Air Injection Manifold - Plugging it up - JeepForum.com
post #1 of 8 Old 06-27-2008, 01:24 PM Thread Starter
sgtbookie
Does anyone have a recommendation for plugging the holes in the exhaust manifold once the air injection system is removed? The rest of the air injection system was removed, but the manifold remains, and is currently just capped off where the hose connected to it at the back of the valve cover. I'd like to remove it without destroying it, if possible.
82 CJ5 - 258.
Thanks,
Jason
2005 LJ Rubicon Sahara #380
sgtbookie is offline
post #2 of 8 Old 06-27-2008, 01:33 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
I used JB weld, let it set up over night, works fine.
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #3 of 8 Old 06-27-2008, 01:37 PM Thread Starter
sgtbookie
Thanks Slik for the reply.
I had considered JB, but wasnt sure if it would be able to withstand the head of the exhaust manifold. DId you remove the air intake manifold and then plug the holes?
post #4 of 8 Old 06-27-2008, 01:40 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Yes, I pulled everything off before I thought about the holes and then just put the JB weld on and it worked
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #5 of 8 Old 06-27-2008, 04:44 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Remove the injector tubes, then cap the holes with brass plugs. I would also keep all the injection stuff you pull off. This allows you to remove the plugs and re-install the equipment if you decide to sell it or if for some reason the environazi's catch up with you.
jeepdaddy2000 is offline
post #6 of 8 Old 06-27-2008, 04:45 PM Thread Starter
sgtbookie
Where can I find brass plugs? Yea, I have a box in the garage with all the enviro-nazi gear in it. Rest of the emissions are staying in place.
post #7 of 8 Old 06-27-2008, 11:12 PM
1986cj
mine from a 79 has brass plugs in it any good hardware store will have brass plugs
1986cj is offline
post #8 of 8 Old 03-01-2010, 08:47 PM
BigAl1979CJ
1979 CJ7
Same issue except 304, what size brass plugs?
BigAl1979CJ is offline
Plugging smog exhaust manifold bolts - How? cfernandez Jeep CJ Forum 9 01-21-2009 11:19 PM
Plugging Clifford Headers 8679cjs Jeep CJ Forum 4 05-07-2008 10:39 AM
JB Weld air injection ports on exhaust manifold? TexasGuns Jeep CJ Forum 4 04-02-2008 10:23 PM
Manifold Question for Howell Fuel Injection goat24 Jeep CJ Forum 0 05-20-2006 10:41 PM
what is the vac. advance plugging into? redlinedcj Jeep CJ Forum 12 09-27-2005 05:03 PM
