Air cleaner housing for an 84 cj7 - JeepForum.com
post #1 of 25 Old 11-19-2009, 09:46 AM Thread Starter
mastercraftka
mastercraftka's Avatar
I can't seem to find a stock replacement air cleaner housing for my 84 CJ7. I see plenty of K&N and stuff but i just want a standard air cleaner housing. When i bought this this jeep it had a dinky little 4" air cleaner and i want to go back stock so i can get the breather tube hooked back up. Any sources out there I must be looking in the wrong places. Thanks Mike
mastercraftka is offline
post #2 of 25 Old 11-19-2009, 10:24 AM
craigb86
Ebay, craigslist, or the wanted section going to be your best bet. We also need to know some info about your jeep. What engine? Power Brake Booster?
Craig
craigb86 is offline
post #3 of 25 Old 11-19-2009, 10:26 AM Thread Starter
mastercraftka
cj7 258 cu I don't think it has a power brake booster.
post #4 of 25 Old 11-19-2009, 11:29 AM
craigb86
craigb86 is offline
post #5 of 25 Old 11-19-2009, 11:48 AM Thread Starter
mastercraftka
dang your good!! thanks!
post #6 of 25 Old 11-19-2009, 11:49 AM
Mike Romain
You 'might' have manual brakes, but you better check because the two air filters don't mix or match.
Go look at the brake master cylinder to see if it is bolted directly to the firewall or if there is a big round vacuum booster between it and the firewall.
Mike
Mike Romain is offline
post #7 of 25 Old 11-19-2009, 11:55 AM Thread Starter
mastercraftka
straight to the firewall
post #8 of 25 Old 11-19-2009, 12:00 PM
Mike Romain
Manual brakes then.
Just a thought, if you ever maybe wanted more stopping power, it is real easy to switch to power brakes so you might want to just get the air filter for power brakes now. That one will work for both systems, the manual brake air filter only works on them.
Mike
post #9 of 25 Old 11-19-2009, 12:14 PM Thread Starter
mastercraftka
So what is the difference in the two?
post #10 of 25 Old 11-19-2009, 12:17 PM
Mike Romain
One sits on the carb, the manual one. The other sits on the valve cover with a snout over the carb so there is room for the brake master to move forward to fit the booster behind it.
Mike
post #11 of 25 Old 11-19-2009, 12:30 PM
craigb86
Here is a power version. If I remember correctly a 1987-1992 YJ air clears work also. Might have luck at finding someone parting out a YJ or finding one in a junk yard.
Jeep CJ Air Cleaner Assembly
Craig
craigb86 is offline
post #12 of 25 Old 11-19-2009, 12:34 PM
ElZorro
My friend is a former AMC mechanic, and he said it's just a pacer air cleaner. If you have trouble finding one using jeep as a search term try pacer in it's place.
ElZorro is offline
post #13 of 25 Old 11-19-2009, 12:36 PM
Mike Romain
Craig
Up here in Canada, The 87-92 YJ one will have a couple holes in the bottom that can be plugged for the pulse air tubes and an extra flap on the intake to prevent vapor loss when the engine is off, but it will fit on and work fine.
I think some US ones have these extra holes too, depending on what emissions market they were sold for.
Mike
post #14 of 25 Old 11-19-2009, 12:56 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Yes, all the US ones I have seen have the two holes for the pulse air system.
John Strenk is offline
post #15 of 25 Old 11-19-2009, 12:59 PM
Mike Romain
A buddy figured out Remy Martin corks fit perfectly. Not all the CJ ones have them though right?
Mike
Air Cleaner Assembly/Housing for sale? kapsig431 Jeep CJ Forum 3 11-18-2013 05:58 PM
Air Cleaner Housing 81CJUSMC Jeep CJ Forum 7 02-17-2008 08:03 AM
carb cleaner vs. brake cleaner Floridazed Jeep CJ Forum 7 01-03-2008 02:57 PM
defrost duct, air cleaner housing gtrpup2 Jeep CJ Forum 4 11-16-2006 04:42 AM
