Air cleaner - JeepForum.com
post #1 of 9 Old 03-22-2013, 06:56 PM Thread Starter
cmlat666
1979 CJ7
Air cleaner
Just bought a 79 jeep cj7 and the carb is a bit naked.... no air cleaner. As far as I know its the stock 2 barrel carb whatever model that may be havent had time to research yet. New to the whole jeep thing and just trying to figure out what other air cleaner is a direct bolt on and where to find.
cmlat666 is offline
post #2 of 9 Old 03-22-2013, 07:01 PM Thread Starter
cmlat666
1979 CJ7
forgot... 5.0 304 motor in it
cmlat666 is offline
post #3 of 9 Old 03-22-2013, 09:23 PM
74Maverick
Its a ford carb so most fords will work just about any from the 70s or 80s, like vans, trucks, lincolns and such. Still id measure to be sure. Also get an idea of you choke linkage and make sure it clears. When I hooked up a manual choke kit to mine I had to raise the air cleaner a half inch. You could also measure it and get something off the shelf from autozone. Mine is an edelbrock, I think its either 12 or 14 inches diameter.
The Last Great American Hero... the demi-god... to which speed means freedom of the soul.
74Maverick is offline
post #4 of 9 Old 03-22-2013, 09:33 PM
lucdog
lucdog's Avatar
1980 CJ5
Don't limit yourself to Ford aircleaners. Pretty much any Quadrajet, Holley and Edlebrock will have the same diameter for the air cleaner, I believe it's a 5.250 diameter.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #5 of 9 Old 03-22-2013, 11:13 PM
BagusJeep
1981 CJ7
Scour the junkyards for a TAC, Thermostatic Air Cleaner. Once hooked up to the right valves and vacuum it will allow you to have warm air on a cold morning and ducted cold air at other times.
The aftermarket chrome pancakes look nice on a street queen but when you are splashing through rivers they will happily let water into your engine and you will have cold air on cold mornings and hot air on hot days.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #6 of 9 Old 03-23-2013, 02:29 PM Thread Starter
cmlat666
1979 CJ7
got an air filter and stud kit. now noticing the threads are missing in the carb...... any suggestions just thinking about jb welding the stud in as a temp fix. plan to replace carb later
cmlat666 is offline
post #7 of 9 Old 03-23-2013, 02:47 PM
74Maverick
Tap it. Might have to weld a different bolt threads to your stud or something. But either tap it with the carb removed or do it very cautiously maybe with a peice of cardboard to keep any shavings out of the carb.
post #8 of 9 Old 03-23-2013, 03:14 PM Thread Starter
cmlat666
1979 CJ7
nothing there to tap except the outer diameter and its an 11/32 still trying to find a tap worth running into it
cmlat666 is offline
post #9 of 9 Old 03-23-2013, 07:43 PM Thread Starter
cmlat666
1979 CJ7
got it all figured out and fixed up thanks for the help
cmlat666 is offline
79 , air , cj , cleaner
