Air cleaner stud for MC2100 - JeepForum.com
post #1 of 12 Old 08-09-2013, 12:43 PM Thread Starter
HeathFinnie
1976 CJ5
Does anyone know the correct size? I need to get one...
Thanks!
HeathFinnie is offline
post #2 of 12 Old 08-09-2013, 01:02 PM
CSP
1/4"
CSP is offline
post #3 of 12 Old 08-09-2013, 01:16 PM Thread Starter
HeathFinnie
1976 CJ5
Thanks! What's the correct length?
post #4 of 12 Old 08-09-2013, 01:25 PM
CSP
I have no idea. Get a length of allthread (cheap) and use it to determine the right length.
Just about every carb/GM throttle body out there uses 1/4", so it's something that wouldn't be hard to find in a junkyard.
CSP is offline
post #5 of 12 Old 08-09-2013, 01:28 PM
capt205
1983 CJ7
I bought a length of threaded rod at Home Depot, and cut mine to the size needed.
capt205 is offline
post #6 of 12 Old 08-09-2013, 01:41 PM Thread Starter
HeathFinnie
1976 CJ5
Great point. Thanks!
post #7 of 12 Old 08-09-2013, 02:04 PM
OleBlue73
1973 CJ5
Length will depend on your air cleaner. That's why all thread is your ticket
1973 CJ5, 304, T15, D20
2009 JKU, Rubicon
2005 TJ, X, 4.0, 6 speed
OleBlue73 is offline
post #8 of 12 Old 08-09-2013, 04:45 PM
skizriz
1978 CJ7
Why am i thinking it is 5/16?
Made mine from all thread also.
Sent from my HTC One SV using JeepForum
skizriz is offline
post #9 of 12 Old 08-09-2013, 08:05 PM
CJ51973
CJ51973's Avatar
Mine is 1/4-20
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #10 of 12 Old 08-10-2013, 06:49 AM
tjeep1
1978 CJ7
i lock my stud to the carb with a nut where the stud screws in the top of the carb for vibraton so it stays tight
tjeep1 is offline
post #11 of 12 Old 08-10-2013, 07:56 AM
Oily
I am needing one also. It seems to me that it is fine threads on the MC2100 and the air cleaner end is coarse threads (for the common decorative nut).
I just bought a Mr Gasket 9" chrome air cleaner which has a 1/4 short length of coarse all threads. It will not screw into the carb base.
Oily is offline
post #12 of 12 Old 08-10-2013, 08:08 AM
colojeepguy
1970 CJ5
If my (admittedly fuzzy) memory serves, this is correct.
I believe some of the Ford 2 bbls had a stepped down stud, from 5/16 to 1/4.
"It's better to have loved and lost, than to live with a psycho the rest of your life"
colojeepguy is offline
