Alpine Lizard Build Project - Page 10 - JeepForum.com
 108Likes
post #136 of 5500 Old 07-30-2012, 01:41 PM Thread Starter
Dadamsnv
1977 CJ5
Originally Posted by 8pitcher View Post
Thanks. Decided not to rebuild. Just redo gaskets and paint and I will rebuild when I get the money later on.
Serious. My rebuild may end up costing me up to $3000
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #137 of 5500 Old 07-30-2012, 01:53 PM
ronaldo-fantast
1982 CJ7
Originally Posted by Dadamsnv View Post
Well since I had so much down time because of the shipping fiasco with the axels, I decided I'd put a horn on the jeep, lord only knows why there isn't one, or a windshield wiper motor, or windshield fluid pump, or...
First thing I did was polish up the horn connections underneath the steering lock ring. I knew this connection was bad because my multimeter was giving me an intermittent tone when I shorted the two wires under the horn button. Pic 1
I then used the existing relay and wiring, and simply mounted a new set of hella horns to a modified Home Depot shelf bracket which I painted black. Pic 2 & 3
I topped it off with a new 13" grant GT polished steering wheel. Pic 4.
Now I have horns and an unbent steering wheel!
Ooo that's the wheel i want to replace my yacht wheel. thought about getting the grant steering wheel quick release anti-theft device?
ronaldo-fantast is offline
post #138 of 5500 Old 07-30-2012, 02:15 PM
8pitcher
8pitcher's Avatar
Mine would be 700. I will do it later.
8pitcher is offline
post #139 of 5500 Old 07-30-2012, 02:21 PM Thread Starter
Dadamsnv
1977 CJ5
Those old wheels are obnoxiously huge!
I haven't heard of a steering wheel quick release, i can imagine cruising through the grocery store, wheel in hand. haha
Some kind of antitheft would be nice at $100 a pop for those wheels.
Dadamsnv is offline
post #140 of 5500 Old 07-30-2012, 02:23 PM Thread Starter
Dadamsnv
1977 CJ5
WHAT??
how so cheap?
Dadamsnv is offline
post #141 of 5500 Old 07-30-2012, 02:33 PM Thread Starter
Dadamsnv
1977 CJ5
Big news!! I drove it to work today!!!!!!!
I was able to start her up last night after polishing up the drivetrain install and adding fluids to everything. She purred like a kitten, had absolutely no leaks or even moist spots from the new pan seal or rear main after 15 mins of idling!!!!! I'm so stoked that that stuff held up!! Its a great day! None of the drivetain leaked at all. I only had a couple drops of coolant form the drain port on my water neck. I'll drain some coolant and reseal that tonight.
You know what that means...? I officially have a leak free CJ!!! (for the moment anyway)
On another note, today was the first time I used the brakes since the YJ power brake conversion. The pedal pushes in almost to the floor while the jeep is off, but a half push while she is off and rolling will stop her dead in her tracks. While I was driving it, a feather of a push will start slowing her down, and a quarter push is a good stopping speed. I haven't locked up any wheels, but I have no doubts I can burn the front ones easy (front dist rear drum). So far, an excellent way to spend $120 on a CJ. I'm very pleased with the mod, and the best part is I still get great stopping power with the motor off for wheeling and such if I kill the motor up a hill.
Dadamsnv is offline
post #142 of 5500 Old 07-30-2012, 02:43 PM
8pitcher
8pitcher's Avatar
WHAT??
how so cheap?
185 for boring and cleaning.
550 or so for engine rebuild kit.
Why is yours going to be so much?
8pitcher is offline
post #143 of 5500 Old 07-30-2012, 02:45 PM
8pitcher
8pitcher's Avatar
Congrats.
8pitcher is offline
post #144 of 5500 Old 07-30-2012, 03:44 PM Thread Starter
Dadamsnv
1977 CJ5
~$800 to machine (grind crank, line hone mains, hone cam bearings, bore cylinders if needed, hone cylinders, mill block and heads, cut valve seats, new valve guides, rear main oiling mod, etc)
~$600 for rebuild kit parts
~$200 added onto parts kit for upgraded cam, lifters, and timing set
I might as well do motor MORE motor mounts, moroso oil pan, gotta buy water pump, valve covers, new carb for the added breathing of the cam, new headers, the list goes on
Dadamsnv is offline
post #145 of 5500 Old 07-30-2012, 04:13 PM
8pitcher
8pitcher's Avatar
Wow
8pitcher is offline
post #146 of 5500 Old 07-31-2012, 12:54 AM Thread Starter
Dadamsnv
1977 CJ5
I spoke too soon! When I got home I had a puddle under the CJ in a matter of minutes. Much to my happiness, it was the Dana 20 and not the oil pan or rear main.
So I jacked up the tranny, dropped the skid and the drive lines, pulled the twin sticks, pulled the speedo cable, drained the t case, unbolted it, and pulled it off. Again.
What I found made me feel stupid, as I knew it would. Only pics can really describe the oil leaks I haphazardly caused. It turns out the gasket lays right over the adapter bolt holes and makes a nice oil bridge.
Dadamsnv is offline
post #147 of 5500 Old 07-31-2012, 12:55 AM
8pitcher
8pitcher's Avatar
At least you found the leak.
8pitcher is offline
post #148 of 5500 Old 07-31-2012, 01:08 AM Thread Starter
Dadamsnv
1977 CJ5
I was able to fix all this t case leaking BS by digging through the trash to find the gasket advance adapters sent me. I didn't use it because it was huge and clunky, but now I know why, I cleaned everything off and redid the gasket with fresh silicon on both sides and bolted the t case back up.
I felt a little gritty something in the bearings while I was removing the t case, and there was a good amount of dust on the drain magnet (especially for only having 20 miles on it). This concerns me a bit. I must have missed a pocket of sand while rinsing the case post sand blasting. But there was no dirt in the oil, so I don't know what is up. It drives smooth and nice, so...
I used a quart of 10w-40 I had laying around to flush the t case a but, and it didn't have dirt in it either. I dunno...
I refilled it and sealed it all up and bolted her all back together, I guess time will tell.
I had to expand a stripped skid frame nut to 7/16" to put the skid on last time so here's some pics of that.
Also, I built my own t case drop kit at ace hardware in town. The big nut has a spacer the same height internal so the whole thing is pretty beefy now. Its 1-1/16" drop for the t 18. The drop spacer in the middle is fake. SHHHHH! I didn't even have a frame nut there (dunno what happened) so its JB welded together.
Dadamsnv is offline
post #149 of 5500 Old 07-31-2012, 01:12 AM Thread Starter
Dadamsnv
1977 CJ5
One last post tonight, here's some pics you may like of the twin stick shaping, and the finished product.
image-4201913330.jpg   image-527082646.jpg   image-2729878483.jpg   image-3083702881.jpg   image-3708038989.jpg
image-2296030128.jpg   image-3607480893.jpg   image-223127138.jpg   image-2571734052.jpg   image-2080699390.jpg
Dadamsnv is offline
post #150 of 5500 Old 07-31-2012, 01:17 AM
8pitcher
8pitcher's Avatar
Looks really good.
8pitcher is offline
