AHHHH! Thought I had this... Differential Guys, Help! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > AHHHH! Thought I had this... Differential Guys, Help!
The ULTIMATE "Selectable" Locker System! Brough**Flash Weekend Sale** Rockridge4wd.com Only!RIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread 08-25-2015, 07:46 AM   #1
Skerr
This is my 2nd time doing this, changing ring and pinion gears. Both axles are/were AMC20s, both were 2.73 to xxx. This one is going to 4.56, and I am installing a Lincoln Locker.
What are these clutch-pak looking thingys!? I don't remember them when I did the 5!
Do they go back in with the Powertrax??
Does it matter that I am missing a retainer clip from one pak?
Side specific???
Is this LSD???
Here's where I am...
As they came out of the carrier...
Missing retainer clip from one side...
THANK YOU! THANK YOU! THANK YOU!!
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 08-25-2015, 07:50 AM   #2
stgil
1982 CJ7
Cj
OEM LSD (track loc)... The clip retainer is a mandatory for LSD in order to do is job...
Regards,
Gilles
FULL DANA 30 REBUILD->http://www.jeepforum.com/forum/f8/cj7-dana-30-full-rebuilt-setup-part-i-1121189
'82 CJ7 LAREDO REBUILD->http://www.jeepforum.com/forum/f8/82-cj7-laredo-diesel-restoration-1179198/
stgil is online now   Reply With Quote Quick reply to this message
Unread 08-25-2015, 09:22 AM   #3
Skerr
Regards,
Gilles
Merci, Gilles. I'm thinking they would NOT be reinstalled with a locker??
Kerrdog
Go Fish! <*////><
Unread 08-25-2015, 09:25 AM   #4
John Strenk
John Strenk's Avatar
1976 CJ5
Will the powertrax fit in a a LSD housing? an open AMC 20 housing is a little different...
John Strenk is offline   Reply With Quote Quick reply to this message
Unread 08-25-2015, 09:31 AM   #5
Skerr
Danged if I KNOW John?? I went back and looked at my build where I changed out the gears in Clay's 5. The carrier is MUCH different. Seems like if I don't put the clutch paks back in then the locker will flop side to side inside the carrier.
The locker (same type of locker) in Clay's 5 surely causes excessive tire wear, which I don't like, but also surely gives me the traction I need in the muddy deer woods.
I will GLADLY acquiesce to the advice of you Veterans.
edit* Going back and looking at the pic you posted. I see what you mean. I have not tried to fit it inside yet.
Kerrdog
Go Fish! <*////><
Unread 08-25-2015, 09:44 AM   #6
John Strenk
1976 CJ5
Might want to check out this thread before you go further...
http://www.jeepforum.com/forum/f8/tr...stion-3349169/
Unread 08-25-2015, 10:41 AM   #7
stgil
1982 CJ7
I'm agree with John !
Regards ,
Gilles
Unread 08-25-2015, 10:49 AM   #8
Skerr
Wish I had a picture of Calvin with a black cloud over his head...
Why can't anything in my life just be straight up?
Thank you, John, for the link. I am a bit embarrassed that you have this thread so close to mine. I didn't search before asking my question. Apologies to All...
Just for the game, I am bench installing the locker to "see" what it looks like. The Powertrax install manual makes reference to open diffs. The link included in John's reply is for a Powertrax TL carrier, for ~$500. Which is cool. But I don't have it, even if I pimp myself!
Everything is sitting on the table while wifey is gone. Back in a bit...
Kerrdog
Go Fish! <*////><
Unread 08-25-2015, 10:51 AM   #9
TIPPEDITOVER
In the garage
TIPPEDITOVER's Avatar
1978 CJ5
The PowerTrax is the only lunchbox locker I know of that will fit in the trac lock case and it is stupid expensive at over $500. A full case bulletproof Detroit is only $600ish. PowerTrax can be found in the link below.
http://www.quadratec.com/products/16104_101.htm
Shaun
1978 CJ5 Wheeler
1996 Grand Cherokee Laredo 4.0 all stock daily driver
TIPPEDITOVER is offline   Reply With Quote Quick reply to this message
Unread 08-25-2015, 11:07 AM   #10
Skerr
Yeah... thanks, Shaun. I was just coming back to say you CAN easily install a non-TL Lincoln locker in a Trac-Loc carrier, but maybe 3/4" of gap in the middle. So it wouldn't work even if it was done completely by accident.
Guess I am ordering a clutch kit and running it with 4.56s. Unless someone has an open carrier laying around...??
Thanks, All
Kerrdog
Go Fish! <*////><
Unread 08-25-2015, 11:24 AM   #11
Skerr
Just as a point of interest...
Q-tec had the clutch pak for $69, while Morris has it for $96. Amazon for just over $100. None of these quotes include shipping. Clutches ordered.
Kerrdog
Go Fish! <*////><
Unread 08-25-2015, 02:46 PM   #12
John Strenk
1976 CJ5
I'll get a round tuit with putting my 4.11 gears on my trackloc someday.
I know the clutches were good, just need some friction modifier poured in.
Kids keep breaking their cars somehow. Ever try to find an engine for a Mitsubishi Lancer without having it shipped cross country?
Unread 08-25-2015, 05:28 PM   #13
TIPPEDITOVER
In the garage
1978 CJ5
Try this site to find an engine if you haven't already.
http://www.car-part.com/index.htm
Shaun
1978 CJ5 Wheeler
Unread 08-25-2015, 07:43 PM   #14
Skerr
I'll make you a deal on a 258... all you gotta do is pick it up!
I seriously know what it means to finance kids!!
E-mail from Q-tec says BACKORDERED.
WhynthehelldidnttheysaythatwhenIordered???? First such experience I have had with Q-tec. Morris had one set left for $96, but *WAIT*... they price-match. Get it for $69 from Morris, plus $16 S/H, plus sales tax... $90! What's the point...
Any friction modifier you guys particularly like? Yukon Gear has a YT thread that says to soak clutches overnight in FM before assembly. Any comments of further advice??
Kerrdog
Go Fish! <*////><
Unread 08-25-2015, 10:37 PM   #15
Marwis
1981 CJ5
Skerr,
I believe I have a couple of amc 20 open carriers out in my shop. I know one is for the 2.73 ratio. The other I am not sure of. If you interested give me a part number (I believe there are numbers stamped in the carrier that can be referenced to tell what ratio it is good for) and I will go attempt to dig it out.
Marwis is offline   Reply With Quote Quick reply to this message
