Air cleaner housing for an 84 cj7 - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Air cleaner housing for an 84 cj7
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 11-19-2009, 02:00 PM   #16
mastercraftka
mastercraftka's Avatar
Learn something new everyday that is why I am in here. Thanks guys, Mike N.
mastercraftka is offline   Reply With Quote Quick reply to this message
Unread 11-19-2009, 02:16 PM   #17
longboy
2006 WK
Yes, all the US ones I have seen have the two holes for the pulse air system.
I would figure only the 1982 and up have them, isn't that when they switched from the air pump to pulse air injection?
2006 5.7l WK
longboy is offline   Reply With Quote Quick reply to this message
Unread 11-19-2009, 03:35 PM   #18
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
In the California market for sure I think. Different areas had different emissions. My Canadian 86 CJ7 had a plain air filter with just the TAC and no catalytic converter, it registers as a 'Utility Vehicle'. YJ's got the fancy one.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 11-19-2009, 05:38 PM   #19
keith460
Jeep. There's Only One
keith460's Avatar
Power brake air cleaner that has the upstream and downstream tubes plugged with rubber stoppers (can't see them though).
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote Quick reply to this message
Unread 02-07-2010, 10:48 PM   #20
hddusen
anyone out there consider/ or have made an air cleaner assembly? my cj5 has those cool and pointless 4" filter stuffed on top of the carb and my cj7 build came with nothing, with a little sheet steel couldn't something be fashioned that emission controls and line could be run too?
BVD
hddusen is offline   Reply With Quote Quick reply to this message
Unread 02-08-2010, 07:44 AM   #21
John Strenk
John Strenk's Avatar
1976 CJ5
BVD
Sure why not. I've done it before myself. Just make sure your seal on the air cleaner filter is good and tight. The stock ones usually have braces stamped in so you only need one bolt to get a good tight seal.
John Strenk is offline   Reply With Quote Quick reply to this message
Unread 02-08-2010, 12:49 PM   #22
mastercraftka
John, Do you know any places that sell after market stock style air cleaner housings?
Unread 02-08-2010, 03:33 PM   #23
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Here's a non-power. I believe I may have a couple of these.
http://www.jeepforum.com/forum/f126/...sembly-931473/
Here are 3 for power brakes:
http://www.jeepforum.com/forum/f126/...brakes-931456/
This is how NAXJA Midwest Chapter elected officials like to treat their resident users and former multi-year supporters.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline   Reply With Quote Quick reply to this message
Unread 02-08-2010, 04:31 PM   #24
pu70
If you still need one for power brakes send me a PM and I will go in the atic and see if I still have one.
pu70 is offline   Reply With Quote Quick reply to this message
Unread 02-08-2010, 05:04 PM   #25
Jonesie
1981 CJ5
While we're at it, I need an air cleaner for a V8 (360). Everything I see on eBay that says V8 seems to be the non-power I6 cleaner. I know the V8 is supposed to have 2 vacuum motors on it.
I have a bid on an actual V8 cleaner on eBay currently, but failing that one, I may be in some trouble.
Thanks - David
Jonesie
1981 Jeep CJ5
Working on a 360 V8, T-176, D300 Swap
Jonesie is offline   Reply With Quote Quick reply to this message
