ALL DRUM BRAKE Combination Valve! - JeepForum.com
post #1 of 9 Old 10-22-2014, 06:19 PM Thread Starter
WindKnot
1977 CJ7
I need help!
My brake combination valve is toast. One of the seats is messed up and no matter what, it leaks. I've searched high and low for a replacement, but so far all I can find are valves that fit the disc/drum combo.
Will this work?
Any idea where I can find an original?
1977 CJ7, Manual 4 drum brakes.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration? http://www.jeepforum.com/forum/f8/ph...ation-1807257/
WindKnot is offline
post #2 of 9 Old 10-23-2014, 04:48 AM
ECJ-7
1976 CJ7
I was looking into going to power assist on mine and the booster/master comes with a new valve, so I'm guessing it is different or they wouldn't include it.
if the seat is screwed up, see if you can find a small enough copper compression washer some parts stores will carry a selection, they're used alot on ba flare fittings, no reason why it wouldn't work on the inverted flare.
ECJ-7 is offline
post #3 of 9 Old 10-23-2014, 08:21 AM Thread Starter
WindKnot
1977 CJ7
Hmmmm......
I'll give the copper washer a try. Nothing to lose but brake fluid.
All the replacements specify disc/drum set ups, so I called and asked. the answer I got was, "You have a stock set up, so it should work..." I'm not so sure unless the difference is thread sizes, which could be worked around.
Thanks.
In the meantime, I'm waiting for J&W in California to open. I don't know if they'd sell a used valve for a brake system, but I'll ask.
WindKnot is offline
post #4 of 9 Old 10-23-2014, 09:36 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by WindKnot View Post
Hmmmm......
Thanks.
I might have one. I'll look.
Anyways a disk/drum setup won't work. There are metering valves and delay springs and stuff like that to get a disk/drum system to work properly.
"The combination valve (often mistakenly just called a proportioning valve) performs three distinct functions, all necessary for safety in a disc/drum setup.
It certainly contains a proportioning valve, which is necessary to reduce pressure to the rear brakes, so that they don't lock up before the fronts, but it also contains a metering valve and a pressure differential switch.
The metering valve provides pressure to the rear brakes before the front brakes. This is necessary to allow the shoes to come in contact with the drums before the front brakes are applied (the front pads are always in contact with the rotors), and then for the rear brakes to begin application slightly before the fronts (which helps the vehicle to stop in a straight line, and be less likely to exchange ends.)
The pressure differential switch activates a light which warns of a problem in the braking system, hopefully BEFORE half the brakes fail (which is usually how you'd otherwise notice it, without the pressure differential switch.)
To replace a combination valve with only an adjustable proportioning valve is a mistake, and will compromise brake safety. Do not do it!!"
A disk/disk should also work for a drum/drum. All they have is a safety valve and a proportioning valve inside.
John Strenk is offline
post #5 of 9 Old 10-23-2014, 06:28 PM Thread Starter
WindKnot
1977 CJ7
Interesting...
I called J&W Auto wrecking and after having a conversation with the mechanic there for 30 years, decided to go with the one at 4WD that says "for stock brakes". The mechanic at J&W concurred saying that the earlier Jeeps used the same valve.
I will update.
John, what was the source for your quotes? I'm not exactly convinced either way...
WindKnot is offline
post #6 of 9 Old 10-23-2014, 08:39 PM
John N
1981 CJ8
I'm pretty sure I have one, but in not sure how to know which one it is. I have a couple of proportioning valves. If I could figure which one it is, you can have it, if you want it. It came off a '76 CJ-7, so I know it was a 4 wheel drum valve.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #7 of 9 Old 10-24-2014, 07:54 AM Thread Starter
WindKnot
1977 CJ7
Thanks everyone. Right now I have a "new" one on its way. I'm going to try it first and then update this thread and probably the rebuild thread as well.
Thanks for the offers! Depending on the results, I may take you up on this!
Thanks again!
WindKnot is offline
post #8 of 9 Old 10-24-2014, 01:59 PM
John Strenk
1976 CJ5
. John, what was the source for your quotes? I'm not exactly convinced either way...
I took the quote off of another jeep forum.
I read the info in a chitons manual and I think you will find the same description in the FSM.
I you want real scoop, there is a company called Vans brakes that can help you.
However your buddy is right. All the early CJs use the same one. It changed later when disk brakes became an option.
post #9 of 9 Old 10-24-2014, 05:06 PM Thread Starter
WindKnot
1977 CJ7
Thanks.
I love exploring... and they're only brakes!
WindKnot is offline
