Are all (truck) shocks the same? - JeepForum.com
post #1 of 8 Old 01-01-2016, 07:40 PM Thread Starter
kirbot
1981 CJ7
So, I'm working on installing a 3" lift on my CJ, and I'm going to need to pick up longer shocks on a budget.
Older Ford f250 shocks look to be about the right length, but are they going to be too stiff for the lighter CJ7?
Part of me assumes heavier vehicle = stiffer shocks, but I can't really find anything to confirm that.
For example, Advance carries "Monroe Gas-Matic Truck Shocks" for both a CJ7 and an f250, and doesn't say anything about one or the other being stiffer.
1981 CJ7, AMC 258, MC2100, T18, Dana 300, OME 2.5" lift, front locker, 32" Kenda mud terrains
kirbot is offline
post #2 of 8 Old 01-01-2016, 08:11 PM
skizriz
1978 CJ7
Gas charged shocks are stiffer. It will take everything you have to compress it, and then it will open back up again. Way too stiff for a CJ IMHO.
I've been running Doetsch Tech DT3000 shocks on mine for a few years and really like them. Hard to beat the $40 price, no matter what length you get.
http://www.lowrangeoffroad.com/doetsch-tech-shocks.html
78 CJ7.. 258.. TH400/Dana18.. SOA/stock YJ springs.. 35" General Grabbers.. Waggy 44s.. 4.88 gears...Spartan/Lockright...Fiberglass front to rear
skizriz is online now
post #3 of 8 Old 01-01-2016, 08:31 PM Thread Starter
kirbot
1981 CJ7
Never seen them before but they do sound pretty well received.
I know I shouldn't cheap out too much. $40 is probably a pretty good compromise
kirbot is offline
post #4 of 8 Old 01-01-2016, 09:27 PM
only in a jeep cj
The valving is different in various shock applications. Yes, the F250 will have differently valved shocks and I'm guessing different sizes, lengths, and eye ends. This is why there are thousands of different shocks out there.
I really hope that quality control has improved or at Doetsch as I ordered a set years ago and one was very different than the other 3. Customer service and trying to get a replacement was a horrible and drawn out experience with the one rep I was going through....When I finally just got a refund, They said that person was no longer there. I would be willing to try them again.
I would remove your current shocks and fully stuff and drop the axles and record the measurements from eye to eye studs. Then use this chart to determine which ones you need. Don't let a generic sales page pick your part number for you.
http://doetsch-shocks.com/37.asp
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #5 of 8 Old 01-05-2016, 01:34 PM Thread Starter
kirbot
1981 CJ7
Well, I ended up with the Monroes after all...
I thought I was going to be able to use my old shocks for a little while, but they turned out to be too short even for on road driving.
So between needing shocks right away, and the $60 they want for shipping on the Doetsch shock, I just decided to cheap out at Advance.
I can post the part numbers I ended up with if anybody is interested, but I just looked through all the Monroe LTs until i found the right length.
They actually feel quite a bit softer than the Superlifts I had, and it came to $68 with tax for all 4. So I'm happy enough for now.
Somewhere much later down the line I might upgrade to OME or Bilstein.
kirbot is offline
post #6 of 8 Old 01-05-2016, 05:30 PM
CSP
There's really no need to go to high dollar shocks with leaf springs. The shocks are there to control rebound and as you found the $68 Monroes do the job.
CSP is offline
post #7 of 8 Old 01-05-2016, 07:16 PM Thread Starter
kirbot
1981 CJ7
Sometime this week I'll take it back on a dirt road where I'll really see how these handle.
Theres a nice wide, but extremely washboarded road near here thats great for testing out suspensions....
After a ride in to work on them though, I'm really happy I saved the $160
kirbot is offline
post #8 of 8 Old 01-05-2016, 08:45 PM Thread Starter
kirbot
1981 CJ7
BTW, I forgot to mention the Monroes were made in the USA.
As silly cheap as they are, I'd have to put money on them being Chinese. Definitely a nice surprise.
kirbot is offline
