Alabama Engine Swap (PICS) - Page 3 - JeepForum.com
post #31 of 134 Old 04-02-2010, 01:20 AM
airtime262
1979 CJ7
Hey Jeff, nice build! I just stumbled upon this thread, seems like everyones jeep is having surgery this spring. Looks really nice, I'm jealous of the engine..(actually I'm jealous that you've gotten this far..lol) My motors out, got my sbc almost ready to go in, will prob test fit this weekend. I went with the M.O.R.E mounts, they're in getting powder coated now. (Fatman, I'll let you know how they work out). Jeff, what exhaust are you going with? It looks like GM manifolds, but I cant tell for sure. I want to go with a header sys, just not sure which one, any ideas? (not outside the frame, I have step bars). Keep up the good work, check back later...
Jeff-
Why do they call them apartments when they're so close together??-Steven Wright
"A parent's only as good as their dumbest kid. If one wins a Nobel Prize but the other gets robbed by a hooker, you failed."
airtime262 is offline
post #32 of 134 Old 04-02-2010, 07:16 AM Thread Starter
jcal73
jcal73's Avatar
2015 JK Wrangler
Jeff-
Thanks!
The exhaust manifolds are for a vette or something.
They are Rams horn center dump with a 2 1/2 inch outlet.
I actually picked those up from a guy on ebay so that I would not have to grind off any accessory brackets on the manifolds.
I did not want headers, I have them on a truck I have (Edelbrock Stainless) and can't stop the leaks.
It will have 2 1/2 duals with yet to be determined mufflers.
We want to see pics of yours.......
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #33 of 134 Old 04-02-2010, 09:38 AM
blackhawk51
1976 CJ5
if you don't mind me asking, i was just wondering if you could throw a ballpark figure of how much this has cost you?
ΜΟΛΩΝ ΛΑΒΕ
My CJ5 Restore and Build Thread
blackhawk51 is offline
post #34 of 134 Old 04-02-2010, 02:43 PM Thread Starter
jcal73
jcal73's Avatar
2015 JK Wrangler
Well that's a good question.....
The wife isn't here so I'll try go give a good answer and yes I have lost my mind!
So far just for the engine swap I have around $5300.00 in it, that number will continue to climb.
That is the FI setup and all. I still have to make a decision on a radiator, fans and Hoses.
I am building from scratch and even had to buy a bunch of brackets and bolts.
Before I am done I will be replacing the power steering pump, steering gear,gear bracket and shaft.
Also she is going to get hydroboost brakes and AC.
There are cheaper ways to do this, but I wanted to go all new.
Click on my build sheet in my signature and you will get and idea of what I'm talking about.
Now I'm depressed.
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #35 of 134 Old 04-04-2010, 05:34 PM Thread Starter
jcal73
jcal73's Avatar
2015 JK Wrangler
Made some progress Saturday.
Finished all of the plumbing at the rear of the jeep.
The extra rubber line that is loosely tied up is a temporary tank vent line to the front of the jeep.
I'm thinking of using copper to run the tank vent line permanently.
Looking at this I'm gonna add a clamp to the line from the liquid check valve to the roll over valve.
We also finished the wiring at the rear. Tank sender and fuel pump.
Fuel filter.
We wired in the speed sender and reverse as well.
Happy Easter
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #36 of 134 Old 04-06-2010, 02:31 AM
airtime262
1979 CJ7
Hey Jeff, thanks. I know what you mean about leaky headers, but I'm gonna give it another shot. Kind of hit a snag this weekend. My MORE mounts dont quite fit as I expected, gonna talk to them tomorrow. My engines still out, due to this, so I have to get a move on. Still have a little top end work to do, but I could still do that with the engine installed. Mine was planned as just a quick swap, with a restore coming in a year or 2. Well, those were the plans anyway. I'll try to get you some pics soon. Keep up the nice work
post #37 of 134 Old 04-07-2010, 08:13 AM Thread Starter
jcal73
jcal73's Avatar
2015 JK Wrangler
When I was doing my research for parts I was reading the PDF on the more mounts and they were saying that the engine can only go one place.
I was thinking that this could cause issues. That was the major factor in my choice of the Advanced Adapters mounts.
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #38 of 134 Old 04-07-2010, 09:54 AM
Performance
Project is looking good Jeff. I have been running the SBC conversion in my '79 CJ5 for over a year now. It works perfect with tons of power. I used the same Ram Horns for a while. The only real major problem that I ran into was excessive under hood heat. These manifolds have a hard time exiting heat and have been known for years to burn out valve cover gaskets. But, they do fit good for this conversion. I just recently switched to headers and couldn't believe the difference in power and heat. Just wanted to give you a heads up in case you ever have trouble. Also the headers work great with the serpentine brackets. The SBC has plenty of power in these CJs and it will be worth all the money and labor. All smiles, buddy!
Performance is offline
post #39 of 134 Old 04-07-2010, 04:51 PM Thread Starter
jcal73
jcal73's Avatar
2015 JK Wrangler
Good to see you back!
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #40 of 134 Old 04-08-2010, 02:26 AM
Performance
Jeff
Thanks, buddy. I have been so busy on projects and other forums. I started back on my Jeep project again, so Im back! Glad to see you are now working on the conversion! Looking good, buddy!
ERIC
post #41 of 134 Old 04-08-2010, 04:47 AM
airtime262
1979 CJ7
Hey Jeff,
I may have hit the panic button a little soon on the mounts. I did have to do a little cutting, a little bending, but with minimal tools. Got some pics I'll post soon, so happy now, I can at least try and stick the motor this weekend, cam and lifters came in 2 days, awesome!
post #42 of 134 Old 04-08-2010, 08:06 AM
Jim1611
Jim1611's Avatar
Just saw your thread today Jeff. Great job and even better that your boys are right in there helping out!! I like that part.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #43 of 134 Old 04-15-2010, 01:37 PM
skclark
1982 CJ7
jealous
I'm jealous of your awesome 350 AND that red Alabama clay! I'm in the land of sand here in FL.
Very nice man. Thanks again for the paint suggestion. I love that fine texture paint. Did my whole roll bar and it came out like a factory finish.
skclark is offline
post #44 of 134 Old 04-15-2010, 08:22 PM Thread Starter
jcal73
jcal73's Avatar
2015 JK Wrangler
Thanks! My boys are my life.
I think that half of the red clay is still under the jeep!
The other half has been tracked in the house by the boys!
We made a little more progress last weekend. We installed the FI harness and the oil and temp gauge hook-ups.
We then drilled for and installed the dash insert so the inside of the jeep is done!
We tested all of the electrical hook-ups as well as the fuel system.
No leeks and all of the functions work that we wired up!
Still working under the hood to clean up the wires and re-route stuff.
The jeep will be lonely this weekend as I get to work.
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #45 of 134 Old 04-16-2010, 01:00 AM
Skerr
Ah, yeah... that work thing! That gets in the way for me too!!
Kerrdog
Go Fish! <*////><
Skerr is offline
Engine swap Pics Hardy350 Jeep CJ Forum 7 06-08-2010 11:46 PM
Engine swap or engine and transmission swap Notplayn Jeep CJ Forum 3 07-13-2008 08:31 PM
Pics of my engine swap (halfway through) -- 258 4.2L mmerlina Jeep CJ Forum 12 02-11-2008 07:42 PM
Tranny swap now with future engine swap in mind gestuhlm Jeep CJ Forum 1 04-23-2006 08:49 PM
Stolen CJ7 in Alabama tadslc Jeep CJ Forum 14 02-03-2004 01:37 AM
