Airbag suspension -
post #1 of 3 Old 10-23-2003, 06:02 PM Thread Starter
DZLCJ7's Avatar
1981 CJ7
Airbag suspension
I'm thinking of doing a SOA conversion on my CJ7 and i was thinking that i could run air bags on the suspension to make it flex when off road but firm when on road, are there any draw backs to air bags or this idea?
1981 CJ7 w/ IH Dana 44s f/r, 3.07 gears, NV4500, 3.9L 4BT CTD, Dana 300, 31" Procomp MTs, 3" of lift, soon to get D60/14Bolt & 37s
1991 YJ
DZLCJ7 is offline
post #2 of 3 Old 10-23-2003, 10:03 PM
magicmudder's Avatar
The main drawbacks are the price, added body roll, and something rupturing the airbag itself. There are some writeups on airbag suspension for jeeps on the internet and also in some of the latest off road magazines. In the latest JP or 4-wheeler there was a guy running it on a jeep and punctured one of them, but he just added a coil back in until he finished the trail.
This site has a good system that eliminates body roll and automatically adjusts on the road, but if you're on the trails alot, you would probably want one that was independantly controlled at all 4 corners. If you've got the $ then it's not a bad idea.
Now for the advantages
84 CJ7, 258, shackle reversal, 4.56 gears, lockrite , moser one piece axles, 37" SSR's
magicmudder is offline
post #3 of 3 Old 10-24-2003, 06:10 AM
kurdt's Avatar
the airbag system is designed for a TJ... you could design a link suspension to run it, but why not just run coilovers (expensive) or 1/4 elliptic springs (cheap) in the rear if you're going to bother with a linked suspension? sticking an airbag between your frame and leaf spring isn't going to improve your articulation any...
personally if you want more flex, SOA your front leafs and do a 4 link with 1/4 elliptical springs... avalanche has an overpriced kit for this at
or you can piece together rodends, spuds, jam nuts and some 1.5 .250 wall DOM, brackets and do it yourself... you need welding and fabrication knowledge
take it easy
00 Lexus GS300
97 Suburban 6.5 Turbo Diesel 6" lift 35" BFG A/Ts
81 CJ-7 rock buggy, injected 350, built th350, 3.8 atlas II w/ ebrake, d60 front 1.5 stubs w/ detroit, 4.88 gears, discs, d70 rear w/ detroit, 4.88 gears, discs, 37" krawlers, 17" trailready beadlocks, 16" king coilovers, 4 link f/r, 12+ point cage, howe full hydraulic steering, fabbed by owner :D
kurdt is offline
In order to be able to post messages on the forums, you must first register.
Suspension ??? my84cj7 Jeep CJ Forum 9 04-24-2009 11:31 AM
'76 vs '74 CJ5 w/ regards to suspension utclimber Jeep CJ Forum 1 07-14-2007 08:33 AM
CJ suspension help DuggerCJ Jeep CJ Forum 11 06-05-2007 06:56 PM
New Suspension terp6977 Jeep CJ Forum 1 02-20-2007 01:19 AM
cj suspension cityofcompton3 Jeep CJ Forum 19 08-10-2005 05:38 PM
