Air cleaner for the Redline/Weber? - Page 2 - JeepForum.com
post #16 of 25 Old 07-17-2013, 04:13 PM
uptillnow
uptillnow's Avatar
Keith,
Your set-up looks like you are using their 99010.600 Air Filter adapter. see attached
The earlier post using the 99010.457 is for a "universal" 5" or so opening on the O.E. assembly.
Just sayin...
your set-up is sweet.
UPTILLNOW
uptillnow is offline
post #17 of 25 Old 07-17-2013, 05:10 PM
jcalhoon84
1980 CJ5
Originally Posted by wellmax
might be easy to do if you had the original air cleaner.
but my old jeep is like what most of us get, I have a 1984 model that had been through a number of PO.
so I was lucky to have much of anything left.
so I got the std carb but some piece of junk air filter.
so when I got the weber I also order the air filter and it's worked ok for me,
advance auto has the replacement filters or can order them for around 19.
I also run a thick foam prefilter around the air filter, this makes the air filter last much longer.
like a lawn mower you can wash out, clean and lightly oil the foam pre filter
has been running good using this method for years.
Do you have a part number for the filter? I can't seem to find them anywhere but online.
jcalhoon84 is offline
post #18 of 25 Old 07-17-2013, 05:26 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by JustDandee View Post
I would like to pop in on a quick question on the OEM housing- Keith maybe you can answer? Does the housing you have on the 6 cyl -the same as the one used on the 4 cyl? It looks very, very similar to my 83' that I have on the 2.5. If I could make mine look like yours I think I could pass visual at the emission station with the weber. The only part I would need to know is what is the diameter of oem tube going to the carb. If height is an issue I could just trim the down tube length to compensate for the elevation change.
Thanks
Dan
I think the assemblies are the same but the 4 cylinder has a much longer tube going to the top of the carburator.
John Strenk is offline
post #19 of 25 Old 07-17-2013, 08:45 PM Thread Starter
SoK66
2009 JK Wrangler
Ok, so I've got 99010.457 on the way. What year CJ air cleaner will adapt to this one? I can simply get an Edelbrock shiny one, but a factory unit would be preferable.
SoK66 is offline
post #20 of 25 Old 07-17-2013, 09:58 PM
GlennLever
GlennLever's Avatar
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #21 of 25 Old 07-17-2013, 10:37 PM
Dwarf
1987 YJ Wrangler
Those are geoguous engine bays!
Dwarf is offline
post #22 of 25 Old 07-18-2013, 06:52 AM
keith460
Jeep. There's Only One
keith460's Avatar
Originally Posted by uptillnow View Post
Keith,
Just sayin...
UPTILLNOW
The adapter for the Weber carb to factory air cleaner can be bought at carbsunlimited.com and will fit both the 32/36 and 38 DGV carbs. p/n:99010.600 found here: http://www.carburetion.com/Weber/adaptors2.htm
1984 CJ-7 Renegade
keith460 is offline
post #23 of 25 Old 07-25-2013, 02:33 PM Thread Starter
SoK66
2009 JK Wrangler
I found an original CJ 1bbl housing in reasonable condition that has the canister purge port near the opening of the trumpet, an EGR filter port in the rear and a mechanical heat riser. All this seems close to what I've been able to determine was stock on the 232 in '76. Hard to pin this down. Anyway I ordered the 99010.600 adapter and will have a go at making this all work with the Weber. For the time being I got their 5 1/8" universal adapter and threw a parts store Edelbrock housing on.
SoK66 is offline
post #24 of 25 Old 07-25-2013, 04:41 PM
John Strenk
1976 CJ5
I got one of those also off my 76. It might not work with power brakes...
post #25 of 25 Old 07-25-2013, 05:34 PM Thread Starter
SoK66
2009 JK Wrangler
Thanks. Mine doesn't have power brakes so we should be cool.
SoK66 is offline
