Air cleaner help!!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Air cleaner help!!!!
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectRIGID LED Light Blowout Sale - All Sizes, All Series, all Toxic Brakes - 3000 PSI Braided Stainless Steel Brake Line
Unread 11-10-2014, 01:23 PM   #1
rokbrigade
I have an '84 jeep cj7 258, I would like to know if anyone has a schematic or diagram of the dual wire that comes off the air cleaner at about 11:00 from the inlet tube. It has a dualplugin. Sometimes these 2 wires are bare because the insulatioin on each wire has worn or burned off. I just need to know what color are the wires that plug into these 2 wires, and where do they come from.
rokbrigade is offline   Reply With Quote Quick reply to this message
Unread 11-10-2014, 03:04 PM   #2
cmsurfer
I believe what you are referring to is the Thermal Electric Switch (TES?). You can see some info here http://home.sprynet.com/~dale02/aircl.htm#tes.
In for the answer as well since I recently put a stock air cleaner on my '85 and cannot find the plug in the engine compartment...
cmsurfer is offline   Reply With Quote Quick reply to this message
