starter
Dadamsnv
1977 CJ5
I went to summit and bought the most expensive HEI advance kit I could buy ($15 from accel). This will get me by until I can buy a decent distributor.
post #1521 of 5190 Old 08-21-2013, 05:43 PM
243
1978 FSJ Cherokee
Great job on the wiper motor restoration
Dave's 78 Build
243 is offline
post #1522 of 5190 Old 08-22-2013, 05:31 PM Thread Starter
Dadamsnv
1977 CJ5
Thanks Dave!
Only thing I regret is painting the cord. I may see if I can't take the paint off of it some day.
post #1523 of 5190 Old 08-22-2013, 05:32 PM Thread Starter
Dadamsnv
1977 CJ5
The best part about living in the mountains is the incredible clear blue sky! Today is a little less clear.
post #1524 of 5190 Old 08-22-2013, 06:09 PM
Skerr
Thought that was a painting!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #1525 of 5190 Old 08-22-2013, 07:02 PM Thread Starter
Dadamsnv
1977 CJ5
It's painting the insides of my lungs right now.
post #1526 of 5190 Old 08-22-2013, 07:20 PM Thread Starter
Dadamsnv
1977 CJ5
More pics
post #1527 of 5190 Old 08-22-2013, 08:01 PM Thread Starter
Dadamsnv
1977 CJ5
Back to jeeps. So I've been through 2 new weight sets (accel and MSD). Both promise to be stock style, and I haven't been ale to get more than 27 total with 12 initial. Both weight sets have shot the advance up dramatically like the stock weights. Weird. Something is amiss.
post #1528 of 5190 Old 08-23-2013, 10:33 PM Thread Starter
Dadamsnv
1977 CJ5
Pics again
I've never been able to just stare at the sun like today. It's just a full orange ball in the sky. The keypad has ash in it. Which is why it's in the pics.
post #1529 of 5190 Old 08-27-2013, 09:56 PM Thread Starter
Dadamsnv
1977 CJ5
Well I was able to get some janky crappy curve for now until I can afford a decent distributor. The curve is way too safe and I'm sure the jeep will be sluggish, but at least it won't be grinding up the bottom end. It hits 27* at 2500 rpm from 12* at 1500 and doesn't go any higher. Le sigh.
Perhaps I'll begin seriously considering GM TBI swaps since I'm looking at a qjet too which means even mo money
post #1530 of 5190 Old 08-27-2013, 11:05 PM
8pitcher
8pitcher's Avatar
I gotta block all painted up and purdy
8pitcher is offline
