Air Cleaner lid gasket replacement? - JeepForum.com
post #1 of 7 Old 10-10-2012, 12:38 AM Thread Starter
monomoy4
1979 CJ7
Hey All,
I need to replace the gasket for my 79 CJ7's air cleaner lid...not the smaller gasket at the carburetor, but the large circular deal on top. I've been unable to find it anywhere...any ideas where I can get one?
Air cleaner is the one that fits on the stock Carter 2 barrel. Thanks for your help!
monomoy4 is offline
post #2 of 7 Old 10-10-2012, 01:22 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I just used standard weather-stripping from the hardware store.
Matt
Matt1981CJ7 is offline
post #3 of 7 Old 10-10-2012, 03:41 AM
5-90
5-90's Avatar
1988 XJ Cherokee
Originally Posted by monomoy4 View Post
Hey All,
What I usually did?
Use a screwdriver to dig out the old gasket and any collected crud.
Cut a Popsicle stick down in width until it will fit in the groove, and has shoulders to stop about halfway down.
Squirt in a bead of RTV, then use the modified Popsicle stick to smooth it out.
Let it cure overnight (if you need it more quickly, you can set your oven to "warm" and have it cured through in about an hour. The lowest setting on your oven shouldn't boil water, but will be about twice room temperature.
The RTV can be scraped out of the groove and this repeated as necessary, but I've found that it lasts longer than the typical gasket or foam Wx-strip will - by probably twice. And, it's easier to keep clean, when the bead has been properly smoothed.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #4 of 7 Old 10-10-2012, 06:31 AM
MoC
Foam backer rod from Lowes / Home Depot fits very close to OEM.
http://www.jeepforum.com/forum/f8/mo...0/index16.html
MoC is offline
post #5 of 7 Old 10-10-2012, 07:07 AM
Ollie09
1983 CJ7
This is what I used on my 83'. It is not an exact fit, but it worked very well.
I have restored a couple of Corvettes over the years and could buy just about any part, I am surprised and disappointed at the lack of after market reproduction parts for the Jeep.
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Ollie09 is offline
post #6 of 7 Old 10-12-2012, 03:05 PM Thread Starter
monomoy4
1979 CJ7
All excellent ideas! Much appreciated!
Is the purpose of the seal to be airtight? I wonder if the Corvette or RTV ideas may be better if that's the purpose...
1979 CJ7, 3 speed manual, 258 Straight 6, Carter 2 Barrel
2003 WJ, Laredo 4x4
monomoy4 is offline
post #7 of 7 Old 10-12-2012, 03:36 PM
lucdog
lucdog's Avatar
1980 CJ5
Yes, you want all the air going in to be filtered. I would use what Matt used ,
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
air cleaner , carter , cj7 , gasket
