Air cleaner for the Redline/Weber? - JeepForum.com
post #1 of 25 Old 07-12-2013, 07:36 PM Thread Starter
SoK66
2009 JK Wrangler
About ten years ago Collins Bros sold an emissions legal air cleaner assembly for the Redline Weber carbs. Had a proper heat riser, used a paper element, etc. They don't seem to carry them any longer, anyone know of a source? I'd like to get one and toss the little POS that came with the carb.
SoK66 is online now
post #2 of 25 Old 07-12-2013, 11:32 PM
HALOjmpr
You want what, when?
HALOjmpr's Avatar
1982 CJ7
Buy the adapter # 99010-457 ($26.95) and it allows you to use the stock air cleaner for your CJ and keep all your attachments intact.
It's available here!
http://www.carburetion.com/Weber/weberpartsair.asp
"It's not about how hard you can hit, it's about how hard you can get hit and keep moving forward!"
HALOjmpr is offline
post #3 of 25 Old 07-12-2013, 11:37 PM
kovic
1983 CJ5
^^ is there a benefit to having the stock air cleaner on rather than the one that comes with the weber?
kov
kovic is offline
post #4 of 25 Old 07-13-2013, 02:20 AM
BagusJeep
1981 CJ7
Huge benefits.
The Thermostatic Air Cleaner gives you cold air to the engine, not the hot stuff under the hood. On start up it gives you warm air pretty quickly.
It has a large paper element that is cheap to change and filters the air properly.
When you are in the water and mud up to your axles it will not let water into the engine
You can't say any of that about the POS chrome thing that comes from Redline. If I could find a TAC out here that fitted I would buy the adapter. In the day we changed them because we were deluded, thinking it would boost performance.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #5 of 25 Old 07-13-2013, 08:23 AM
WindKnot
1977 CJ7
Sometimes it comes as a shock to us, but the factory engineers usually knew what they were doing. They built an air filter assembly specific to the Jeep. The engineers at Weber didn't have that luxury. They have no idea what vehicle their carburetor is going on and what kind of clearances they have under the hood or even if there is a hood.
Using the adapter allows all the other parts related to fit. Bagus is right and I'd love to find a factory breather assembly for mine.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #6 of 25 Old 07-13-2013, 08:29 AM Thread Starter
SoK66
2009 JK Wrangler
Thanks, I'll check it out.
SoK66 is online now
post #7 of 25 Old 07-13-2013, 09:19 AM
prismfisher
1982 CJ8
air cleaner
I put one on my weber. Easy Peasy and worked mucho better than the crap they sent me......
prismfisher is offline
post #8 of 25 Old 07-13-2013, 09:44 AM
kovic
1983 CJ5
Good thing I kept My old assembly, was so close to tossing it. Maybe I'll clean her up, get the adapter and throw her on.
kov
kovic is offline
post #9 of 25 Old 07-13-2013, 09:48 AM
wellmax
might be easy to do if you had the original air cleaner.
but my old jeep is like what most of us get, I have a 1984 model that had been through a number of PO.
so I was lucky to have much of anything left.
so I got the std carb but some piece of junk air filter.
so when I got the weber I also order the air filter and it's worked ok for me,
advance auto has the replacement filters or can order them for around 19.
I also run a thick foam prefilter around the air filter, this makes the air filter last much longer.
like a lawn mower you can wash out, clean and lightly oil the foam pre filter
has been running good using this method for years.
wellmax is offline
post #10 of 25 Old 07-13-2013, 10:01 AM
kovic
1983 CJ5
Do you guys know if they sell the bolts required to connect the original assembly to the adapter, I believe I tossed that with the BBD.
And I found the rest of what I need here: http://www.ebay.com/itm/Jeep-Cj-Lare...b9e93f&vxp=mtr
And is this the correct adapter? Seems it may have the bolt included.http://www.webercarbsdirect.com/product_p/a1000.htm
kov
kovic is offline
post #11 of 25 Old 07-13-2013, 10:22 AM
keith460
Jeep. There's Only One
keith460's Avatar
Yes, that is the correct adapter and the hot air flex pipe off of the exhaust manifold and vinyl air intake duct.
You must raise the OEM air cleaner 1" off the valve cover because the Weber carbs sit exactly 1" higher than the Carter BBD's.
1984 CJ-7 Renegade
keith460 is online now
post #12 of 25 Old 07-13-2013, 10:32 AM
kovic
1983 CJ5
Ok, yea the description was saying I need to check the hood clearance before ordering, and you say the weber sits even higher? SO with the higher sitting weber, and the even higher adapter, you think i will still be clear?. And man, your air cleaner looks different than mine.
Also keith, at the very end of the air cleaner, that little greyish housing that sits on the top(trap door motor?), You have a rubber hose going to it, and that rubber hose goes to some kind of in line thing, mine was yellow, but its long gone, what is that and is it needed?
thanks
kov
kovic is offline
post #13 of 25 Old 07-13-2013, 04:42 PM Thread Starter
SoK66
2009 JK Wrangler
My next question is, what air cleaner assy would work best with my 232, adapted to a 2 bbl manifold off a 258? I got the Weber kit for the 258 so I didn't have to run the 2bbl into 1bbl adapter. Works great, btw. When I dragged the poor CJ home 11 years ago it had some old oil bath air cleaner off heaven knows what. Wasn't a CJ unit at all. So, looks like I can an ai cleaner assembly off a 258 that came stock with a Carter 2bbl, but which year would be best? Can I assume the 76 - 79 might be the ticket?
SoK66 is online now
post #14 of 25 Old 07-14-2013, 07:12 AM
keith460
keith460's Avatar
thanks
kov
The air cleaner is only different design if you have power brakes. Power brake booster interferes with the manual brake type air cleaner.
You may be referring to the Delay Vacuum Valve that is yellow/white in color. It slowly activates the vacuum motor on top to gently open and close the flap. There is also a gray/white one for the other vacuum motor.
1984 CJ-7 Renegade
post #15 of 25 Old 07-14-2013, 08:55 AM
JustDandee
1983 CJ7
I would like to pop in on a quick question on the OEM housing- Keith maybe you can answer? Does the housing you have on the 6 cyl -the same as the one used on the 4 cyl? It looks very, very similar to my 83' that I have on the 2.5. If I could make mine look like yours I think I could pass visual at the emission station with the weber. The only part I would need to know is what is the diameter of oem tube going to the carb. If height is an issue I could just trim the down tube length to compensate for the elevation change.
Thanks
Dan
JustDandee is offline
